    New Raspberry Pi Zero 2W
    65
    4.2k
      @o_lampe said in New Raspberry Pi Zero 2W:
      @t3p3tony
      I tried to find a Pico board with Sam-C21 and CAN-FD.
      See https://duet3d.dozuki.com/Wiki/Using_the_Sammy-C21_development_board_with_Duet_3.
      PCRundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
      • PCRundefined
        PCR @dc42
        • o_lampeundefined
          o_lampe @dc42
          @dc42 I know the board, but it's out off stock and quite expensive. (27EUR vs 4EUR)
          But I'd still consider it as Duet2 CoPro as described above.
          @T3P3Tony I wouldn't mind to delete the last posts and start a new thread, although everything I posted about the M0 is IMHO also valid for the Zero 2W and any other SBC
            T3P3Tony administrators @PCR
            @pcr nice! why the two different headers, one for Duet 3 and one for the 3 mini?
            PCRundefined 1 Reply Last reply Reply Quote 0
            • PCRundefined
              PCR @T3P3Tony
              @t3p3tony yes. I dont want to Stack in diectly on the Board. Because of some connectors. And yes the Header is placed diffrently on duet 3 and Duet Mini ;(
              • PCRundefined
                PCR @PCR
                @pcr btw someone from Germany who Likes to Test the Board ?
                o_lampeundefined PCRundefined 2 Replies Last reply Reply Quote 1
                • zaptaundefined
                  zapta @T3P3Tony
                  @t3p3tony said in New Raspberry Pi Zero 2W:
                  definitely worth giving it a go though!
                  How about a duet controller board with a plugged in Pi Zero for both controller and SBC functionalities?
                  Edit: or a Pi Zero and a minimal MCU for i/o only, basically a Klipper style RRF on a single board.
                  • o_lampeundefined
                    o_lampe @PCR
                    @pcr said in New Raspberry Pi Zero 2W:
                    Ich habe heute einen Zero 2W bestellt, aber ich habe weder Duet3 oder Mini5+.
                    Vielleicht @cosmowave ?
                    English: I've ordered a Z2W, but don't have duet3 nor Mini5...maybe Cosmowave?
                    • PCRundefined
                      PCR @PCR
                      @pcr
                      pi@raspberrypi:~ $ neofetch
                        `.::///+:/-.        --///+//-:``    pi@raspberrypi
                       `+oooooooooooo:   `+oooooooooooo:    --------------
                        /oooo++//ooooo:  ooooo+//+ooooo.    OS: Raspbian GNU/Linux 10 (buster) armv7l
                        `+ooooooo:-:oo-  +o+::/ooooooo:     Host: Raspberry Pi Zero 2 Rev 1.0
                         `:oooooooo+``    `.oooooooo+-      Kernel: 5.10.63-v7+
                           `:++ooo/.        :+ooo+/.`       Uptime: 10 mins
                              ...`  `.----.` ``..           Packages: 533 (dpkg)
                           .::::-``:::::::::.`-:::-`        Shell: bash 5.0.3
                          -:::-`   .:::::::-`  `-:::-       Terminal: /dev/pts/0
                         `::.  `.--.`  `` `.---.``.::`      CPU: BCM2835 (4) @ 1.000GHz
                             .::::::::`  -::::::::` `       Memory: 49MiB / 427MiB
                      pi@raspberrypi:~ $ ls /opt/dsf/sd
                      filaments  firmware  gcodes  macros  menu  sys  www
                      • PCRundefined
                        PCR @T3P3Tony
                        @t3p3tony https://copperhilltech.com/canpico-can-fd-module-with-raspberry-pi-pico/
                        oliofundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
                        • oliofundefined
                          oliof @PCR
                          @pcr I am game.
                          • o_lampeundefined
                            o_lampe @PCR
                            @pcr
                            CAN-FD module for RasPi Pico I checked the prices of the main components: the CAN-FD module and the transceiver chip cost less than 3€
                            Why is this module so expensive?
                            • PCRundefined
                              PCR @o_lampe
                              @o_lampe dont Know. Could be the programming software. If Somebody would be interested in programming i would make a small Board with only the 2040 chip
                              • o_lampeundefined
                                o_lampe @PCR
                                It's open source
                                The open-source MicroPython SDK from Canis Labs implements a sophisticated CAN API, including priority-inversion free drivers, 1μs accuracy timestamps, large buffers, and an API for triggering a logic analyzer or oscilloscope.
                                If you make your own CAN-board, make sure all Pico through-hole pins are still available
                                • PCRundefined
                                  PCR @o_lampe
                                  @o_lampe Sure 😉 First development would be a hat for the pico
                                  • o_lampeundefined
                                    o_lampe @PCR
                                    @pcr I wonder, if it would also work for the Zero 2W? A quad-core 1GHz SBC-board with CAN-FD would be a gamechanger...
                                    • PCRundefined
                                      PCR @o_lampe
                                      @o_lampe
                                      Should
                                      https://copperhilltech.com/pican-fd-zero-can-fd-hat-for-raspberry-pi-zero-with-1a-smps/
                                      o_lampeundefined 1 Reply Last reply Reply Quote 1
                                      • o_lampeundefined
                                        o_lampe @PCR
                                        @pcr @T3P3Tony If we could integrate CAN-FD as PIO state machine in M0(Pico) hardware, we would only need a tranceiver...
                                        • oliofundefined
                                          oliof @o_lampe
                                          @o_lampe is that realtime capable though?
                                          • o_lampeundefined
                                            o_lampe @oliof
                                            @oliof I started reading about PIO statemachines yesterday, so I might got a wrong impression. They say, those state machine work independant from the processor.
                                            I assume RRF uses them for pulse generation, too.
                                            gloomyandyundefined 1 Reply Last reply Reply Quote 0
