Smart Effector issue
How are you running G29 without movement?
Here is some more detail on using M672 https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m672-program-z-probe
undefined Phaedrux moved this topic from Duet Hardware and wiring
@tecno said in Smart Effector issue:
I get no reaction to M672 command.
Power up 2 flashes.
Probe input on SKRV1.4T (3 wires)
M672 only works if there is also a command signal from the board to the Smart Effector, i.e. 4 wires.
Fixed 4 wires
M672 S131:131 works OK with 5 flashes. Boot up 2 flashesBut if I try M672 S105:070:255 = nothing Invalid Z probe index
M672 S105:070:255
That does not look like a valid command to me. See:To program the sensor, send command M672 S105:aaa:bbb replacing aaa by the desired sensitivity and bbb by 255 - aaa. The green LED will flash 4 times if the command is accepted. When you subsequently power up the effector, the green LED will flash three times instead of twice to indicate that a custom sensitivity is being used.
So the 3rd value needs to be 255 minus the second value. In this case 255-70 = 185. What happens if you send: M672 S105:070:185?
I get no where with this M672 sensitivity setting. Tried both P5 and P8 and up to 50:205 and I get sporadic jump overs.
Can this be my step setting?
M92 X80.00 Y80.00 Z80.00 E80.00 -
Running G29 I get sporadic triggers with no Z moving, is there a way to adjust the sensitivity?
Triggers at H heightIs it triggering when the machine is idle, not moving?
If so, does it make a difference whether the hot end fan and/or print cooling fan are running?
No fans active - no magnets on effectorG29 and tiggers on point where it should go down.
Tried now with higher µsteps
M92 X80.00 Y80.00 Z80.00 E80.00 ; set steps per mm
M350 X256 Y256 Z256 E16 I1 ; configure microstepping with interpolationThis gives much better result, but I think I need to adjust belts that sound to be cogging.
Still sporadic trigging, need some rest to clear my head.
I noticed following. when homed and issuing G29 I can observe several triggs with LED flickering.
This even with 55:200.Also I can see push-down of bed position from 12 to 4 in outer positions.
Something is fishy for sure.
@tecno please answer the first question in my previous post. Also tell us what M558 command you are using.
@dc42 said in Smart Effector issue:
M558 P8 R0.4 C"probe+servo0" H15 F800 T1500
G29 and tiggers on point where it should go down. Idle = NO
@tecno What do you have in the probe G31 line?
G31 P180 X0 Y0 Z-0.72
M672 S131:131
1/16th µstep Back to 'normal' -
@tecno OK; the Z-0.72 reminds me of the smart effector I got that was faulty...
The other one is incredibly sensitive, I initially set it at -0.1 but to get a correct first layer it seems better at Z0.0 !
That's with all default settings.DC42 is the authority on that, though; I'm just another Duet user.
Try reducing the probing Z acceleration, using M201.1 if you are running 3.4.0RC firmware, or M201 if not. High Z acceleration combined with a high mass hot end create the same strain in the effector at the start of the probing move as nozzle contact does.
M201 X1000.00 Y1000.00 Z400.00 E1000.00Slightly worse = more jump over points
@tecno try even lower, e.g. 100.
Also, if the green LED flashes at the end of the XY travel move rather than at the start of the probing move, increase the M558 R parameter.
R1 or R2 Still same problem
No problems with fan shroud taken off.
