    Looks like I need a new printer!
    27
    2349
    • PaulHew
      PaulHew last edited by
      My partner found lots of things on Pintrest which requires a 3D printer....
      So my thoughts are I give her my Ender 3 Pro which is heavily converted and I buy a kit to build like a Core XY.
      So I have been looking at some kits, RatRig, Railcore and Hypercube but I do not know what to buy and thats where I need the help, please.
      I know what I will control it with, Duet obviously and for this build I would like a 2 colour hotend.
      I live in the UK, so E3D and Oozenest are good for parts and extrusions.
      I build model helicopters from kits, so I am good with making sure things are correct and am able to do simple electronics, not at component level!
      Do I buy a kit pre cut with all the fixings etc, then purchase the motors, hotend etc.?
      Suggestions and guidance would be appreciated.
      Regards,
      Paul.
      RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
      Voron 2.4 disassembled..... Waiting for the RailCore Mini....
      deckingman zapta DocTrucker 3 Replies Last reply Reply Quote 0
        Of the 3 kits you've listed, I would say that the RailCore is my top pick, but being in the UK may mean shipping from the US, which may be a non-starter. You could still self-source the parts though since the BOM is available.
          As you are looking for a CoreXY design you could also consider the E3D tool changer if you can wait a little longer, but it's not cheap.
          • deckingman
            deckingman @PaulHew last edited by
            @paulhew What tools do you have? Can you cut aluminium extrusion accurately to length and square? If so, you could look at some of the OpenBuilds designs. Many of them have build logs and include BOMs.
            There is another user on these forums building a RatRig kit that you might find informative. https://forum.duet3d.com/topic/9465/core-xy-based-on-rat-rig-v-core-and-duet-2-ethernet/144
            I've used both RatRig and Ooznest. Prices vary a bit depending on Euro to GBP exchange rate but there isn't much in it. Delivery from RatRig is very slow (in my experience and that of the user who's thread I linked to). Ooznest on the other hand are super fast and very efficient. (Disclaimer - Ryan from Ooznest has been generous to me in the past but despite that, I would still highly recommend them).
            As a general rule, people who spend time sourcing parts to put kits together for sale, usually put a bit of a mark up on the parts to pay for their time. So maybe buying the extrusion - either cut to length or otherwise then sourcing the rest of the hardware yourself might save some money but cost some time (so it depends which you have most of). Also, as you have a printer at the moment, and if a kit includes printed parts, then it would make a lot of sense to print those yourself.
            Here is a tip for assembling the frame. You'll need lots of M5 bolts so buy them from here https://www.screwfix.com/search?search=button+head+screws#boltsize=m5. Less than £3 for a pack of 50.
            For motors, these are hard to beat https://www.omc-stepperonline.com/nema-17-stepper-motor?mfp=16o-ship-from[61]
            HTH
            • zapta
              zapta @PaulHew last edited by
              @paulhew said in Looks like I need a new printer!:
              I purchased an hypercube evolution kit and ended up using only a small fraction of the parts.
              My suggestion is use the BOM approach. Decided on the design and the parts you want and purchase them separately. For extrusion frame, I would go with cut to order because the cuts are more accurate and cleaner than what I can achieve with my hand tools buy YMMV. Aliexpress is a great source for many parts (screws, steppers, heated bed, extruders, belts, etc) but possibly not economical for extrusions because of the shipping cost. Also, for some components such as power supply you may want brand names such as MeanWell for safety.
              BTW, the most community supported corexy I found is the Voron, excellent information, videos, upgrades, etc. However, I liked more the hypercube evolution design and went with it.
              • BLV
                BLV last edited by BLV
                Check this link, you may find it useful:
                BLV mgn Cube - open source 3D printer
                https://www.thingiverse.com/thing:3382718
                • mrehorstdmd
                  mrehorstdmd last edited by mrehorstdmd
                  This corexy machine works pretty well for me.
                  But I suggest you design and build your own. It's more fun, you'll learn more, and since you are already familiar with the way printers work, you have a good base from which to start.
                  • T3P3Tony
                    I must say i agree with @deckingman and @mrehorstdmd - if you have the time then making your own design will be really rewarding. I would spend quite a bit of time looking at existing designs and reading critiques of them though because there is a tendency in 3d printer designs to repeat errors that have been well documented before (for example over constraining axis).
                    On the other hand, if you want to build a really solid design but not have to work out all the details then the Railcore II would get my vote. I saw a large number of them, both self sourced and from ProjectR3D at MRRF and they were printing very impressively. @kraegar here is one of the developers.
                    None of that is to say that the RatRig or BLV mgn cube, or hypercube are bad, i just don't have experience with them.
