    Smart Effector issue
    Smart effector for delta printers
    10
    87
    4.4k
    • achrnundefined
      achrn @tecno
      @tecno https://duet3d.dozuki.com/Wiki/Smart_effector_and_carriage_adapters_for_delta_printer#Section_Programming_the_sensitivity
      However, if it's triggering with no movement, I'm not sure that setting sensitivity is the issue, since that would imply it's triggering with no mechanical input.
      tecnoundefined 1 Reply Last reply Reply Quote 0
      • tecnoundefined
        tecno @achrn
        I get no reaction to M672 command.
        Power up 2 flashes.
        Probe input on SKRV1.4T (3 wires)
          How are you running G29 without movement?
          Here is some more detail on using M672 https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m672-program-z-probe
          • Phaedruxundefined Phaedrux moved this topic from Duet Hardware and wiring
            dc42 administrators @tecno
            @tecno said in Smart Effector issue:
            Power up 2 flashes.
            M672 only works if there is also a command signal from the board to the Smart Effector, i.e. 4 wires.
            • tecnoundefined
              tecno @dc42
              Fixed 4 wires
              M672 S131:131 works OK with 5 flashes. Boot up 2 flashes
              But if I try M672 S105:070:255 = nothing Invalid Z probe index
              gloomyandyundefined 1 Reply Last reply Reply Quote 0
              • gloomyandyundefined
                gloomyandy @tecno
                M672 S105:070:255
                That does not look like a valid command to me. See:
                To program the sensor, send command M672 S105:aaa:bbb replacing aaa by the desired sensitivity and bbb by 255 - aaa. The green LED will flash 4 times if the command is accepted. When you subsequently power up the effector, the green LED will flash three times instead of twice to indicate that a custom sensitivity is being used.
                So the 3rd value needs to be 255 minus the second value. In this case 255-70 = 185. What happens if you send: M672 S105:070:185?
                • tecnoundefined
                  tecno @gloomyandy
                  @gloomyandy
                  • tecnoundefined
                    tecno @tecno
                    I get no where with this M672 sensitivity setting. Tried both P5 and P8 and up to 50:205 and I get sporadic jump overs.
                    Can this be my step setting?
                    M92 X80.00 Y80.00 Z80.00 E80.00
                      Running G29 I get sporadic triggers with no Z moving, is there a way to adjust the sensitivity?
                      Triggers at H height
                      Is it triggering when the machine is idle, not moving?
                      If so, does it make a difference whether the hot end fan and/or print cooling fan are running?
                      • tecnoundefined
                        tecno @dc42
                        No fans active - no magnets on effector
                        G29 and tiggers on point where it should go down.
                        Tried now with higher µsteps
                        M92 X80.00 Y80.00 Z80.00 E80.00 ; set steps per mm
                        M350 X256 Y256 Z256 E16 I1 ; configure microstepping with interpolation
                        This gives much better result, but I think I need to adjust belts that sound to be cogging.
                        tecnoundefined dc42undefined 2 Replies Last reply Reply Quote 0
                        • tecnoundefined
                          tecno @tecno
                          Still sporadic trigging, need some rest to clear my head.
                          I noticed following. when homed and issuing G29 I can observe several triggs with LED flickering.
                          This even with 55:200.
                          Also I can see push-down of bed position from 12 to 4 in outer positions.
                          Something is fishy for sure.
                            @tecno please answer the first question in my previous post. Also tell us what M558 command you are using.
                            • tecnoundefined
                              tecno @dc42
                              @dc42 said in Smart Effector issue:
                              M558 P8 R0.4 C"probe+servo0" H15 F800 T1500
                              G29 and tiggers on point where it should go down. Idle = NO
                              rjenkinsgbundefined 1 Reply Last reply Reply Quote 0
                              • rjenkinsgbundefined
                                rjenkinsgb @tecno
                                @tecno What do you have in the probe G31 line?
                                Robert J.
                                Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
                                • tecnoundefined
                                  tecno @rjenkinsgb
                                  @rjenkinsgb
                                  G31 P180 X0 Y0 Z-0.72
                                  • tecnoundefined
                                    tecno @tecno
                                    https://youtu.be/6YHxmoWgLI8
                                    M672 S131:131
                                    1/16th µstep Back to 'normal'
                                      rjenkinsgb @tecno
                                      @tecno OK; the Z-0.72 reminds me of the smart effector I got that was faulty...
                                      The other one is incredibly sensitive, I initially set it at -0.1 but to get a correct first layer it seems better at Z0.0 !
                                      That's with all default settings.
                                      DC42 is the authority on that, though; I'm just another Duet user.
                                      Robert J.
                                        Try reducing the probing Z acceleration, using M201.1 if you are running 3.4.0RC firmware, or M201 if not. High Z acceleration combined with a high mass hot end create the same strain in the effector at the start of the probing move as nozzle contact does.
                                        • tecnoundefined
                                          tecno @dc42
                                          M201 X1000.00 Y1000.00 Z400.00 E1000.00
                                          Slightly worse = more jump over points
                                            @tecno try even lower, e.g. 100.
                                            Also, if the green LED flashes at the end of the XY travel move rather than at the start of the probing move, increase the M558 R parameter.
