    Duet 3 3HC CAD Model Request
    17
    1.2k
    • kroybalundefined
      kroybal
      Also interested in CAD model, any luck?
      Nuramoriundefined 1 Reply Last reply Reply Quote 0
      • Nuramoriundefined
        Nuramori @kroybal
        This post is deleted!
          T3P3Tony administrators
          I have added a link on the documentation page to the file hosted on github:
          https://duet3d.dozuki.com/Wiki/Duet_3_Expansion_Hardware_Overview#Section_3D_Model
          Phil Maddoxundefined 1 Reply Last reply Reply Quote 2
          • Phil Maddoxundefined
            Phil Maddox @T3P3Tony
            @T3P3Tony Sorry but the file wont open/ import in either F360 or Autodesk Inventor (2016)
            DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
            • DIY-O-Sphereundefined
              DIY-O-Sphere @Phil Maddox
              @Phil-Maddox
              Right click "View raw"
              Then perform" Save as"
              It's a little bit tricky to download a single file on Github.....
              (UTC+1)
              Dizzwoldundefined 1 Reply Last reply Reply Quote 0
              • Dizzwoldundefined
                Dizzwold @DIY-O-Sphere
                @DIY-O-Sphere
                Any ideas on have to download it on a mac?
                • infiniteloopundefined
                  infiniteloop @Dizzwold
                  @Dizzwold
                  As described above. Use the link provided by @T3P3Tony, follow the link "3HC STEP File on github", there, use the context menu with a right click as @DIY-O-Sphere illustrates with his screenshot. You then might be asked whether you want to permit downloads from GitHub. You then will find the file "Duet3_Exp_3HC.step.txt" in your "Downloads" folder where you need to remove the second extension (".txt") from the file name. Finally, you need an app which can handle the .step file …
                  • Dizzwoldundefined
                    Dizzwold @infiniteloop
                    @infiniteloop
                    Thank you for confirming what I'd already tried.
                    It would seem my problem lies with Fusion from the following;
                      @Dizzwold said in Duet 3 3HC CAD Model Request:
                      Well, in the meantime, I tried further: removing the .txt file type seemed to work in Finder, but the extension reappeared after editing. Use the file info dialog for that.
                      I don't use Fusion but FreeCad - after I had really renamed the file, I could import it without problems:
                      • Dizzwoldundefined
                        @infiniteloop
                        The 6hc link comes up with 404 missing.
                        https://github.com/Duet3D/Duet3-Mainboard-6HC/tree/master/Duet3_Mainboard_v1.0
                        Are there any new links?
                          Phaedrux Moderator @Dizzwold
                          @Dizzwold https://github.com/Duet3D/Duet3-Mainboard-6HC/tree/master/Duet3_Mainboard_6HC_v1.0
                          URL just changed to add 6HC
                          Dizzwoldundefined 1 Reply Last reply Reply Quote 1
                          • Dizzwoldundefined
                            Dizzwold @Phaedrux
                            @Phaedrux @infiniteloop @DIY-O-Sphere
                            Thank you guys, Got it now.
                            • dc42undefined dc42 marked this topic as a question
                            • dc42undefined dc42 has marked this topic as solved