                    Duet Hardware Designer
                    www.duet3d.com
                    deckingman zapta 2 Replies Last reply Reply Quote 0
                    • deckingman
                      deckingman @T3P3Tony last edited by
                      @t3p3tony They can all be improved upon - but for me that's part of the fun. My printer is continuously evolving as readers of my blog will know. For me, there is a huge amount of satisfaction to be gained from making ones own design and tweaking it. But that may not be what the OP is looking for - only he can decide how much time and effort he wants to put in.
                      I just need to think of a name for mine. I was thinking along the lines of "Hyper Ballistic Vengeance Predator"
                      ..............only joking - I'll just stick with "The tall coreXY" .............. ☺
                      • T3P3Tony
                        T3P3Tony administrators @deckingman last edited by
                        @deckingman you have bucked the trend. Normally one comes up with an awesome name and then builds a printer to fit!
                        www.duet3d.com
                        • PaulHew
                          Thank you all for your input, I REALLY appreciate it.
                          @deckingman - I would use Oozenest for my extrusions and have already been in touch with Ryan today asking if they can cut the rails if I gave them the dimensions.
                          They are about 1.5 hours away so I might take a run out there and go through whichever build I am going to do and save a delivery charge.
                          I have watched some of your videos and was amazed especially when you put the counter balance on.
                          The RatRig, Yes I have to agree it would take a while for the parts to turn up and possible customs charges.
                          I started going through the Railcore BOM and started putting prices together.
                          Also I was looking on Openbuilds and other sites before I had all these superb responses.
                          @mrehorstdmd That is a massive build and must say it does look impressive.
                          I honestly do not know what I would print with something that big!
                          @T3P3Tony I am not clever in design, better at building things with a box of bits and would not know where to start designing my own. I am good at building computer networks and model helis and programming control systems to control houses.
                          Maybe after I have built one from scratch i would have a better idea.
                          @zapta I think you are right, i will go for cut to order, makes sense, I do not think my multitool would be too good for accuracy!
                          At the moment I am learning towards the BLV as there are alot of metal parts I can source in the UK like the 90 degree metal brackets and I prefer metal to plastic, especially for the frame.
                          @Phaedrux - I think you are right Railcore might be a non starter as I would definately want the aluminium parts after reading the blog about the plastics giving up.
                          @dc42 A tool changer, lots of money! I think I will stick with a 2 colour head first!
                          More Duet boards and questions on the forum!
                          Do not hink I could justify the Diamond 5 colour head @deckingman has on his rig.
                          I also prefer to use UK Suppliers, I would never buy a clone of anything, I have seen a £3k helicopter go down because the guy thought the £70 receiver was as good as the £275 receiver.
                          I think the other thing is the availability of the parts, I have mentioned Oozenest and E3D and of course Duet3D!
                          I am probably going to find others who I will need to supply me, like Simply Bearings, i use them a lot when I rebuild model Helicopter engines and things.
                          Again, I thank you all for your input, it has blown me away.
                          Excel spreadsheets tomorrow!
                          Kind Regards,
                          Paul.
                          Phaedrux deckingman 2 Replies Last reply Reply Quote 0
                            Phaedrux Moderator @PaulHew last edited by
                            You know you've found the right hobby when you're excited to use Excel.
                            • oliof
                              oliof last edited by
                              @PaulHew as long as UK is part of the European trade union, you won't be paying import tax on RatRig as they're based in Portugal.
                              That said, I had an order with them which I cancelled after five or so weeks -- they're seemingly victims of their own success and have met challenges scaling their operations. They're very friendly and helpful and there's a pretty welcoming community about RatRig on Facebook.
                              <>Creality CR-20 IDEX Duet3 mini 5+<>RatRig V-Minion SKR RRF 1.1<>
                              • jay_s_uk
                                jay_s_uk last edited by
                                There are many places that sell the cut extrusions. Here is just one of them, so you may find somewhere a bit closer at equal or cheaper price. It's all the same stuff.
                                Owns various duet boards and is the main wiki maintainer for the Teamgloomy LPC/STM32 port of RRF
                                Dougal1957 1 Reply Last reply Reply Quote 0
                                • Dougal1957
                                  Dougal1957 @jay_s_uk last edited by
                                  @jay_s_uk said in Looks like I need a new printer!:
                                  Actually it isn't all the same stuff.
                                  If you intend to use V-Wheels running on the slots then that stuff you linked just will not do the job properly you do need the Proper V Slot profile and not T-Slot like the Valuframe or even the motels or bosch-rexroth profiles for that matter.
                                  Just my 2 pence (Cents) thoughts.
