    New Raspberry Pi Zero 2W
    65
    4.2k
    • o_lampeundefined
      o_lampe @T3P3Tony
      @t3p3tony said in New Raspberry Pi Zero 2W:
      There could be applications for a coprocessor (maybe not so much a toolboard but on a mainboard) but it adds significantly to the complexity of many things (think a firmware update).
      I'd happily go that extra mile, if it helps the huge Duet2-community "over the hump" and enables it to benefit from future development.
      The M0 processor has ~twice the power of the onboard MCU. If we'd use the onboard MCU as gateway and the M0 as mainprocessor, it would be a huge leap forward. (just dreaming)
        T3P3Tony administrators @o_lampe
        @o_lampe I don't understand exactly what you are proposing? what would the board with the pico do? how would it communicate (and what hump are we getting over?)
        • o_lampeundefined
          o_lampe @T3P3Tony
          @t3p3tony the M0 could do the multi-stream gcode analysis, while the onboard MCU does the pulse-generating for steppers, PWM a.s.o.
          The hump is the limited RAM of the duet2 mcu
            @o_lampe said in New Raspberry Pi Zero 2W:
            @t3p3tony
            I tried to find a Pico board with Sam-C21 and CAN-FD.
            See https://duet3d.dozuki.com/Wiki/Using_the_Sammy-C21_development_board_with_Duet_3.
            PCRundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
            • PCRundefined
              PCR @dc42
              • o_lampeundefined
                o_lampe @dc42
                @dc42 I know the board, but it's out off stock and quite expensive. (27EUR vs 4EUR)
                But I'd still consider it as Duet2 CoPro as described above.
                @T3P3Tony I wouldn't mind to delete the last posts and start a new thread, although everything I posted about the M0 is IMHO also valid for the Zero 2W and any other SBC
                  T3P3Tony administrators @PCR
                  @pcr nice! why the two different headers, one for Duet 3 and one for the 3 mini?
                  PCRundefined 1 Reply Last reply Reply Quote 0
                  • PCRundefined
                    PCR @T3P3Tony
                    @t3p3tony yes. I dont want to Stack in diectly on the Board. Because of some connectors. And yes the Header is placed diffrently on duet 3 and Duet Mini ;(
                    • PCRundefined
                      PCR @PCR
                      @pcr btw someone from Germany who Likes to Test the Board ?
                      o_lampeundefined PCRundefined 2 Replies Last reply Reply Quote 1
                      • zaptaundefined
                        zapta @T3P3Tony
                        definitely worth giving it a go though!
                        How about a duet controller board with a plugged in Pi Zero for both controller and SBC functionalities?
                        Edit: or a Pi Zero and a minimal MCU for i/o only, basically a Klipper style RRF on a single board.
                        • o_lampeundefined
                          o_lampe @PCR
                          @pcr said in New Raspberry Pi Zero 2W:
                          Ich habe heute einen Zero 2W bestellt, aber ich habe weder Duet3 oder Mini5+.
                          Vielleicht @cosmowave ?
                          English: I've ordered a Z2W, but don't have duet3 nor Mini5...maybe Cosmowave?
                          • PCRundefined
                            PCR @PCR
                            @pcr
                            pi@raspberrypi:~ $ neofetch
                              `.::///+:/-.        --///+//-:``    pi@raspberrypi
                             `+oooooooooooo:   `+oooooooooooo:    --------------
                              /oooo++//ooooo:  ooooo+//+ooooo.    OS: Raspbian GNU/Linux 10 (buster) armv7l
                              `+ooooooo:-:oo-  +o+::/ooooooo:     Host: Raspberry Pi Zero 2 Rev 1.0
                               `:oooooooo+``    `.oooooooo+-      Kernel: 5.10.63-v7+
                                 `:++ooo/.        :+ooo+/.`       Uptime: 10 mins
                                    ...`  `.----.` ``..           Packages: 533 (dpkg)
                                 .::::-``:::::::::.`-:::-`        Shell: bash 5.0.3
                                -:::-`   .:::::::-`  `-:::-       Terminal: /dev/pts/0
                               `::.  `.--.`  `` `.---.``.::`      CPU: BCM2835 (4) @ 1.000GHz
                                   .::::::::`  -::::::::` `       Memory: 49MiB / 427MiB
                            pi@raspberrypi:~ $ ls /opt/dsf/sd
                            filaments  firmware  gcodes  macros  menu  sys  www
                            • PCRundefined
                              PCR @T3P3Tony
                              @t3p3tony https://copperhilltech.com/canpico-can-fd-module-with-raspberry-pi-pico/
                              oliofundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
                              • oliofundefined
                                oliof @PCR
                                @pcr I am game.
                                • o_lampeundefined
                                  o_lampe @PCR
                                  @pcr
                                  CAN-FD module for RasPi Pico I checked the prices of the main components: the CAN-FD module and the transceiver chip cost less than 3€
                                  Why is this module so expensive?
                                  • PCRundefined
                                    PCR @o_lampe
                                    @o_lampe dont Know. Could be the programming software. If Somebody would be interested in programming i would make a small Board with only the 2040 chip
                                    • o_lampeundefined
                                      o_lampe @PCR
                                      It's open source
                                      The open-source MicroPython SDK from Canis Labs implements a sophisticated CAN API, including priority-inversion free drivers, 1μs accuracy timestamps, large buffers, and an API for triggering a logic analyzer or oscilloscope.
                                      If you make your own CAN-board, make sure all Pico through-hole pins are still available
                                      • PCRundefined
                                        PCR @o_lampe
                                        @o_lampe Sure 😉 First development would be a hat for the pico
                                        • o_lampeundefined
                                          o_lampe @PCR
                                          @pcr I wonder, if it would also work for the Zero 2W? A quad-core 1GHz SBC-board with CAN-FD would be a gamechanger...
                                          • PCRundefined
                                            PCR @o_lampe
                                            @o_lampe
                                            Should
                                            https://copperhilltech.com/pican-fd-zero-can-fd-hat-for-raspberry-pi-zero-with-1a-smps/
                                            o_lampeundefined 1 Reply Last reply Reply Quote 1
