    Duet3 + SBC (Timeout while waiting for transfer ready pin)
    1.1k
      droftarts administrators @Polyneutron21
      @Polyneutron21 Did you remove the SD card from the 6HC? It won't be running in SBC mode if it is still in the 6HC. In our experience, most "Timeout while waiting for transfer ready pin" issues are caused by interference on the ribbon cable; see https://docs.duet3d.com/en/User_manual/Machine_configuration/SBC_setup#warning-lost-connection-to-duet-timeout-while-waiting-for-transfer-ready-pin-error
      You appear to have a stepper driver cable running pretty close to the ribbon cable.
      If you have a second Raspberry Pi, I'd also test with that, in case it's an issue with the RPi rather than the Duet. Also worth checking the 6HC functionality by setting it up in Standalone mode, if possible.
      Polyneutron21undefined 1 Reply Last reply Reply Quote 0
      • Polyneutron21undefined
        Polyneutron21 @droftarts
        @droftarts I did remove the 16GB micro SD but this did not resolve the "Timeout waiting for transfer pin" and I have two Pi 5's and have tried both. The one dedicated to the SBC roll used to work fine. I took the Pi5 off the display and tried that one with a fresh image but that didn't work either. I also have two 24-40 pin cables and neither of those make a difference.
          Polyneutron21 @Polyneutron21
          @Polyneutron21 I looked at the contents of the Micro SD that came with the 6HC and put it back into the 6HC then connected to the ethernet and only the red and green lights are on but I don't see any communication through the router. Do I need a jumper or something to tell it to go to stand alone mode?
            @Polyneutron21 Has the 6HC ever communicated with the RPi? If not, probably bench testing the 6HC and a Pi would be a good idea, ie with nothing else plugged in apart from power and the ribbon cable between them.
            What firmware version is on the 6HC, and have you updated the DuetPi? I believe there were some issues initially with RPi 5 support (@chrishamm will know better). To update see https://docs.duet3d.com/en/User_manual/Machine_configuration/SBC_setup#update-firmware
            There is also a newer RPi image, see https://forum.duet3d.com/topic/37011/duetpi-bookworm-2024-11-27-now-available, it may be worth trying that.
            No, just the SD card in the 6HC SD socket. You also need correct command to enable networking in config.g - M552 S1 P0.0.0.0, or send it via a USB connection using YAT. You may need to have the correct version of DWC on the SD card, to match the firmware version.
              @droftarts I just shh into Pi and updated to version 3.5.4 and still waiting for transfer PIN. I will take out the Pi5 again and then put the card in and follow the instructions on getting it to stand alone. What is the point of all this. I think it is time to move past duet.
              jay_s_ukundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                jay_s_uk @Polyneutron21
                @Polyneutron21 good luck with klipper!
                Probably best to sort out your wiring as suggested rather than complaining something doesn't work
                Polyneutron21undefined 1 Reply Last reply Reply Quote 1
                  Phaedrux Moderator @Polyneutron21
                  @Polyneutron21 said in Duet3 + SBC (Timeout while waiting for transfer ready pin):
                  That may be a good question actually. Is there something you require the Pi for, rather than just standalone mode?
                    Polyneutron21 @Phaedrux
                    @Phaedrux I would rather use SBC mode. if I cannot get the SBC mode straight, there is little to no point. I have Two Manta M8P with integrated CM4 with 8 gb memory and 16GB EMMC and I had klipper on the emmc for years. CanFD was the clear choice as Can was too flakey. I still have a couple EBB36 tool boards but UUID's kept getting lost.
                      Polyneutron21 @jay_s_uk
                      @jay_s_uk I took it out of the printer, connected it to a 24 VDC power supply and the pi to the computer with the USBC and the 24-40 pin cables. The wiring could not be simpler yet there was no change. I updated the firmware in the Pi 5 to 3.5.4 but the transfer pin faulted there as well. The update did finish.
                      Then I took it all down to pieces and used only the microSD card that came with the board and a USBC cable to the computer and the computer doesn't see it and the device manager doesn't have it.
