    Duet 3 : No tool nor bed shown
    1.1k
    • Donpiundefined
      Donpi
      Can someone tell me what I'm doing wrong ?
      I have not tool nor bed and the temperature graph is empty.
      Here is my config.g
      G90                                            			; Send absolute coordinates...
      M83                                            			; ...but relative extruder moves
      M669 K1                                        			; Select CoreXY mode
      M569 P0.0 S0                                   			; Physical drive 0.0 goes forwards
      M569 P0.1 S0                                   			; Physical drive 0.1 goes forwards
      M569 P0.2 S0				       			   			; Physical drive 0.2 goes forwards
      M569 P0.3 S0                                   			; Physical drive 0.3 goes forwards
      M569 P0.4 S1                                   			; physical drive 0.4 goes forwards
      M584 X0.2 Y0.3 Z0.1:0.4 E0.0				   			; set drive mapping
      M350 X16 Y16 Z16:16 E16 I1                     			; Configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E837.20      					; Set steps per mm
      M566 X1000.00 Y1000.00 Z50.00 E1000.00          		; Set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z500.00 E5000.00        			; Set maximum speeds (mm/min)
      M201 X2000.00 Y2000.00 Z100.00 E2000.00         		; Set accelerations (mm/s^2)
      M906 X800.00 Y800.00 Z1200.00 E800.00 I30       		; Set motor currents (mA) and motor idle factor in per cent
      M84 S30                                        			; Set idle timeout
      M208 X-10 Y-35 Z0 S1                            		; Set axis minima
      M208 X300 Y300 Z300 S0                         			; Set axis maxima
      M574 X1 S4												; Set endstops controlled by multiple motor load detection
      M574 Y1 S4                               				; Set endstops controlled by multiple motor load detection
      M574 Z1 S2												; z Probe
      M915 X Y S6 R1											; Configure motor load detection
      M950 S0 C"io7.out"                              		; create servo pin 0 for BLTouch
      M558 P9 C"^io7.in" H5 F50 T2000                 		; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X0 Y79.3 Z1.2                          		; set Z probe trigger value, offset and trigger height
      M557 X20:280 Y20:280 S20                       			; Define mesh grid
      ; Sensors
      	; Bed
      M308 S0 P"temp0" Y"thermistor" T100000 B3950 R4700      ; configure sensor 0 as thermistor on pin temp0
      	; Extruder 0
      M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8   ; configure sensor 1 as thermistor on pin temp1
      	;Electronique
      M308 S2 Y"drivers" A"DRIVERS"  							; configure sensor 2 as temperature warning and overheat flags on the TMC2660 on Duet
      M308 S3 Y"mcu-temp" A"MCU" 	   							; configure sensor 3 as thermistor on pin e1temp for left stepper
      	; Bed
      M950 H0 C"out0" T0 Q1.00                                ; create bed heater output on out0 and map it to sensor 0
      M307 H0 B0 S1.00                                        ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                                 ; map heated bed to heater 0
      M143 H0 S150                                            ; set temperature limit for heater 0 to 150C
      M307 H0 A165.1 C686.8 D1.7 S1.00 V25.6 B0
      	; Extruder 0
      M950 H1 C"out1" T1                                      ; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 B0 S1.00                                        ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280                                            ; set temperature limit for heater 1 to 280C
      M307 H1 A531.2 C241.0 D3.4 S1.00 V25.4 B0
      	;HotEnd
      M950 F0 C"out3" Q25000                                  ; create fan 0 on pin out3 and set its frequency
      M106 P0 S0 H-1                                          ; set fan 0 value. Thermostatic control is turned off
      	;HeatBreaker
      M950 F1 C"out4" Q500                                    ; create fan 1 on pin out4 and set its frequency
      M106 P1 S1 H1 T45                                       ; set fan 1 value. Thermostatic control is turned on
      	;Electronique
      M950 F2 C"out5" Q100                                    ; create fan 2 on pin out5 and set its frequency
      M106 P2 S1 H2:3 L0.15 X1 B2 T40:70                      ; set fan 2 value. Thermostatic control is turned on
      M563 P0 D0 H1 F0                                        ; define tool 0
      G10 P0 X0 Y0 Z0                                         ; set tool 0 axis offsets
      G10 P0 R0 S0                                            ; set initial tool 0 active and standby temperatures to 0C
      G10 L2 P1 X0.00 Y0.00 Z0.00
      M572 D0 S0.25
      M575 P1 S1 B57600                                       ; enable support for PanelDue
      engikeneerundefined 1 Reply Last reply Reply Quote 0
      • dhusoloundefined
        dhusolo
        what happens if you try modifying both of the M308 to include A
        M308 S0 P"temp0" Y"thermistor" A"Bed Temp" T100000 B3950 R4700
        Donpiundefined 1 Reply Last reply Reply Quote 0
        • Donpiundefined
          Donpi @dhusolo
          @dhusolo Thanks for the reply.
