    Tool Board Heater Tuning Leading To Faults
    101
    5.4k
    • fcwiltundefined
      fcwilt @KevinMar
      @kevinmar said in Tool Board Heater Tuning Leading To Faults:
      @fcwilt They're identical
      So you copied the lines from the config-override.g file and put them into your config.g file?
      I assume you re-booted.
      KevinMarundefined 1 Reply Last reply Reply Quote 0
      • KevinMarundefined
        KevinMar @fcwilt
        @fcwilt Affirmative
        • fcwiltundefined
          fcwilt @KevinMar
          @fcwilt Affirmative
          Strange problem you are having.
          You posted a screen shot showing heaters Ex0, Ex1 and Ex3 faulted.
          Were all three heating at the time?
          • DIY-O-Sphereundefined
            DIY-O-Sphere @fcwilt
            @KevinMar
            M308 S1 P"20.temp0" Y"thermistor" T100000 B4725 C7.06e-8 A"Ex0"
            On T0 you use a thermistor but not with the other tools?
            What is your tuning command.
            (UTC+1)
            • KevinMarundefined
              KevinMar @fcwilt
              @fcwilt Yes, all 3 faulted (nearly) simultaneously, when heating is initiated simultaneously
              • KevinMarundefined
                KevinMar @DIY-O-Sphere
                @diy-o-sphere Changed to thermistor (actually changed hardware) just to try troubleshooting
                DIY-O-Sphereundefined dc42undefined 2 Replies Last reply Reply Quote 0
                  DIY-O-Sphere @KevinMar
                  @kevinmar
                  CAN addresses set correctly?
                  (UTC+1)
                    dc42 administrators @KevinMar
                    @kevinmar did you see my comment about retuning with a silicone sock in place, and my suggestion to reduce the M307 R parameter?
                    • KevinMarundefined
                      KevinMar @dc42
                      @dc42 said in Tool Board Heater Tuning Leading To Faults:
                      If after re-tuning with the silicone sock on (if necessary) the heaters still fault, you can try reducing the M307 R parameter. Try a 30% reduction.
                      I added the sock, retuned, and it still faulted.
                      I reduced R from 2 to 1.5 and even to 1.0 and it didn't help
                      • KevinMarundefined
                        @diy-o-sphere lol yeah, boards working fine otherwise
                          I reduced R from 2 to 1.5 and it didn't help
                          Did the R value change much when you added the sock, or was it just the C values that changed?
                          • fcwiltundefined
                            fcwilt @KevinMar
                            If you execute a M570 command from the DWC Console what value does it report?
                            • KevinMarundefined
                              KevinMar @dc42
                              @dc42 C values changed when tuning with the sock.
                              R values were a manual change
                              • KevinMarundefined
                                KevinMar @fcwilt
                                @fcwilt "Print will be terminated if a heater fault is not reset within 10 minutes"
                                  @kevinmar confirm you are running firmware 3.3 on both main board and tool board?
                                  • KevinMarundefined
                                    KevinMar @dc42
                                    @dc42 yes, 100%. All running 3.3 non beta or anything
                                    • fcwiltundefined
                                      fcwilt @KevinMar
                                      As a test have you commented out the settings for all but one tool heater to see if that makes a difference?
                                      • KevinMarundefined
                                        KevinMar @fcwilt
                                        @fcwilt huh? Just comment out all of the heaters? I have not tried that.
                                        Should I add "M570 H1 P10 T15 S0" to my config?
                                        • KevinMarundefined
                                          KevinMar
                                          The thing that keeps confusing me is that this is a very standard-issue setup. Running all standard E3D + Duet hardware, and running a stable release of the firmware.
                                          • fcwiltundefined
                                            fcwilt @KevinMar
                                            I was wondering if the same problem would occur you if you only had one extruder heater configured.
                                            As to the M570 I was working with out of date documentation.
                                            It turns out with current firmware it appears you have to have a H parameter to set/report on a given heater.
