    Tool Board Heater Tuning Leading To Faults
    101
    5.4k
    • fcwiltundefined
      fcwilt @KevinMar
      @kevinmar said in Tool Board Heater Tuning Leading To Faults:
      @fcwilt it included M307 commands that were generated from the autotuning and saved using M500
      So we can ignore the ones in your config.g file?
      KevinMarundefined 1 Reply Last reply Reply Quote 0
      • KevinMarundefined
        KevinMar @fcwilt
        @fcwilt They're identical
        • fcwiltundefined
          fcwilt @KevinMar
          So you copied the lines from the config-override.g file and put them into your config.g file?
          I assume you re-booted.
          • KevinMarundefined
            KevinMar @fcwilt
            @fcwilt Affirmative
            • fcwiltundefined
              fcwilt @KevinMar
              @fcwilt Affirmative
              Strange problem you are having.
              You posted a screen shot showing heaters Ex0, Ex1 and Ex3 faulted.
              Were all three heating at the time?
              • DIY-O-Sphereundefined
                DIY-O-Sphere @fcwilt
                @KevinMar
                M308 S1 P"20.temp0" Y"thermistor" T100000 B4725 C7.06e-8 A"Ex0"
                On T0 you use a thermistor but not with the other tools?
                What is your tuning command.
                (UTC+1)
                • KevinMarundefined
                  KevinMar @fcwilt
                  @fcwilt Yes, all 3 faulted (nearly) simultaneously, when heating is initiated simultaneously
                  • KevinMarundefined
                    KevinMar @DIY-O-Sphere
                    @diy-o-sphere Changed to thermistor (actually changed hardware) just to try troubleshooting
                    DIY-O-Sphereundefined dc42undefined 2 Replies Last reply Reply Quote 0
                      DIY-O-Sphere @KevinMar
                      @kevinmar
                      CAN addresses set correctly?
                      (UTC+1)
                        dc42 administrators @KevinMar
                        @kevinmar did you see my comment about retuning with a silicone sock in place, and my suggestion to reduce the M307 R parameter?
                        • KevinMarundefined
                          KevinMar @dc42
                          @dc42 said in Tool Board Heater Tuning Leading To Faults:
                          If after re-tuning with the silicone sock on (if necessary) the heaters still fault, you can try reducing the M307 R parameter. Try a 30% reduction.
                          I added the sock, retuned, and it still faulted.
                          I reduced R from 2 to 1.5 and even to 1.0 and it didn't help
                          • KevinMarundefined
                            @diy-o-sphere lol yeah, boards working fine otherwise
                              I reduced R from 2 to 1.5 and it didn't help
                              Did the R value change much when you added the sock, or was it just the C values that changed?
                              • fcwiltundefined
                                fcwilt @KevinMar
                                If you execute a M570 command from the DWC Console what value does it report?
                                • KevinMarundefined
                                  KevinMar @dc42
                                  @dc42 C values changed when tuning with the sock.
                                  R values were a manual change
                                  • KevinMarundefined
                                    KevinMar @fcwilt
                                    @fcwilt "Print will be terminated if a heater fault is not reset within 10 minutes"
                                      @kevinmar confirm you are running firmware 3.3 on both main board and tool board?
                                      • KevinMarundefined
                                        KevinMar @dc42
                                        @dc42 yes, 100%. All running 3.3 non beta or anything
                                        • fcwiltundefined
                                          fcwilt @KevinMar
                                          As a test have you commented out the settings for all but one tool heater to see if that makes a difference?
                                          • KevinMarundefined
                                            KevinMar @fcwilt
                                            @fcwilt huh? Just comment out all of the heaters? I have not tried that.
                                            Should I add "M570 H1 P10 T15 S0" to my config?
