    Wiki/Docs images broken?
    17
    647
    • davehundefined
      daveh
      It looks to me like the docs images are currently broken. For example this page looks like this
      When you open the image in a new tab, you get an Access Denied XML
      • Luke'sLaboratoryundefined
        Luke'sLaboratory
        Broke for me as well.
        Luke
        Luke
        http://lukeslab.online
        alankilianundefined 1 Reply Last reply Reply Quote 1
        • alankilianundefined
          alankilian @Luke'sLaboratory
          Yeah, they are all:
          <Error>
          <Code>AccessDenied</Code>
          <Message>Access Denied</Message>
          <RequestId>9M6RDES61EPS6YX7</RequestId>
          <HostId>
          JBH+TFLbCYZ1p2k99NJ84EbG1RBo8bTAlrxdaonjrFo7sm/F9nhRM2wigWZWVGawRt2VpZa2C+E=
          </HostId>
          </Error>
          Dave Parryundefined 1 Reply Last reply Reply Quote 1
          • Dave Parryundefined
            Dave Parry @alankilian
            me too. Annoying as I want to assemble my magnetic sensor. But without pics it's difficult.
            • Gubbfittanundefined
              Gubbfittan
              I have the same... Just about to assemble a Duet 3 mini 😞
              • o_lampeundefined
                o_lampe @Dave Parry
                @dave-parry said in Wiki/Docs images broken?:
                You might find the pics cached somewhere. Tried to guugel it?
                I guess it's related to the new java safety issue? I had to install several updates lately as a reaction to this issue.
                davehundefined 1 Reply Last reply Reply Quote 0
                • nyaruundefined
                  nyaru
                  I have same troubles.
                  If you're using chrome, you can avoid this problem by adding "cache:" to the URL.
                  like this.
                  cache:https://duet3d.dozuki.com/c/Duet_3_Mainboard_6HC
                  • davehundefined
                    daveh @o_lampe
                    Log4Shell? I doubt it. It appears the S3 bin has had public access disabled.
                    • davehundefined
                      daveh
                      Some images have started appearing this morning!
                      • oliofundefined
                        oliof
                        This post is deleted!
                        Gixxerfastundefined 1 Reply Last reply Reply Quote 0
                        • Gixxerfastundefined
                          Gixxerfast @oliof
                          There, to expand the images you have to right click and open them in a new tab.
                          Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
                          Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
                          Ender 3 Pro with BTT SKR-2 + RRF
                            droftarts administrators
                            Sorry folks, not sure what is going on, but I think it’s an issue with Dozuki servers. @T3P3Tony is out of the office at the moment, but will look at it as soon as he can I’m sure. Images that are summary images (top of the page) are now showing, so I guess they are slowly rebuilding the image server. Hopefully it will be back up soon.
                            Please don’t use the link @oliof posted; you’ll crash that too! It isn’t ready for prime time, and has limited resources. It’s what I’ve been working on for quite a few months…
                            Gixxerfastundefined 1 Reply Last reply Reply Quote 1
                              Gixxerfast @droftarts
                              @droftarts said in Wiki/Docs images broken?:
                              But that's the one that's linked from https://www.duet3d.com/ ?
                                droftarts administrators @Gixxerfast
                                @gixxerfast ah, so it is. I didn’t realise it was linked there. Oh well, thunder stolen, cat’s out of the bag etc!
                                Welcome to the new Duet3D documentation website! Be gentle, it’s not quite finished… (GCodes are back to being a single page, some will be happy to know!)
                                http://docs.duet3d.com/
                                PCRundefined 1 Reply Last reply Reply Quote 1
                                • PCRundefined
                                  PCR @droftarts
                                  @droftarts btw @oliof and i only found it by this issue
                                  https://github.com/prusa3d/PrusaSlicer/pull/7537 😉
                                  rsobik opened this pull request in prusa3d/PrusaSlicer
                                  open Remove deprecated use of M107 for RepRapFirmware #7537
                                    T3P3Tony administrators @daveh
                                    @daveh and others, thanks for reporting this. not sure what changed but it appears to be working for me again now. Please let me know if there is still an issue.
                                    Dave Parryundefined 1 Reply Last reply Reply Quote 0
                                      Dave Parry @T3P3Tony
                                      @t3p3tony Thanks Tony working for me now.