          I just tried, but still the same. no sensor, no tools, no bed.
          dhusoloundefined droftartsundefined 2 Replies Last reply Reply Quote 0
          • dhusoloundefined
            dhusolo @Donpi
            @Donpi I had the same problem at one point but I can't remember exactly what I did to fix it. It might have been re-uploading the firmware.
            This is my heater section. Try pasting it into your config.g to see if it works but make sure you make a backup of it first and you restart the printer after you upload the config
            M308 S0 P"temp0" Y"thermistor" A"Bed Temp" T100000 B4700 C0.0000000706                   ; configure sensor 0 as thermistor on pin temp0
            M308 S1 P"temp1" Y"thermistor" A"Extruder Temp" T100000 B4725 C0.0000000706               ; configure sensor 1 as thermistor on pin temp1
            M950 H0 C"out1" T0                                 ; create bed heater output on out1 and map it to sensor 0
            M950 H1 C"out2" T1                                 ; create nozzle heater output on out2 and map it to sensor 1
            M307 H0 A326.4 C1281.8 D11.0 V24.5 B0              ; Set PID for bed heater
            M143 H0 S100                                       ; set temperature limit for heater 0 to 100C
            M307 H1 A319.6 C112.6 D2.2 V24.5 S1.0 B0			; Set PID for Hotend .4Bmm nozzle
            M143 H1 S260                         				; Set temperature limit for heater 1 to 260C
            M308 S2 P"mcu-temp" Y"mcu-temp" A"Duet Board" ; Configure MCU sensor
            M950 F0 C"out9" Q500                               ; create fan 0 on pin out9 and set its frequency
            M106 P0 C"Layer Fan" S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
            M950 F2 C"out7" Q500                               ; create fan 1 on pin out7 and set its frequency
            M106 P2 C"MB Fan" T40:55 H2                                  ; set fan 1 value. Thermostatic control is turned on
            M950 F1 C"out8" Q500                               ; create fan 1 on pin out8 and set its frequency
            M106 P1 S255 H1 T30                                  ; set fan 1 value. Thermostatic control is turned on
            • engikeneerundefined
              engikeneer @Donpi
              @Donpi double check your firmware version. Send M115 in the console to see what it says. You should be running version 3.1.1 to match your config.
              i3 clone with a bunch of mods
                droftarts administrators @Donpi
                @Donpi I can't see anything particularly wrong with your config.g. Please send M122 and post the reply. Are you using Duet 3 in standalone or with SBC?
                Also, send M98 P"config.g" and see if config.g generates any errors. If not, send M308 S0 and M308 S1 to report sensor configuration, then M950 T0 and M950 T1. You should get a response something like:
                M308 S0
                Sensor 0 type Thermistor using pin bedtemp, reading 19.1, last error: sensor not ready, T:100000.0 B:3988.0 C:0.00e+0 R:4700.0 L:0 H:0
                M950 H0
                Heater 0 pin bedheat frequency 250Hz, sensor 0
                • Donpiundefined
                  Donpi @engikeneer
                  @engikeneer M115 return this :
                    jay_s_uk @Donpi
                    @Donpi I would upgrade your firmware to 3.1.1 first.
                    https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
                    https://github.com/Duet3D/RepRapFirmware/releases/tag/3.1.1
                    • Donpiundefined
                      Donpi @droftarts
                      @droftarts
                      I use a Raspberry 4 2Go as SBC.
                      M98 P"config.g" Show me the welcome message again.
