    Accelerometer Usage
    Beta Firmware
    25
    191
    22.9k
    • jbergeneundefined
      jbergene @DIY-O-Sphere
      @diy-o-sphere switched the wiring from the daughterboard pinouts to the Paneldue pinout with same results.
      DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
      • DIY-O-Sphereundefined
        DIY-O-Sphere @jbergene
        @jbergene
        M955 P0 I61 C"io0.out+io0.in"               ; Define IO for accelerometer
        (UTC+1)
        jbergeneundefined 1 Reply Last reply Reply Quote 0
        • jbergeneundefined
          @diy-o-sphere M955 P0 I61 C"io0.out+io0.in"
          Error: M955: Unknown pin name 'io0.out'
            @jbergene
            Sorry, thats for a Mini5+
            (UTC+1)
            • jbergeneundefined
              jbergene @jbergene
              @jbergene
              update
              it worked when removing the Paneldue and disabling paneldue in the config file.
              (still using Daughter board pins)
              • jbergeneundefined
                jbergene @jbergene
                @jbergene Now I get another issue and that is the Duet2 just reset every time I try to record. It some how manages to record something, but the CSV file is invalid.
                Duet also states that the LISD3H is aLIS3DSH which is incorrect. (the board have LIS3DH typed in on it)
                  Phaedrux Moderator @jbergene
                  @jbergene said in Accelerometer Usage:
                  Photo of the board?
                  And can you send M115 to report the specific firmware version?
                  • oliofundefined
                    oliof
                    @dc42 how'd you do InputShaping for IDEX machines? In independent head mode, I guess I can set the InputShaping for each head in tpre#.g, but what about copy mode / mirror mode? I guess to keep with the program, the task here is to build the IDEX machine so a common InputShaping setup for X and U is viable?
                      dc42 administrators @oliof
                      @oliof said in Accelerometer Usage:
                      For now, yes. In future we RRF may support different shaping on the X and U print heads.
                      • jbergeneundefined
                        jbergene @Phaedrux
                        @phaedrux 2021-08-16 20_56_18-Foto - Google Foto.png 2021-08-16 20_56_00-MessageCenterUI.png
                          dc42 administrators @jbergene
                          @jbergene can you read any markings on the accelerometer chip? You may need to find the correct lighting angle to see it.
                          • tekstyleundefined
                            tekstyle
                            i got my accelerometer installed using a usb3 cable, i was able to get it working even over 3meters!! i generated the csv files but right now i am stuck at figuring out how to make use of the data. how do i know which frequency to use in M953 Fnn? do i actually need to print something to tune even with the accelerometer? i was under the impression that printing and measure ringing and calculating Hz wS only needed if you dont have an accelerometer to generate the csv files.
                            Phaedruxundefined jbergeneundefined 2 Replies Last reply Reply Quote 1
                              Phaedrux Moderator @tekstyle
                              @tekstyle See here: https://duet3d.dozuki.com/Wiki/Accelerometers
                              Having the accelerometer is just the first step. You will need to do some test movements to get readings and then analyze them to determine which frequencies are needed to use with the input shaper.
                              oliofundefined tekstyleundefined 2 Replies Last reply Reply Quote 0
                              • jbergeneundefined
                                jbergene @tekstyle
                                @tekstyle thats smart! i will try that 😄
                                • oliofundefined
                                  oliof @Phaedrux
                                  @phaedrux the documentation currently lacks the two crucial sentences, how to find out the dominant frequency of an axis ... but the InputShaping plugin will solve this eventually (-:
                                  CCS86undefined 1 Reply Last reply Reply Quote 1
                                  • jbergeneundefined
                                    jbergene @dc42
                                    8937
                                    c3H
                                    0KK1F?
                                    • CCS86undefined
                                      CCS86 @oliof
                                      This feature is barely in beta form. You can't really expect comprehensive documentation at this point.
                                      • oliofundefined
                                        oliof
                                        I am not expecting comprehensive documentation at this point. As I wrote I am looking forward to the eventual solution via the InputShaping plugin.
                                        • tekstyleundefined
                                          tekstyle @Phaedrux
                                          @phaedrux i have the accelerometer plugin. i was able to visual the graph for all 3 axis. i just dont know what to look for as the link provided isnt clear on how to interpret the data to figure out which hz to use. or i am just not understanding the content.
                                            @tekstyle No you're right. That part is coming and hopefully will be more automated by the plugin to suggest what it should tune out, among other things.
                                            tekstyleundefined 1 Reply Last reply Reply Quote 0
