    Time line for Duet 3 6XD
    Using Duet Controllers
    12
    16
    1.3k
    • tecnoundefined
      tecno
      When can I have a go with this board?
      Cheers
      Bengt
      ctilley79undefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
      • ctilley79undefined
        ctilley79 @tecno
        @tecno I’m unfamiliar with this board. Is this one with closed loop steppers?
        Nurgelrotundefined 1 Reply Last reply Reply Quote 0
        • Nurgelrotundefined
          Nurgelrot @ctilley79
          @ctilley79 It a new board under development. Basically a Duet3d 6 with step stick sockets instead of integrated stepper chips. Well all want to see it so we can see what other goodies it may have 🙂
          ctilley79undefined 1 Reply Last reply Reply Quote 0
            ctilley79 @Nurgelrot
            @nurgelrot Gotcha. Will they limit the number of supported stepper drivers? I can't imagine maintaining firmware for several different chips would be realistic.
              @ctilley79 No idea. You now know about as much as most of us do 🙂
              • JoergS5undefined
                JoergS5
                @ctilley79 if it's a 6 times 1XD board, then there is no stepper driver on board, but the board generated PUL/DIR/EN signals, and you need external drivers and steppers. This allows high current solutions (eg DM860) or servo usage (eg iHSV).
                  T3P3Tony administrators @tecno
                  @tecno We have prototypes under production. depending on how those go and how many changes we need to make we will then move it into production. Minimum of a couple of months from now before they are in production.
                  Initial documentation is here:
                  https://docs.duet3d.com/en/Duet3D_hardware/Duet_3_family/Duet_3_Mainboard_6XD_Hardware_Overview
                  Note there are a few things still to add.
                  JAundefined markzundefined 2 Replies Last reply Reply Quote 1
                  • JAundefined
                    JA @T3P3Tony
                    @t3p3tony Thank you for changing to usb C 🙂
                    • markzundefined
                      markz @T3P3Tony
                      @t3p3tony I have an existing CNC I'd love to swap out my Duet2 for the 6XD. Let us know when we can preorder : )
                      I do wish there was a nice dual-core processor you could use. RRF seems tailor-made for placing some of the motion into a core. Still, I'll take the bump to 300.
                        dc42 administrators @markz
                        @markz the motion computation has got a lot more complicated since we introduced input shaping and it now uses floating point arithmetic. So moving it into a core wouldn't be very practical.
                        The 300MHz processor is way faster than external drivers need, because external drivers can't handle step rates as high as the Trinamic drivers on other Duets.
                        markzundefined 1 Reply Last reply Reply Quote 0
                        • samlogan87undefined
                          samlogan87
                          This is very interesting. I am looking at building a router at some stage. Any chance of adding an analog output that is a bit more friendly for vsd’s like 4-20mA or 0-10v?
                          Custom Core-XY
                          elmoretundefined dc42undefined 2 Replies Last reply Reply Quote 0
                          • markzundefined
                            markz @dc42
                            @dc42 Fair enough. Thanks. I am looking forward to the board.
                            • elmoretundefined
                              elmoret @samlogan87
                              @samlogan87 said in Time line for Duet 3 6XD:
                              Super simple to convert PWM to either of those.
                                For controlling a VSD, an opto isolated interface is strongly recommended. That's most easily done using a PWM-to-voltage converter. See https://docs.duet3d.com/en/User_manual/Machine_configuration/Configuration_CNC#connecting-a-spindle.
                                • Phaedruxundefined Phaedrux referenced this topic
                                • cosengundefined
                                  coseng
                                  FYI, from @dc42 on 7/26/22:
                                  The first production 6XD boards are being shipped to resellers this week.
                                  Chris
                                  Cosentino Engineering
                                  DHM-onlineundefined 1 Reply Last reply Reply Quote 1
                                  • DHM-onlineundefined
                                    DHM-online @coseng
                                    @coseng Here it is! New restock on dhm-online.com
                                    Come and find your duet 3 new products: duet 3 6xd and more https://www.dhm-online.com/brand/14-duet3d
                                    Compass DHM projects
                                    Customer Care
                                    Email: info@dhm-online.com | Phone: +39 049 2701149 | Office hours: Mon - Fri 09.00 - 12.00 / 15.00 - 18.00 | Web-links: https://linktr.ee/DHM_online
