    Feature Request - workpiece angle compensation CNC
    Firmware wishlist
    11
    54
    2.9k
    • CanDo415undefined
      CanDo415
      "Error: in file macro line 37 column 12: meta command: unknown variable 'var'"
      is the new result after updating to 3.5.1
      var y_first_measurement = 0
      var y_second_measurement = 0
      var y_length = 0
      var x_first_measurement = 0
      var x_second_measurement = 0
      var x_length = 0
      var y_over_x = 0
      var y_x_tan_rads = 0
      var y_x_tan_deg = 0
      M291 P"Probe links vor das Werstück positionieren" S2 X1 Y1 Z1					; Pop up box asking for operator input
      M558 F1500																		; Set the initial probing speed
      G38.2 Y600 P0 K0																	; Probe the material as a first pass
      G1 Y{move.axes[1].machinePosition-5}											; Move 5mm away from the material
      M558 F150																		; Set the final probing speed
      G38.2 Y600 P0 K0																	; Probe the material again
      M400																			; Make sure all movement is complete
      set var.y_first_measurement=move.axes[1].machinePosition						; Record the stop position y_first_measurement
      set var.x_first_measurement=move.axes[0].machinePosition						; Record the stop position x_first_measurement
      M400																			; Make sure all data recording is complete
      G1 Y{move.axes[1].machinePosition-10}											; Move 5mm away from the material
      G1 X{move.axes[0].machinePosition+50}											; Move along the workpiece in X
      set var.y_second_measurement=move.axes[1].machinePosition						; Record the stop position y_second_measurement
      set var.x_second_measurement=move.axes[0].machinePosition						; Record the stop position x_second_measurement
      set var.y_length={var.y_second_measurement-var.y_first_measurement}
      set var.x_length={var.x_second_measurement-var.x_first_measurement}
      set var.y_over_x={var.y_length/var.x_length}
      set var.y_x_tan_rads=atan(var.y_over_x)
      set var.var y_x_tan_rads=degrees{var.y_x_tan_rads}
      G68 A0 B0 R{var.y_x_tan_rads}
      jay_s_ukundefined droftartsundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @CanDo415
        @CanDo415 i have a mistake in my macro. i have corrected my original
        CanDo415undefined 1 Reply Last reply Reply Quote 0
        • CanDo415undefined
          CanDo415 @jay_s_uk
          @jay_s_uk
          @Phaedrux
          Error: line 37 column 22: meta command: unknown value 'degrees'
          there seems to be a bit more
            jay_s_uk @CanDo415
            @CanDo415 i've made another change but I don't think its going to fix the issue.
            I don't know why "degrees" throws an error though as its a built in command
            CanDo415undefined OwenDundefined 2 Replies Last reply Reply Quote 0
            • CanDo415undefined
              CanDo415 @jay_s_uk
              that's why i added Phaedrux.
              I want to change it a bit to get the corner as well. so the degrees issue has to be solved anyway.
              Thanks for the great start jay
              • CanDo415undefined
                CanDo415 @CanDo415
                maybe he can help?
                  droftarts administrators @CanDo415
                  @CanDo415 @jay_s_uk
                  There's a space in the variable name, ie var.var y_x_tan_rads isn't a valid variable name.
                  • CanDo415undefined
                    CanDo415 @droftarts
                    @droftarts
                    jay corrected it already.
                    the problem shifted to the degrees command
                    • OwenDundefined
                      OwenD @jay_s_uk
                      @jay_s_uk said in Feature Request - workpiece angle compensation CNC:
                      degrees() is a function
                      You've used curly braces instead of parentheses
                      set var.y_x_tan_deg=degrees{var.y_x_tan_rads}
                      try
                      set var.y_x_tan_deg=degrees(var.y_x_tan_rads)
                      jay_s_ukundefined CanDo415undefined 2 Replies Last reply Reply Quote 2
                        jay_s_uk @OwenD
                        @OwenD i knew it would be something about the way its been formatted
                        updated the original again
                        • CanDo415undefined
                          CanDo415 @OwenD
                          @OwenD
                          thank you for showing up the problem
                          • CanDo415undefined
                            CanDo415 @CanDo415
                            G68 A0 B0 R{-var.y_x_tan_rads}
                            the "-" seems important. otherwise the system gets turned the wrong way round
                            • CanDo415undefined
                              CanDo415 @CanDo415
                              @jay_s_uk
                              i modified it quite a bit. some points are still not ready.
