    RRF 3.4 Beta 7 | Tool-Offsets Issue
    21
    1.3k
    • CR3Dundefined
      CR3D @oliof
      Unfortunately, the issue has not yet been resolved with 3.4 (stable).
      Up to version 3.4 beta 4 everything worked.
      I noticed the error for the first time in beta 6 and now again with 3.4.
      We made a video to show it again.
      After downgrading from 3.4 to 3.4 beta 4 everything worked as expected.
      There must be a bug in one of the versions!
      Video:
      https://we.tl/t-9OXBVcGegW
      Christian from CR-3D
      Homepage:
      www.cr-3d.de
      Facebook:
      https://www.facebook.com/cr3d.official
      Our Discord Server
      https://discord.gg/SxRaPNuRdA
      Thingiverse Profile:
      https://www.thingiverse.com/cr-3d_official/about
      • CR3Dundefined CR3D referenced this topic
        dc42 administrators @CR3D
        @cr3d did you read this item from the RRF 3.4 upgrade notes:
        • After changing tool, RRF no longer moves the new tool head to the coordinates at which the old tool head was at when the Tn command was actioned. In most situations this should not matter, because GCode generators usually generate commands to move to the correct XYZ position after generating a Tn command. Usually, they restore XY before Z. However, Cura does it the other way round, which risks dragging the tool head across the print. Therefore when using Cura, or in any other situations in which you want to restore the old behaviour, we suggest you add command G1 R2 X0 Y0 Z2 Fxxx followed by G1 R2 Z0 Fxxx to the end of your tpost#.g files, if you don't already use those or similar commands.
        CR3Dundefined 2 Replies Last reply Reply Quote 1
        • CR3Dundefined
          CR3D @dc42
          @dc42 ok thank you!
          I overread this section... in this printer series we tested it today there wasnยดt this section in the tpost.g
          if that was the solution, i take everything back and claim the opposite!
          Thank you for your prompt reply ๐Ÿ™‚
          Regards Christian
          Homepage:
          www.cr-3d.de
          Facebook:
          Our Discord Server
          sonderzugundefined 1 Reply Last reply Reply Quote 2
          • sonderzugundefined
            sonderzug @CR3D
            @cr3d
            Hi Christian,
            one thing that came to my mind, which you might want to check - are you using firmware retraction and different z-hop heights in M207? This seems to be a problem with my setup (E3D Toolchanger), especially when trying to use G10/G11 as a retract/unretract move at tool change.
            I have to say though that my machine is still running at an older 2.x version of RRF, so I'm not sure what might have changed, especially in regards to the behaviour of RRF 3.4 and onwards like David posted before.
            best, Niklas
            • CR3Dundefined
              CR3D @dc42
              @dc42 said in RRF 3.4 Beta 7 | Tool-Offsets Issue:
              Sorry @dc42 DC42 that I still have to take up the topic, but what you claim here is simply not the case! The whole topic always worked without any problems before the update and since the update the new tool has moved exactly to the old position! This leads to many collisions and should be restored to the way it was before as soon as possible.
              The required command is in tpost.g.
              ;wait for tool 1 heaters to reach operating temperature
              M116 P1 S5
              ;go to
              G1 X328 Y65 F50000
              ;unretract
              G11
              ;clean
              M98 P"clean1.g"
              ;PCF fan on
              M106 R2
              G1 R2 X0 Y0 Z2    ; restore position 2mm above
              G1 R2 X0 Y0 Z0    ; restore position
              In the pictures you can see the left tool in front of the tool change to X=0mm and the right one in park position.
              After the tool change, T1 (because it moves to the old position of T0) crashes into T0.
              He also makes unnecessary movements during the print. The principle may work for tool changers, but not for IDEX printers.
              It works so far, even if the print head is always somehow in the middle of the print bed before the tool change. But it often happens that this is also in the extreme positions and then there is a crash.
              Please help or a solution.
              As I said before all the changes, everything was perfect and it worked. ๐Ÿ™‚
              Homepage:
              www.cr-3d.de
              Facebook:
              Our Discord Server
              CR3Dundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
              • CR3Dundefined
                CR3D @CR3D
                @dc42 any idea or better a solution for this? ๐Ÿ™‚
                Homepage:
                www.cr-3d.de
                Facebook:
                Our Discord Server
                  T3P3Tony administrators @CR3D
                  @cr3d said in RRF 3.4 Beta 7 | Tool-Offsets Issue:
                  By having this command you are moving the T1 to the position of T0 before the tool change was commanded. I think that's not what you want to do if you are first parking T0 using some gcode in the print file, and then commanding the tool change.
                  is that what is happening? It would be good to share part of a gcode file you are printing along with all the tool change macros so we can understand what behaviour is happening in more detail.
                  CR3Dundefined 1 Reply Last reply Reply Quote 0
                  • CR3Dundefined
                    CR3D @T3P3Tony
                    @t3p3tony Thank you for your Answer!
