New Raspberry Pi Zero 2W
@dc42 I know the board, but it's out off stock and quite expensive. (27EUR vs 4EUR)
But I'd still consider it as Duet2 CoPro as described above.@T3P3Tony I wouldn't mind to delete the last posts and start a new thread, although everything I posted about the M0 is IMHO also valid for the Zero 2W and any other SBC
@pcr nice! why the two different headers, one for Duet 3 and one for the 3 mini?
@t3p3tony yes. I dont want to Stack in diectly on the Board. Because of some connectors. And yes the Header is placed diffrently on duet 3 and Duet Mini ;(
@pcr btw someone from Germany who Likes to Test the Board ?
@t3p3tony said in New Raspberry Pi Zero 2W:
definitely worth giving it a go though!
How about a duet controller board with a plugged in Pi Zero for both controller and SBC functionalities?
Edit: or a Pi Zero and a minimal MCU for i/o only, basically a Klipper style RRF on a single board.
@pcr said in New Raspberry Pi Zero 2W:
Ich habe heute einen Zero 2W bestellt, aber ich habe weder Duet3 oder Mini5+.
Vielleicht @cosmowave ?English: I've ordered a Z2W, but don't have duet3 nor Mini5...maybe Cosmowave?
pi@raspberrypi:~ $ neofetch `.::///+:/-. --///+//-:`` pi@raspberrypi `+oooooooooooo: `+oooooooooooo: -------------- /oooo++//ooooo: ooooo+//+ooooo. OS: Raspbian GNU/Linux 10 (buster) armv7l `+ooooooo:-:oo- +o+::/ooooooo: Host: Raspberry Pi Zero 2 Rev 1.0 `:oooooooo+`` `.oooooooo+- Kernel: 5.10.63-v7+ `:++ooo/. :+ooo+/.` Uptime: 10 mins ...` `.----.` ``.. Packages: 533 (dpkg) .::::-``:::::::::.`-:::-` Shell: bash 5.0.3 -:::-` .:::::::-` `-:::- Terminal: /dev/pts/0 `::. `.--.` `` `.---.``.::` CPU: BCM2835 (4) @ 1.000GHz .::::::::` -::::::::` ` Memory: 49MiB / 427MiB .::` .:::::::::- `::::::::::``::. -:::` ::::::::::. ::::::::::.`:::- :::: -::::::::. `-:::::::: :::: -::- .-:::-.``....``.-::-. -::- .. `` .::::::::. `..`.. -:::-` -::::::::::` .:::::` :::::::` -::::::::::` :::::::. .::::::: -::::::::. :::::::: `-:::::` ..--.` ::::::. `...` `...--..` `...` .:::::::::: `.-::::-` pi@raspberrypi:~ $ ls /opt/dsf/sd filaments firmware gcodes macros menu sys www
@pcr I am game.
@pcr
CAN-FD module for RasPi Pico I checked the prices of the main components: the CAN-FD module and the transceiver chip cost less than 3€
Why is this module so expensive? -
@o_lampe dont Know. Could be the programming software. If Somebody would be interested in programming i would make a small Board with only the 2040 chip
It's open source
The open-source MicroPython SDK from Canis Labs implements a sophisticated CAN API, including priority-inversion free drivers, 1μs accuracy timestamps, large buffers, and an API for triggering a logic analyzer or oscilloscope.
If you make your own CAN-board, make sure all Pico through-hole pins are still available
@o_lampe Sure First development would be a hat for the pico
@pcr I wonder, if it would also work for the Zero 2W? A quad-core 1GHz SBC-board with CAN-FD would be a gamechanger...
@o_lampe is that realtime capable though?
@oliof I started reading about PIO statemachines yesterday, so I might got a wrong impression. They say, those state machine work independant from the processor.
I assume RRF uses them for pulse generation, too. -
@o_lampe said in New Raspberry Pi Zero 2W:
I assume RRF uses them for pulse generation, too.Does RRF currently run on any hardware that has a PIO state machine?
@gloomyandy
It seems only the M0 processor has those state machines. The M4 (duet2) doesn't have.
I'm not even sure, if the Sam-C21 has them, although it's from the M0 family.
