Voron 0 + Duet 3 Mini
25
3.0k
    PaulHew @fma
    @fma I am building another V0 but the V0.1
    I have been toying with the SKR, cheaper if you get it shipped from China, but I think after seeing this post has made up my mind, Duet Mini !
    Just need to look at the backpack for the SKR and LRS-100 and move the heatsets so the Duet mini can be mounted on the Underneath.
    I am also thinking about WiFi Version, but would have to hook in with a USB to set the WiFi connection up each time, wherever I might take it.
    Decisions decisions!
    Already have a 220V heater so will keep that as part of the build.
    undefined 1 Reply Last reply 2 May 2021, 17:42 Reply Quote 0
      fma @PaulHew
      @paulhew Forgot to say that I will use a 24V heat bed. I don' like having LV here, as this printer will be used by children...
      Frédéric
      undefined 1 Reply Last reply 3 May 2021, 04:10 Reply Quote 0
        zapta
        The cult of Voron seems to catch significant momentum recently, with vendors offerings kits and products that target vorons (LDO frames, Fsyetc Spider, Funssor metal parts, etc).
        I am working on my V2.4 sourcing, most parts already arrived, black Misumi extrusions will take a little bit longer to arrive.
        So far Klipper seems to be recommended and most common firmware and Spyder seems to be the upcoming recommended controller.
        Next they will expand, I think, to desktop CNC machines but yet to be seen.
        undefined 1 Reply Last reply 20 Jun 2021, 14:05 Reply Quote 0
          zapta @fma
          @fma said in Voron 0 + Duet 3 Mini:
          Do you have room for the larger power supply? I heard that the V0 design is very tight.
          undefined 1 Reply Last reply 3 May 2021, 04:58 Reply Quote 0
            fma @zapta
            @zapta said in Voron 0 + Duet 3 Mini:
            As I drop the Bowden extruder and the Rpi, yes, no problem. The Duet3 Mini fits behind the Z axis, and the power supply fits below.
            And a 120x120mm heatbed does not need a lot of current...
            Frédéric
              PaulHew
              @fma Is there an available mount for the Mini that fits on the 15x15
              I looked in voron users but I cannot find one.
              P.
              undefined undefined 2 Replies Last reply 3 May 2021, 13:09 Reply Quote 0
                fma @PaulHew
                @paulhew I don't own a Duet 3 Mini yet, so didn't look for a mount. But I was thinking to make holes in the rear panel, and mount the Duet with spacers...
                Frédéric
                  Phaedrux Moderator @PaulHew
                  @paulhew said in Voron 0 + Duet 3 Mini:
                  P.
                  It has the same hole spacing as the Maestro, so if there is a mount for that it should work.
                  undefined 2 Replies Last reply 3 May 2021, 20:07 Reply Quote 0
                    PaulHew @Phaedrux
                    @phaedrux Friend just designed one for me.
                    He is good with F360
                    Just need to buy the board. 🙂
                    undefined 1 Reply Last reply 5 May 2021, 03:37 Reply Quote 1
                      PaulHew @Phaedrux
                      @phaedrux Sorry, my manners. That is good info, thank you. I will look for it so I can share.
                        zapta @PaulHew
                        That's a skill that worth the learning time IMO.
                          DanJunior
                          I'm just wondering,if someone has a config.g to get the required esteps as reference. I'm just configuring my V0.1.
                          undefined 1 Reply Last reply 19 Jun 2021, 17:23 Reply Quote 0
                            Phaedrux Moderator @DanJunior
                            @danjunior Which extruder exactly?
                            undefined 1 Reply Last reply 19 Jun 2021, 17:31 Reply Quote 0
                              PaulHew @Phaedrux
                              @phaedrux The V0.1 is a DirectDrive unit, BMG internals and the LDO Pancake stepper.
                              Mine V0.1 is offline at the moment as I am going to have to rebuild the DD unit 😞
                              even at 350ma it cooked again.
                              The rating is suitable for High Temp applications..... So I and possibly like others think that it is suitable for an enclosure, which it is
                              What I did not realise that the motor will heat itself up also, more than any of the OMC's I have been running with no problems @80% of their rating.
                              Slightly disappointed that this info is not displayed clearly when looking at general info on the motor......
                              oliofundefined 1 Reply Last reply 19 Jun 2021, 20:38 Reply Quote 0
                              • oliofundefined
                                oliof @PaulHew
                                @paulhew depending on your microsteps, it'll be 345 or 690 steps/mm on the LDO pancake stepper meant for the Orbiter.
                                  keyz182
                                  This is what I have on my V0.1 + Duet 3 Mini 5+, with OMC steppers. No guarantees it's correct, still tuning in and adjusting, but it's printing things reasonably so should be a good starting point at least. Also, critique welcome 😛
                                  ; Configuration file for Duet 3 Mini 5+ (firmware version 3)
                                  ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Jun 04 2021 16:03:31 GMT+0100 (British Summer Time)
                                  G90                                                   ; send absolute coordinates...