                    The command was just integrated because it was prescribed in the change log that it should now be used like this.
                    Basically, we've used it before because it's good to move over the component first and then lower Z when changing tools.
                    As I said, it just doesn't work anymore since the update!
                    No Gcode is necessary at all, this also happens if you last had the tool far outside and after the tool change the print head wants to go back to the old position and then crashes.
                    Homepage:
                    www.cr-3d.de
                    Facebook:
                    Our Discord Server
                    T3P3Tonyundefined dc42undefined 2 Replies Last reply Reply Quote 0
                      yes, this is the purpose of the G1 R2 command so in that sense its working as intended - returning the tool head to the position of the previous tool. If you remove the G1 R2 commands from the print Tool change file, what happens?
                        @cr3d I am reviewing your thread. You have reported two different issues:
                        1. The tool not being at the correct height after a tool change, when the tools have different Z offsets; and later:
                        2. Tools crashing into each other during a tool change.
                        In order that I can make progress, please provide:
                        1. Your complete config,g file
                        2. Your complete tool change files, and any macro files that they invoke;
                        3. The GCode file you are trying to print (at least up to and including the first few tool changes);
                        4. A description of what the issue(s) that you have at present, using firmware 3.4.2rc3.
                        • CR3Dundefined
                          CR3D @dc42
                          I will make a new documaetation with the newest Firmware tomorrow.
                          The issue with the incorrect height after the tool change was fixed from you!
                          The only problem is the handling of the tool position (old position of the previous tool) after the toolchange... this is not working.
                          Homepage:
                          www.cr-3d.de
                          Facebook:
                          Our Discord Server
                          dc42undefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                            @cr3d if it's just the height that needs to be corrected after a tool change to allow for the new tool Z offset, then you could use just G1 R2 Z0 at the end of the tpost file so that X and Y are not moved. This should be sufficient if the slicer always generates a travel move after the T command and before the first extruding move.
                              @cr3d does the slicer always generate a travel move to the new tool start position after the tool change command? If so then please see if DC42s solution works.
                              • VoodooBaneundefined
                                VoodooBane
                                So I am having this issue of the u-axis not having the same Z-height on the X axis .. this is assumed by the T1(the second extruder) not laying down a layer...
                                My bed is pretty darn flat. I have both of my Z-axis rods independent and I have them auto tram...
                                I figured out that for Slic3r (any kind of Slic3r fork) with RepRap firmware the retractions, Z-lift values, and speeds NEED to be in the setup in RRF firmware, and all of the settings need to be disabled in Slic3r. I do not know how I found this out.
                                Source: https://blog.prusa3d.com/slic3r-and-marlin-configuration-for-reprap-firmware-retraction-2_3686/
                                I am running a V-cast 1.5 please see the link: https://myhub.autodesk360.com/ue2a0f85b/g/shares/SH35dfcQT936092f0e43f11e68d181475a37
                                The only difference to that model is that I am running a different extruder and hot-end.
                                Can anyone help me with this problem and find a solution? It seems no one has found a fix or what they did to fix it.
                                All my .config files are attached; please tell me if you see something wrong.
                                bed.g
                                config.g
                                homeall.g
                                homeu.g
                                homex.g
                                homey.g
                                homez.g
                                  VoodooBane
                                  Also here are my tool files;
                                  tfree0.g
                                  tfree1.g
                                  tpost0.g
                                  tpost1.g
                                  tpre0.g
                                  tpre1.g
                                    jay_s_uk @VoodooBane
                                    @VoodooBane you're best off starting a new thread rather than hijacking someone elses
                                    VoodooBaneundefined 1 Reply Last reply Reply Quote 0
                                      VoodooBane @jay_s_uk
                                      @jay_s_uk Ah yes will do. My mistake. Did mean to hijack anything..lol I will start a new thread. Sorry about that.
                                      sebkritikelundefined 1 Reply Last reply Reply Quote 1
                                      • sebkritikelundefined
                                        sebkritikel @VoodooBane
                                        @VoodooBane said in RRF 3.4 Beta 7 | Tool-Offsets Issue:
                                        If you get a chance to make a new thread, please upload a sample gcode file. I haven't been able to reproduce the issues described by @CR3D on my IDEX machine.
                                        Large(ish?) IDEX - 6HC, 1HCL
                                        Stratasys Dimension 1200es to 6HC Conversion
                                        VoodooBaneundefined 1 Reply Last reply Reply Quote 1
                                          VoodooBane @sebkritikel
                                          @sebkritikel I actually figured it out... lol I was doing a negative value on my T1 z-offset. But I changed, I got rid of the negative sign on the Z offset. it is working now. the layers are going down now.
                                          Only wish I could use a fork of slic3r that allowed you to adjust the z-hop, z-retration, etc in the slicer itself instead of the firmware.
