    Smart Effector issue
    Smart effector for delta printers
    10
    87
    4.2k
    • tecnoundefined
      tecno
      Running G29 I get sporadic triggers with no Z moving, is there a way to adjust the sensitivity?
      Triggers at H height
      Any suggestions?
      achrnundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • achrnundefined
        achrn @tecno
        @tecno https://duet3d.dozuki.com/Wiki/Smart_effector_and_carriage_adapters_for_delta_printer#Section_Programming_the_sensitivity
        However, if it's triggering with no movement, I'm not sure that setting sensitivity is the issue, since that would imply it's triggering with no mechanical input.
        tecnoundefined 1 Reply Last reply Reply Quote 0
        • tecnoundefined
          tecno @achrn
          I get no reaction to M672 command.
          Power up 2 flashes.
          Probe input on SKRV1.4T (3 wires)
            How are you running G29 without movement?
            Here is some more detail on using M672 https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m672-program-z-probe
            • Phaedruxundefined Phaedrux moved this topic from Duet Hardware and wiring
              dc42 administrators @tecno
              @tecno said in Smart Effector issue:
              Power up 2 flashes.
              M672 only works if there is also a command signal from the board to the Smart Effector, i.e. 4 wires.
              • tecnoundefined
                tecno @dc42
                Fixed 4 wires
                M672 S131:131 works OK with 5 flashes. Boot up 2 flashes
                But if I try M672 S105:070:255 = nothing Invalid Z probe index
                gloomyandyundefined 1 Reply Last reply Reply Quote 0
                • gloomyandyundefined
                  gloomyandy @tecno
                  M672 S105:070:255
                  That does not look like a valid command to me. See:
                  To program the sensor, send command M672 S105:aaa:bbb replacing aaa by the desired sensitivity and bbb by 255 - aaa. The green LED will flash 4 times if the command is accepted. When you subsequently power up the effector, the green LED will flash three times instead of twice to indicate that a custom sensitivity is being used.
                  So the 3rd value needs to be 255 minus the second value. In this case 255-70 = 185. What happens if you send: M672 S105:070:185?
                  • tecnoundefined
                    tecno @gloomyandy
                    @gloomyandy
                    • tecnoundefined
                      tecno @tecno
                      I get no where with this M672 sensitivity setting. Tried both P5 and P8 and up to 50:205 and I get sporadic jump overs.
                      Can this be my step setting?
                      M92 X80.00 Y80.00 Z80.00 E80.00
                        Is it triggering when the machine is idle, not moving?
                        If so, does it make a difference whether the hot end fan and/or print cooling fan are running?
                        • tecnoundefined
                          tecno @dc42
                          No fans active - no magnets on effector
                          G29 and tiggers on point where it should go down.
                          Tried now with higher µsteps
                          M92 X80.00 Y80.00 Z80.00 E80.00 ; set steps per mm
                          M350 X256 Y256 Z256 E16 I1 ; configure microstepping with interpolation
                          This gives much better result, but I think I need to adjust belts that sound to be cogging.
                          tecnoundefined dc42undefined 2 Replies Last reply Reply Quote 0
                          • tecnoundefined
                            tecno @tecno
                            Still sporadic trigging, need some rest to clear my head.
                            I noticed following. when homed and issuing G29 I can observe several triggs with LED flickering.
                            This even with 55:200.
                            Also I can see push-down of bed position from 12 to 4 in outer positions.
                            Something is fishy for sure.
                              @tecno please answer the first question in my previous post. Also tell us what M558 command you are using.
                              • tecnoundefined
                                tecno @dc42
                                @dc42 said in Smart Effector issue:
                                M558 P8 R0.4 C"probe+servo0" H15 F800 T1500
                                G29 and tiggers on point where it should go down. Idle = NO
                                rjenkinsgbundefined 1 Reply Last reply Reply Quote 0
                                • rjenkinsgbundefined
                                  rjenkinsgb @tecno
                                  @tecno What do you have in the probe G31 line?
                                  Robert J.
                                  Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
                                  • tecnoundefined
                                    tecno @rjenkinsgb
                                    @rjenkinsgb
                                    G31 P180 X0 Y0 Z-0.72
                                    • tecnoundefined
                                      tecno @tecno
                                      https://youtu.be/6YHxmoWgLI8
                                      M672 S131:131
                                      1/16th µstep Back to 'normal'
                                        rjenkinsgb @tecno
                                        @tecno OK; the Z-0.72 reminds me of the smart effector I got that was faulty...
                                        The other one is incredibly sensitive, I initially set it at -0.1 but to get a correct first layer it seems better at Z0.0 !
                                        That's with all default settings.
                                        DC42 is the authority on that, though; I'm just another Duet user.
                                        Robert J.
                                          Try reducing the probing Z acceleration, using M201.1 if you are running 3.4.0RC firmware, or M201 if not. High Z acceleration combined with a high mass hot end create the same strain in the effector at the start of the probing move as nozzle contact does.
                                          • tecnoundefined
                                            tecno @dc42
                                            M201 X1000.00 Y1000.00 Z400.00 E1000.00
                                            Slightly worse = more jump over points
