    Tool Board Heater Tuning Leading To Faults
    101
    5.4k
    • KevinMarundefined
      KevinMar @fcwilt
      @fcwilt They're identical
      • fcwiltundefined
        fcwilt @KevinMar
        @kevinmar said in Tool Board Heater Tuning Leading To Faults:
        So you copied the lines from the config-override.g file and put them into your config.g file?
        I assume you re-booted.
        KevinMarundefined 1 Reply Last reply Reply Quote 0
        • KevinMarundefined
          KevinMar @fcwilt
          @fcwilt Affirmative
          • fcwiltundefined
            fcwilt @KevinMar
            @fcwilt Affirmative
            Strange problem you are having.
            You posted a screen shot showing heaters Ex0, Ex1 and Ex3 faulted.
            Were all three heating at the time?
            • DIY-O-Sphereundefined
              DIY-O-Sphere @fcwilt
              @KevinMar
              M308 S1 P"20.temp0" Y"thermistor" T100000 B4725 C7.06e-8 A"Ex0"
              On T0 you use a thermistor but not with the other tools?
              What is your tuning command.
              (UTC+1)
              • KevinMarundefined
                KevinMar @fcwilt
                @fcwilt Yes, all 3 faulted (nearly) simultaneously, when heating is initiated simultaneously
                • KevinMarundefined
                  KevinMar @DIY-O-Sphere
                  @diy-o-sphere Changed to thermistor (actually changed hardware) just to try troubleshooting
                  DIY-O-Sphereundefined dc42undefined 2 Replies Last reply Reply Quote 0
                    DIY-O-Sphere @KevinMar
                    @kevinmar
                    CAN addresses set correctly?
                    (UTC+1)
                      dc42 administrators @KevinMar
                      @kevinmar did you see my comment about retuning with a silicone sock in place, and my suggestion to reduce the M307 R parameter?
                      • KevinMarundefined
                        KevinMar @dc42
                        @dc42 said in Tool Board Heater Tuning Leading To Faults:
                        If after re-tuning with the silicone sock on (if necessary) the heaters still fault, you can try reducing the M307 R parameter. Try a 30% reduction.
                        I added the sock, retuned, and it still faulted.
                        I reduced R from 2 to 1.5 and even to 1.0 and it didn't help
                        • KevinMarundefined
                          @diy-o-sphere lol yeah, boards working fine otherwise
                            I reduced R from 2 to 1.5 and it didn't help
                            Did the R value change much when you added the sock, or was it just the C values that changed?
                            • fcwiltundefined
                              fcwilt @KevinMar
                              If you execute a M570 command from the DWC Console what value does it report?
                              • KevinMarundefined
                                KevinMar @dc42
                                @dc42 C values changed when tuning with the sock.
                                R values were a manual change
                                • KevinMarundefined
                                  KevinMar @fcwilt
                                  @fcwilt "Print will be terminated if a heater fault is not reset within 10 minutes"
                                    @kevinmar confirm you are running firmware 3.3 on both main board and tool board?
                                    • KevinMarundefined
                                      KevinMar @dc42
                                      @dc42 yes, 100%. All running 3.3 non beta or anything
                                      • fcwiltundefined
                                        fcwilt @KevinMar
                                        As a test have you commented out the settings for all but one tool heater to see if that makes a difference?
                                        • KevinMarundefined
                                          KevinMar @fcwilt
                                          @fcwilt huh? Just comment out all of the heaters? I have not tried that.
                                          Should I add "M570 H1 P10 T15 S0" to my config?
                                          • KevinMarundefined
                                            KevinMar
                                            The thing that keeps confusing me is that this is a very standard-issue setup. Running all standard E3D + Duet hardware, and running a stable release of the firmware.
