    Accelerometer Usage
    Beta Firmware
    25
    191
    20.7k
    • DIY-O-Sphereundefined
      DIY-O-Sphere @jbergene
      @jbergene said in Accelerometer Usage:
      M955 P0 C"spi.cs3+spi.cs4
      I had a LIS3DH working with 3,3V
      It seams that you have swaped in and out....
      I also had that wrong with my first attempt....
      M955 P0 C"spi.cs4+spi.cs3
      (UTC+1)
      jbergeneundefined 1 Reply Last reply Reply Quote 0
      • jbergeneundefined
        jbergene @DIY-O-Sphere
        @diy-o-sphere ah sorry my bad, i have tried swapping this too without success. Just forgot to edit the text. my bad
        DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
          @jbergene
          My wiring is in this thread...just for double check...
          https://forum.duet3d.com/topic/23559/accelerometer-usage/15
          (UTC+1)
          • jbergeneundefined
            @diy-o-sphere switched the wiring from the daughterboard pinouts to the Paneldue pinout with same results.
              @jbergene
              M955 P0 I61 C"io0.out+io0.in"               ; Define IO for accelerometer
              (UTC+1)
              • jbergeneundefined
                @diy-o-sphere M955 P0 I61 C"io0.out+io0.in"
                Error: M955: Unknown pin name 'io0.out'
                  @jbergene
                  Sorry, thats for a Mini5+
                  (UTC+1)
                  • jbergeneundefined
                    jbergene @jbergene
                    @jbergene
                    update
                    it worked when removing the Paneldue and disabling paneldue in the config file.
                    (still using Daughter board pins)
                    • jbergeneundefined
                      jbergene @jbergene
                      @jbergene Now I get another issue and that is the Duet2 just reset every time I try to record. It some how manages to record something, but the CSV file is invalid.
                      Duet also states that the LISD3H is aLIS3DSH which is incorrect. (the board have LIS3DH typed in on it)
                        Phaedrux Moderator @jbergene
                        Photo of the board?
                        And can you send M115 to report the specific firmware version?
                        • oliofundefined
                          oliof
                          @dc42 how'd you do InputShaping for IDEX machines? In independent head mode, I guess I can set the InputShaping for each head in tpre#.g, but what about copy mode / mirror mode? I guess to keep with the program, the task here is to build the IDEX machine so a common InputShaping setup for X and U is viable?
                            dc42 administrators @oliof
                            @oliof said in Accelerometer Usage:
                            For now, yes. In future we RRF may support different shaping on the X and U print heads.
                            • jbergeneundefined
                              jbergene @Phaedrux
                              @phaedrux 2021-08-16 20_56_18-Foto - Google Foto.png 2021-08-16 20_56_00-MessageCenterUI.png
                                dc42 administrators @jbergene
                                @jbergene can you read any markings on the accelerometer chip? You may need to find the correct lighting angle to see it.
                                • tekstyleundefined
                                  tekstyle
                                  i got my accelerometer installed using a usb3 cable, i was able to get it working even over 3meters!! i generated the csv files but right now i am stuck at figuring out how to make use of the data. how do i know which frequency to use in M953 Fnn? do i actually need to print something to tune even with the accelerometer? i was under the impression that printing and measure ringing and calculating Hz wS only needed if you dont have an accelerometer to generate the csv files.
                                  Phaedruxundefined jbergeneundefined 2 Replies Last reply Reply Quote 1
                                    Phaedrux Moderator @tekstyle
                                    @tekstyle See here: https://duet3d.dozuki.com/Wiki/Accelerometers
                                    Having the accelerometer is just the first step. You will need to do some test movements to get readings and then analyze them to determine which frequencies are needed to use with the input shaper.
                                    oliofundefined tekstyleundefined 2 Replies Last reply Reply Quote 0
                                    • jbergeneundefined
                                      jbergene @tekstyle
                                      @tekstyle thats smart! i will try that 😄
                                      • oliofundefined
                                        oliof @Phaedrux
                                        @phaedrux the documentation currently lacks the two crucial sentences, how to find out the dominant frequency of an axis ... but the InputShaping plugin will solve this eventually (-:
                                        CCS86undefined 1 Reply Last reply Reply Quote 1
                                        • jbergeneundefined
                                          jbergene @dc42
                                          8937
                                          c3H
                                          0KK1F?
                                          • CCS86undefined
                                            CCS86 @oliof
                                            This feature is barely in beta form. You can't really expect comprehensive documentation at this point.