                                  M83                                                   ; ...but relative extruder moves
                                  M550 P"voronzero"                                        ; set printer name
                                  M669 K1                                               ; select CoreXY mode
                                  M569 P0.1 S0                                          ; physical drive 0.1 goes backwards
                                  M569 P0.2 S0                                          ; physical drive 0.2 goes backwards
                                  M569 P0.4 S0                                          ; physical drive 0.4 goes backwards
                                  M569 P0.3 S1                                          ; physical drive 0.3 goes forwards
                                  M584 X0.1 Y0.2 Z0.4 E0.3                              ; set drive mapping
                                  M350 X16 Y16 Z16 E16 I1                               ; configure microstepping with interpolation
                                  M92 X80.00 Y80.00 Z400.00 E1370.00                    ; set steps per mm
                                  M566 X1080.00 Y1080.00 Z90.00 E150.00                   ; set maximum instantaneous speed changes (mm/min)
                                  M203 X30000.00 Y30000.00 Z1200.00 E9000.00            ; set maximum speeds (mm/min)
                                  M201 X4000.00 Y4000.00 Z450.00 E6000.00               ; set accelerations (mm/s^2)
                                  M906 X1250 Y1250 Z400 E800 I25                        ; set motor currents (mA) and motor idle factor in per cent
                                  M84 S30                                               ; Set idle timeout
                                  M208 X0 Y0 Z0 S1                                      ; set axis minima
                                  M208 X120 Y120 Z120 S0                                ; set axis maxima
                                  M574 X2 S1 P"io3.in"                                  ; configure active-high endstop for high end on X via pin io3.in
                                  M574 Y2 S1 P"io5.in"                                  ; configure active-high endstop for high end on Y via pin io5.in
                                  M574 Z1 S1 P"io6.in"                                  ; configure active-high endstop for low end on Z via pin io6.in
                                  M558 P0 H5 F120 T3000                                 ; disable Z probe but set dive height, probe speed and travel speed
                                  M308 S0 P"temp0" Y"thermistor" T100000 B4138          ; configure sensor 0 as thermistor on pin temp0
                                  M950 H0 C"out0" T0                                    ; create bed heater output on out0 and map it to sensor 0
                                  M307 H0 B1 S1.00                                      ; enable bang-bang mode for the bed heater and set PWM limit
                                  M140 H0                                               ; map heated bed to heater 0
                                  M143 H0 S120                                          ; set temperature limit for heater 0 to 120C
                                  M308 S1 P"temp1" Y"pt1000" R2200                      ; configure sensor 1 as PT1000 on pin temp1
                                  M950 H1 C"out1" T1                                    ; create nozzle heater output on out1 and map it to sensor 1
                                  M307 H1 B0 S1.00                                      ; disable bang-bang mode for heater  and set PWM limit
                                  M143 H1 S280                                          ; set temperature limit for heater 1 to 280C
                                  M950 F0 C"out6" Q75                                  ; create fan 0 on pin out6 and set its frequency
                                  M106 P0 C"Cooling" H1 T45 B0.5                     ; set fan 0 name and value. Thermostatic control is turned on
                                  M950 F1 C"out5" Q75                                  ; create fan 1 on pin out5 and set its frequency
                                  M106 P1 C"Part" H-1 B0.5                          ; set fan 1 name and value. Thermostatic control is turned off
                                  M563 P0 D0 H1 F0                                      ; define tool 0
                                  G10 P0 X0 Y0 Z0                                       ; set tool 0 axis offsets
                                  G10 P0 R0 S0                                          ; set initial tool 0 active and standby temperatures to 0C
                                  ; Custom settings
                                  ; DHT22 Temperature Sensor
                                  M308 S10 P"io4.out+io4.in" Y"dht22" A"Chamber Temp"
                                  M308 S11 P"S10.1" Y"dhthumidity" A"Chamber Hum[%]"
                                  ; Set bed screw positions for true bed leveling
                                  M671 X60:5:115 Y5:115:115 P0.5
                                  ;  Laser filament monitor with over the top R values
                                  M591 D0 P6 C"io1.in" R0:200 E3.0 S1
                                  ; ST7567 12864 display
                                  M918 P2 E2                                           ; enable ST7567-based 12864 display
                                  M150 X2 R32 U255 B32 S3                              ; set all 3 LEDs to white
                                  ; M955 P0 C"io0.out+io0.in"
                                  M501                                                  ; load saved parameters from non-volatile memory
                                  T0                                                    ; select first tool
                                  undefined 1 Reply Last reply 19 Jun 2021, 21:49 Reply Quote 0
                                    PaulHew @keyz182
                                    @keyz182 What OMC have you got on the Extruder?
                                    1. I am interested
                                    2. I pray you do not suffer my fate where the LDO motor destroyed my DD plastics.
                                      I was running 800ma, later to find that was too high and should be about 350ish
                                    P.
                                    undefined 1 Reply Last reply 19 Jun 2021, 22:05 Reply Quote 0
                                      keyz182 @PaulHew
                                      @paulhew https://www.omc-stepperonline.com/round-nema-14-bipolar-1-8deg-9-ncm-12-75-oz-in-1-0a-f36x17-5mm-4-wires.html
                                      That's the one. Yeah, it's a bit high, as I said, still tuning. Put probably a roll of filament through at that amperage though and so far it looks fine (had the extruder disassembled yesterday).
                                      undefined 1 Reply Last reply 19 Jun 2021, 22:20 Reply Quote 0
                                        PaulHew @keyz182
                                        @keyz182 Thanks for the info.
                                        Going to steal some of your config!
                                        My LDO even @450ma was hot enough to burn my fingers.
                                        Might get one of those steppers, not trusting the LDO at the moment....
                                        Thanks again
                                        P.
                                          SputnikOC3d @zapta
                                          @zapta cult of Voron ... lol ABS Mafia
                                          undefined 1 Reply Last reply 21 Jun 2021, 04:33 Reply Quote 0