                              I'm not shure how to ent the if passage.
                              end if seems not to work
                              var y_1 = 0
                              var x_1 = 0
                              var x_2 = 0
                              var x_3 = 0
                              var x_4 = 0
                              var x_5 = 0
                              var delta_x = 0
                              var y_2 = 0
                              var y_3 = 0
                              var y_4 = 0
                              var y_5 = 0
                              var delta_y = 0
                              var z0 = 0
                              var d_probe = 0
                              var m_1 = 0
                              var m_2 = 0
                              var m_1_tan_rads = 0
                              var m_1_tan_deg = 0
                              M291 P"position probe over front left corner of workpiece" S2 X1 Y1 Z1	; Pop up box asking for operator input
                              M558 F300																		; Set the initial probing speed
                              G38.2 Z-60 P0 K0																; Probe the material as a first pass
                              M558 F50																		; Set the final probing speed
                              G38.4 Z50 P0 K0        ; Move away from workpiece in Z
                              set var.z0=move.axes[2].machinePosition	                			    		                ; Record the stop position y_first_measurement
                              G1 Z{move.axes[2].machinePosition+5}										; Move along the workpiece in X
                              G1 X{move.axes[0].machinePosition-20}										; Move 5mm away from the material
                              G1 Y{move.axes[1].machinePosition+5}										; Move 5mm away from the material
                              G1 Z{move.axes[2].machinePosition-3}											; Move along the workpiece in X
                              M558 F1000																		; Set the initial probing speed
                              G38.2 X100 P0 K0																; Probe the material as a first pass
                              G38.4 X-10 P0 K0        ; Move away from workpiece in X
                              set var.y_1=move.axes[1].machinePosition							    		        ; Record the stop position y_first_measurement
                              set var.x_1=move.axes[0].machinePosition							    		        ; Record the stop position x_first_measurement
                              G1 X{move.axes[0].machinePosition-5}											; Move 5mm away from the material
                              G1 Z{move.axes[2].machinePosition+10}										; Move along the workpiece in X
                              G1 X{move.axes[0].machinePosition+15}										; Move 5mm away from the material
                              G1 Y{move.axes[1].machinePosition-20}										; Move 5mm away from the material
                              G1 Z{move.axes[2].machinePosition}	    										; Move along the workpiece in X
                              G38.2 Y100 P0 K0																; Probe the material as a first pass
                              G38.4 Y-10 P0 K0															        ; Probe the material again
                              set var.y_2=move.axes[1].machinePosition								    	        ; Record the stop position y_first_measurement
                              set var.x_2=move.axes[0].machinePosition					    				        ; Record the stop position x_first_measurement
                              G1 Y{move.axes[1].machinePosition-50}										; Move 5mm away from the material
                              set var.y_3=move.axes[1].machinePosition								    	        ; Record the stop position y_second_measurement
                              set var.x_3=move.axes[0].machinePosition								    	        ; Record the stop position x_second_measurement
                              M291 P"Probe Diameter" R"enter diameter of probe" S5 L0 H10			; Pop up box asking for operator input diameter of
                              set var.d_probe=input															; set the diameter of the probe
                              ;calculation
                              set var.delta_y={var.y_3-var.y_2}
                              set var.delta_x={var.x_3-var.x_2}
                              set var.m_1={var.delta_y/var.delta_x}											; m of the staight P2-P3
                              set var.m_2={(-var.delta_x)/var.delta_y}										        ; m of perpendicilar to straight P2-P3
                              set var.m_1_tan_rads=atan(var.m_1)
                              set var.m_1_tan_deg=degrees(var.m_1_tan_rads)
