    Stringing problem corexy
    Example setups and prints
    270
    • Dav
      Dav last edited by
      Hi
      As you can see in the picture I have problemswith my direct BMG corexy, these are my config:
      deckingman droftarts 2 Replies Last reply Reply Quote 0
      • deckingman
        deckingman @Dav last edited by
        @Dav Insufficient retraction.
        Dav 1 Reply Last reply Reply Quote 0
        • jay_s_uk
          jay_s_uk last edited by
          @Dav
          You'd be better off using the built in firmware retraction so you can tweak it during printing until it no longer leaves any strings etc
          https://duet3d.dozuki.com/Wiki/Gcode#Section_M207_Set_retract_length
          Owns various duet boards and is the main wiki maintainer for the Teamgloomy LPC/STM32F4 port of RRF
          • Dav
            Dav @deckingman last edited by
            @deckingman
            it's a direct, I have less than 10cm of bowden tube between bmg and hotend
            deckingman timcurtis67 2 Replies Last reply Reply Quote 0
            • deckingman
              deckingman @Dav last edited by deckingman
              @Dav said in Stringing problem corexy:
              @deckingman
              So what? The stringing is caused by filament continuing to ooze during travel moves. The 0.8mm of retraction you are using insufficient to compensate for this. The amount of retraction you need (as well as the speed of retraction) is a function of many things, not just the length of Bowden tube. Temperature, filament type, print speed, travel speed, whether you use pressure advance etc, can all play a part.
              • timcurtis67
                timcurtis67 @Dav last edited by
                @deckingman
                Adjust retraction or lower hotend temp. Both effect stringing.
                • droftarts
                  droftarts Moderator @Dav last edited by
                  @Dav Please post config.g and send M115 to your Duet, then post the response. What material is this (PLA?) and what temperature do you print at?
                  • imrj
                    imrj last edited by
                    am having issue with stringing too with TPU....can someone clarify how to approach a setting for retraction speed? I know from past experience if I make my Dyze Xtruder retract too fast it will clog....
                    • PaulHew
                      PaulHew last edited by PaulHew
                      @imrj I have been printing Ninjatek Armadillo TPU. E3D Aero extruder 0.4mm nozzle.
                      Base was a PLA profile, tweaked heat settings to suit, 220 / 40. Retraction 50mm/s length 1mm
                      Print speed 55mm/s, infill 45mm/s, walls 27.5mm/s, top/bottom speed 15mm/s
                      HTH
                      Paul
                      RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
                      Voron 2.4 disassembled..... Waiting for the RailCore Mini....
                      • imrj
                        imrj last edited by
                        the max retraction speed for the Dyze is 25mm/s , but i will try the other settings....i can always go higher than 25 but am sure will be clogging time