                                  Doug
                                  • deckingman
                                    deckingman @PaulHew last edited by deckingman
                                    @paulhew You need also to think about how you are going to join the extrusion together. I favour the technique whereby you tap the ends of the extrusion, insert a button head screw, then drill a hole in the side of the other member that forms the corner. The side hole is clearance diameter for an Allen key. Like this
                                    The "button head" of the screw slides into the slot in the mating extrusion. It's much neater, and cheaper, and arguably stronger than using those God awful brackets. The ends of the extrusion are already drilled to take the right size tap but many suppliers will tap the ends for you if you want. Drilling the holes in the sides is a little more tricky - I managed to do all mine with a hand held power drill but a bench drill or better still a small mill, would have made life easier.
                                    • PaulHew
                                      Thanks @deckingman - I have a friend who has a bench drill / mill and he owes me a few favours!
                                      There is a lot of 90 degree brackets on the BLV, still have not made my mind up.
                                      I am like a kid in an ice cream shop!!
                                      • whosrdaddy
                                        whosrdaddy last edited by whosrdaddy
                                        To expand on @deckingman excellent advise, I use these from Motedis:
                                        https://www.motedis.com/shop/Nutprofil-Zubehoer/Zubehoer-20-I-Typ-Nut-5/Verbinder-Winkel/Standardverbinder-20-I-Typ-Nut-5::570.html. It is the same principle as @deckingman uses but the plate will assure a straight connection between the 2 extrusions. Drilling holes in the extrusion is not hard to do with the right tools (and some cutting oil 🙂 )
                                        deckingman 1 Reply Last reply Reply Quote 1
                                        • deckingman
                                          deckingman @whosrdaddy last edited by
                                          @whosrdaddy said in Looks like I need a new printer!:
                                          That's a good find - looks like they will give a bit more contact area than just the button head. I'll bear those in mind if I ever build another printer.
                                          • zapta
                                            zapta @T3P3Tony last edited by
                                            @t3p3tony said in Looks like I need a new printer!:
                                            ... there is a tendency in 3d printer designs to repeat errors that have been well documented before (for example over constraining axis).
                                            @t3p3tony, can you explain over constraining? For example, in the larger version of hypercube evo, the Z bed it supported by four vertical rods and moved by two lead screws. What are the over constrains in this example?
                                            Also, the bed is supported and leveled by 4 screws. Is it also an over constrain?
                                              Phaedrux Moderator @zapta last edited by
                                              @zapta You would need one rod to fix the bed in X and Y, and another rod to keep the bed from rotating around the first rod. Anything more is technically over constrained. But in reality there are no perfectly rigid bodies and things do flex and sag, so adding more constraints can be used to overcome those problems, however it's not without its own problems, like binding when things aren't perfectly aligned. Or at least aligned to within tolerance.
                                              For the bed leveling, 3 points define a plane, 4 points define a saddle parabola. If the bed is rigid enough to maintain a flat plane when supported at only 3 points leveling will be much easier. If the bed is too flexible to be adequately supported by 3 points, then 4 points can be used, and can still arrive at a flat plane, but it will take far more adjustment to take the twist out of the saddle.
                                              If you're really interested in mechanical constraints in 3D printers I suggest this book: http://www.sublimepublications.com/store/p1/3D_Printer_Engineering_Volume_1%3A_Motion_Platform_Design.html
                                              zapta 1 Reply Last reply Reply Quote 0
                                              • deckingman
                                                deckingman @zapta last edited by
                                                @zapta said in Looks like I need a new printer!:
                                                IMO that's a classic case of being over constrained. The vertical rods should not support the bed - that's the job of the lead screws. The vertical rods should only prevent the bed from moving in the X or Y directions and two rods, one at each opposite corner is enough to do that. Trying to accurately align two rods so that they are perfectly parallel is difficult enough, three is even worse and four is asking for trouble. But then lifting a bed with only two screws is also asking for trouble...........
                                                • kraegar
                                                  kraegar last edited by
                                                  I do wish we could make getting a RailCore to the UK easier. Shipping and customs suck.
                                                  Co-Creator of the RailcoreII CoreXY printer
                                                  https://www.thingiverse.com/thing:2407174
                                                  • zapta
                                                    zapta @Phaedrux last edited by
                                                    @phaedrux said in Looks like I need a new printer!:
                                                    I will take a look, thanks.
                                                      dc42 administrators @kraegar last edited by
                                                      @kraegar said in Looks like I need a new printer!:
                                                      Might be worth checking whether Ooznest stocks many of the parts already. If so then perhaps they could supply kits in this part of the world. They are already a Duet3D distributor.