                              ;calc the corner of workpeace
                              set var.x_4=((var.y_1-(-(var.x_3-var.x_2)/(var.y_3-var.y_2))*var.x_1)-(var.y_2-((var.y_3-var.y_2)/(var.x_3-var.x_2)*var.x_2)))/(((var.y_3-var.y_2)/(var.x_3-var.x_2))-(-(var.x_3-var.x_2)/(var.y_3-var.y_2)))
                              set var.y_4=(-(var.x_3-var.x_2)/(var.y_3-var.y_2))*((var.y_1-(-(var.x_3-var.x_2)/(var.y_3-var.y_2))*var.x_1)-(var.y_2-((var.y_3-var.y_2)/(var.x_3-var.x_2)*var.x_2)))/(((var.y_3-var.y_2)/(var.x_3-var.x_2))-(-(var.x_3-var.x_2)/(var.y_3-var.y_2)))+(var.y_1-(-(var.x_3-var.x_2)/(var.y_3-var.y_2))*var.x_1)
                              If var.y_2>var.y_3																; workpiece Zero coordinates
                              set var.x_5=var.x_4+(COS(ARCTAN(var.m_1))+COS(ARCTAN(var.m_2)))*var.d_probe/2
                              set var.y_5=var.y_4+(SIN(ARCTAN(var.m_1))+SIN(ARCTAN(var.m_2)))*var.d_probe/2
                              If var.y_2<var.y_3
                              set var.x_5=var.x_4+(COS(ARCTAN(var.m_1))-COS(ARCTAN(var.m_2)))*var.d_probe/2
                              set var.y_5=var.y_4+(SIN(ARCTAN(var.m_1))-SIN(ARCTAN(var.m_2)))*var.d_probe/2
                              ;move over workpiece zero and set tool x&y to 0
                              G1 Y{move.axes[1].machinePosition-1}											        ; Move 1mm away from the material
                              G1 Z{move.axes[2].machinePosition+10}											; Move above workpiece
                              ;G68 A0 B0 R{-var.m_1_tan_deg}        ; set Rotation
                              Exerqtorundefined 1 Reply Last reply Reply Quote 0
                              • Exerqtorundefined
                                Exerqtor @CanDo415
                                @CanDo415
                                You have to indent the lines you want to be part of the conditional statement, thats a place to start at least.
                                • CanDo415undefined
                                  CanDo415 @Exerqtor
                                  @Exerqtor
                                  like:
                                  end if
                                  If var.y_2<var.y_3
                                  end if
                                  Exerqtorundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                  • Exerqtorundefined
                                    Exerqtor @CanDo415
                                    @CanDo415
                                    No like:
                                    if var.y_2 > var.y_3																; workpiece Zero coordinates
                                      set var.x_5 = var.x_4 + (COS(ARCTAN(var.m_1)) + COS(ARCTAN(var.m_2))) * var.d_probe / 2
                                      set var.y_5 = var.y_4 + (SIN(ARCTAN(var.m_1)) + SIN(ARCTAN(var.m_2))) * var.d_probe / 2
                                    if var.y_2 < var.y_3
                                      set var.x_5 = var.x_4 + (COS(ARCTAN(var.m_1)) - COS(ARCTAN(var.m_2))) * var.d_probe / 2
                                      set var.y_5 = var.y_4 + (SIN(ARCTAN(var.m_1)) - SIN(ARCTAN(var.m_2))) * var.d_probe / 2
                                    • CanDo415undefined
                                      CanDo415 @Exerqtor
                                      @Exerqtor
                                      i tried this before in another case... everything unter the 2nd if wasnt done if the if doesn't match.
                                      the problem of the missing end if
                                      Exerqtorundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                                      • Exerqtorundefined
                                        Exerqtor @CanDo415
                                        @CanDo415
                                        Then you simply must have done something wrong in the other case you're mentioning.
                                        As reference to conditional construct have look at this.
                                          jay_s_uk @CanDo415
                                          @CanDo415 as @Exerqtor said, there's no end if.
                                          Things have to be indented to be part of the if
                                            dc42 administrators @CanDo415
                                            @CanDo415 you also need to replace SIN by sin, COS by cos, ARCTAN by atan etc. See https://docs.duet3d.com/User_manual/Reference/Gcode_meta_commands#functions.
                                            CanDo415undefined 1 Reply Last reply Reply Quote 1
