    Best lead screw - ball bearing mount system
    3D Printing General Chat
    13
    42
    5.4k
      deckingman
      I'd just add that if there is any misalignment of the linear guides or, any other inaccuracy that can cause the Z axis to bind or stick a bit, then those couplings can wind up like a spring and absorb some of the linear movement. Then when there is enough tension, they can let go and give bit extra movement. The net result being uneven layer heights. Hence my personal opinion is to ditch them (or use a universal joint or Oldham coupling if you really have to use something).
      • Edgars Batnaundefined
        Edgars Batna
        What @deckingman said. You need completely straight lead screws and they should be attached to the frame without potential for movement. If there's any chance the bed can move on its own without input from the motor, then so it will and layers will be uneven.
        I'd think that heavier beds are more prone to problems with flexible couplings. I tried various "self aligning" "hassle-free" couplings and they all were just randomizing the error.
        • sinned6915undefined
          sinned6915
          There are a few printers that have similar motion systems. The one that comes to mind is Herculien and Eustathios. They use a pair of ball bearings to support the screw through a bearing holder and the pulley is grub screwed to the screw, and stop collar to keep the whole mess together. Bearing holder also supports the 10mm shaft. Same block for ball screws and TR8 screws.
          https://i.imgur.com/BfKQMK1.png
          Hope this screen grab makes sense. The plastic part bolts up to the underside of an 202o extrusion. The top and bottom bore accepts the 608zz bearings, and the pulley goes on the to and acts as a stop collar.
          If you go here https://github.com/eclsnowman/Eustathios-Spider-V2
          and navigate to the STL's, you can preview the part.
          Eustathios-Spider-V2/STL Print FIles/Z_Axis_Leadscrew_Support_V2 (With Tensioner Config_hold downs and diaphragms).STL
          The one thing I do not like about any of the designs is that the bearing in whatever form will have to support axial thrust loads. Deep groove ball bearings are crap for thrust loads. Proper design would be to use a pair of angular contact bearings that bear on a shoulder, but those are $$$
          I added a ball thrust bearing and I think it made a difference. It is big enough to bear on the outer race and support the pulley above.
          https://www.mcmaster.com/6655k54
          • Vetiundefined
            Veti
            what about sfu1204. you would not need the coupler.
            • DocTruckerundefined
              DocTrucker
              Is the pulley for belt reduction or tying the three lead screws to one stepper?
              If the former I would recommend worm reduction drive instead to reduce the chance of the elevator driving itself down under it's own weight. I was going to look into breaks for my belt reduction system but someone rightly pointed out worm reduction was potentially a better option.
              deckingmanundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                deckingman @DocTrucker
                @doctrucker From other posts, I think he was gunning for a continuous belt/single motor (but I could be wrong).
                The simplest way to prevent the weight of the bed from driving the screws is to use a finer lead screws with correspondingly shallower helix angles.
                Worm drives are OK (ish) - the problem is eliminating backlash. If you have a sufficiently heavy bed and a very steep helix angle on the thread (very course lead), then gravity will take care of any backlash, but finer lead screws are all together a simpler and (IMO) more elegant solution.
                  Phaedrux Moderator @DocTrucker
                  @doctrucker said in Best lead screw - ball bearing mount system:
                  I think his lead screws are 2mm pitch/lead single start, so shouldn't have much auto rotation potential.
                  • Stephen6309undefined
                    Stephen6309
                    On my corexy using makerslide. I have only a 608 bearing and the pulley keeping the tr8-8 in place with gravity. One belt runs the two leadscrews from the stepper motor at 2:1. The bed will move down if I press hard down on it, otherwise it doesn't move.
                    • gnydickundefined
                      gnydick
                      If your bed is mounted rigidly and can't move in X or Y, then the lead screw really doesn't have to be all that good. I use a floating lead screw nut because lead screws aren't perfect, but the linear rails that my bed is mounted to is precise. I've seen ZERO artifacts from the float.
                        deckingman @gnydick
                        @gnydick I'll second that. Lead screws should only provide lift, guides should only guide. I had a bit of an accident a few months ago and bent one of the lead screws. I've never got around to straightening or replacing it because it prints perfectly. The screw might wobble a bit, but one rotation still gives me exactly 1mm of linear movement.
                        • gnydickundefined
                          gnydick @deckingman
                          @deckingman I had the exact same thing happen!!
                          • claustroundefined
                            claustro
                            Thank you for all your suggestions.
                            This is what come out .
                            I moved the thrust bearing on the top so it can discharge the weight of the bed on the plastic structure.
                            Below I installed the ball bearing that doesn't have to manage weight.
                            I am still waiting for the rigid coupler.
                            what do you think
                            2_1559396358318_20190601_151644 (Piccola).jpg 1_1559396358318_20190601_151656 (Piccola).jpg 0_1559396358317_20190601_151713 (Piccola).jpg
                              Looks good to me.
                                deckingman
                                That'll do.
                                • mrehorstdmdundefined
                                  mrehorstdmd
                                  With this sort of thing I tend to think about what might go wrong and what I can do to prevent it. I try to only have to do things once. Making things as close to ideal (in the relevant properties) as possible reduces the things you have to consider if something goes wrong. If I use a plastic part in an assembly I tend to make it bulky to ensure rigidity, so I wouldn't use thin plastic flanges, even with side-webbing, to support a relatively large weight or something that will be loaded by a drive belt.
                                  At the very least I would thicken the flange that bolts to the top side of the t-slot, maybe to the point of making it continuous with the body of the part. I'm not saying that your flange design won't be adequate, but if it isn't, you'll be redesigning and reprinting.
                                  In the end, you should worry less about the plastic flexing and more about the t-slot it's bolted to twisting.
                                  claustroundefined 1 Reply Last reply Reply Quote 0
                                  • claustroundefined
                                    claustro @mrehorstdmd
                                    @mrehorstdmd
                                    is something like this enough "bulky"?
                                      mrehorstdmd
                                      Yes, I'd do something like that. I'd also use modifier meshes to increase the fill density around the mounting bolt holes.
                                      • Vetiundefined
                                        Veti
                                        that reminds me there was a video by alex kenis about this
                                        https://www.youtube.com/watch?v=2Z7mZVvPlc8
                                        • claustroundefined
                                          claustro
                                          While I am trying to fix the squareness of the frame I finalized!the Z axis belt system
                                          This is what it came out.
                                          I tried to make the belt running as much as possible around the pulley with this setup all the pulley has 180 degree belt contact.
                                          The 2 tensioners are temporary , I am going to print a support for it
                                          Any suggestion will be appreciated.
                                          Thank you
                                          Andrea
                                          deckingmanundefined gnydickundefined 2 Replies Last reply Reply Quote 1
                                            deckingman @claustro
                                            @claustro How come those front two lead screws are set so far back from the front of the frame?