                        @Polyneutron21 maybe you need to flash the board with firmware then. Best look at bossa recovery for the board you have
                          @jay_s_uk Okay I used Bosa to flash the 6HC with the newest firmware. Neither Pi 5 would connect without the error. I purchased a new Raspberry Pi 4B it arrived today. I burned the newest Duet Web control to the Duet microSD card using the raspberry pi imager. Then I connected the 24 pin plug to the mainboard and the 40 Pin GPIO on the pi SBC. I inserted the new image. Used a PSU to supply power to the Pi and a 24V PSU to power the 6HC mainboard. It booted up, tried to connect and "waiting for transfer pin" error again. I have not been able to connect this board without the waiting for transfer pin satisfied.
                            @Polyneutron21 you have the cable connected incorrectly to the pi...
                            Polyneutron21undefined 1 Reply Last reply Reply Quote 2
                              droftarts administrators @andywm
                              @andywm said in Duet3 + SBC (Timeout while waiting for transfer ready pin):
                              Hello, I need help troubleshooting this issue;
                              A few months ago, I converted one of my machines to use an SBC mode Duet3 6HC. The machine now randomly halts. DWC will report status=disconnected. And this warning will be in the console;
                              "Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin"
                              Sorry for not replying to your initial post, not sure how I missed it. Generally, intermittent timeout issues are due to interference. There is some troubleshooting advice in the documentation here: https://docs.duet3d.com/en/User_manual/Machine_configuration/SBC_setup#warning-lost-connection-to-duet-timeout-while-waiting-for-transfer-ready-pin-error
                              andywmundefined 1 Reply Last reply Reply Quote 0
                                @jay_s_uk You are correct, I re-connected all of it correctly and nothing changed. First time for everything. I have tried two different pi 5's and two different 26 pin to 40 pin GPIO and this was a new Pi 4B 8GB.
                                  @Polyneutron21 take the SD card out of the 6HC...
                                    @jay_s_uk SD card is out. Cables are correct. Shh in and updated software. Still incomplete connection as it is waiting for the transfer pin.20250313_121039[1].jpg
                                    elmoretundefined 1 Reply Last reply Reply Quote 0
                                    • elmoretundefined
                                      elmoret @Polyneutron21
                                      @Polyneutron21 Had a chance to troubleshoot your 6HC return today. First tests did confirm the transfer ready pin error, but then I noted that the erase jumper was left on the pins, continuously erasing the firmware. I took a close look at the photos you posted to the forum, and I can see the erase jumper was installed then, too:
                                      I removed the erase jumper, flashed the firmware with Bossa, and tested the board - it works fine:
                                      1 Reply Last reply Reply Quote 4
                                      • andywmundefined
                                        andywm @droftarts
                                        @droftarts
                                        Sorry to bump a really old topic. I actually did solve this issue, I attended SMRRF and spoke with someone at the Duet booth, possibly even you actually. And had just never come back to check. Forgot my forum etiquette a bit. In my case the included ribbon cable
                                        I am updating for anyone else in the future that may come across this thread, as there are already sporadic posts spanning months.
                                        As per
                                        Ribbon cable should ideally be not longer than 150mm.
                                        The included ribbon cable that shipped with the Duet 6HC was too long per this advise, about 220-250mm from memory.
                                        Once I cut it down, this problem was eliminated for me.
                                        droftartsundefined 1 Reply Last reply Reply Quote 2
                                          @andywm Thanks for the follow up, and glad it's working for you now. For some reason it used to work with the older, longer ribbon cable (and sometimes quite a lot longer cables), though I can't say we've tested it recently, and now generally recommend a shorter cable. It may just be down to cable quality, and how good the connection is between the ribbon wire and press-on connector, as they rely on a small 'fork' cutting through the ribbon wire insulation.
                                          I've added a fair amount of notes to the troubleshooting page, including links to loopback tests for Duet and SBC, which should help narrow down where the issue is.