                      But no error
                      Here is the return of
                      M308 S0
                      M308 S1
                      M950 S0
                      M950 S1
                      M122 returns this :
                      M122
                      RepRapFirmware for Duet 3 MB6HC version 3.01-RC9 running on Duet 3 MB6HC v1.01 or later
                      Board ID: 08DJM-956BA-NA3TN-6JTDG-3SD6J-TABLTUsed output buffers: 1 of 40 (11 max)
                      Static ram: 154572
                      Dynamic ram: 160680 of which 20 recycled
                      Exception stack ram used: 264
                      Never used ram: 77680
                      Tasks: NETWORK(ready,2076) HEAT(blocked,1412) CanReceiv(suspended,3824) CanSender(suspended,1484) CanClock(blocked,1432) TMC(blocked,216) MAIN(running,5036) IDLE(ready,80)
                      Owned mutexes:
                      Last reset 00:03:46 ago, cause: power up
                      Last software reset details not available
                      Error status: 0
                      Free file entries: 10
                      MCU temperature: min 20.8, current 26.6, max 26.8
                      Supply voltage: min 24.9, current 24.9, max 25.0, under voltage events: 0, over voltage events: 0, power good: yes
                      12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
                      Driver 0: standstill, reads 6924, writes 11 timeouts 0, SG min/max 0/0
                      Driver 1: standstill, reads 6925, writes 11 timeouts 0, SG min/max 0/0
                      Driver 2: standstill, reads 6925, writes 11 timeouts 0, SG min/max 0/0
                      Driver 3: standstill, reads 6926, writes 11 timeouts 0, SG min/max 0/0
                      Driver 4: standstill, reads 6926, writes 11 timeouts 0, SG min/max 0/0
                      Driver 5: standstill, reads 6927, writes 11 timeouts 0, SG min/max 0/0
                      Date/time: 2020-11-18 12:04:16
                      Slowest loop: 3.26ms; fastest: 0.14ms
                      Hiccups: 0(0), FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms
                      === MainDDARing ===
                      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
                      === AuxDDARing ===
                      Bed heaters = -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
                      Segments left: 0
                      Movement lock held by null
                      HTTP* is ready with "M122" in state(s) 0
                      Telnet is idle in state(s) 0
                      File is idle in state(s) 0
                      USB is idle in state(s) 0
                      Aux is idle in state(s) 0
                      Queue is idle in state(s) 0
                      LCD is idle in state(s) 0
                      SBC is idle in state(s) 0
                      Daemon* is idle in state(s) 0 0, running macro
                      Code queue is empty.
                      === Network ===
                      Slowest loop: 1.90ms; fastest: 0.01ms
                      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
                      HTTP sessions: 0 of 8
                      - Ethernet -
                      State: disabled
                      Error counts: 0 0 0 0 0
                      === CAN ===
                      Messages sent 0, longest wait 0ms for type 0
                      === Linux interface ===
                      State: 0, failed transfers: 0
                      Last transfer: 17ms ago
                      RX/TX seq numbers: 6649/6650
                      SPI underruns 0, overruns 0
                      Number of disconnects: 0
                      Buffer RX/TX: 0/0-0
                      === Duet Control Server ===
                      Duet Control Server v3.1.1
                      Daemon:
                      Finishing macro daemon.g, started by system
                      > Next stack level
                      Code buffer space: 4096
                      Configured SPI speed: 8000000 Hz
                      Full transfers per second: 0.82
                      • Donpiundefined
                        Donpi @jay_s_uk
                        @jay_s_uk
                        you meen with with
                        sudo apt update
                        sudo apt upgrade
                        I'll allready done it but noting install.
                        • A Former User?
                          A Former User @Donpi
                          @Donpi said in Duet 3 : No tool nor bed shown:
                          try running M997 the previous post shows the software on the pi is 3.1.1. M997 should try to flash the board to match.
                          • Donpiundefined
                            Donpi @A Former User
                            @bearer @jay_s_uk @engikeneer
                            The M997 worked... I guess
                            now M115 reutrns :
                            But still nothing...
                            • Vetiundefined
                              Veti
                              M950 S0
                              M950 S1
                              you wrote T instead of S
                              • Donpiundefined
                                Donpi @Veti
                                @Veti Yeah, in this case, even S was wrong 😛
                                M950 H0 and H1 give the same response :
                                Heater 0 does not exist
                                • Vetiundefined
                                  Veti
                                  you are not allowed to specify 2 z values.
                                  what i would suggest is. save all your config files and generate an new one from the configurator.
                                  then slowly start adding your additional configs one by one until it breaks.
                                    @Donpi My mistake, send M950 H0 and M950 H1 (not T0/1) to check heater definition. Also send M563 P0 to check tool definition.
                                    M563 P0
                                    Tool 0 - name: T0; drives: 0; heaters (active/standby temps): 1 (0.0/0.0); xmap: X; ymap: Y; fans: 0; status: selected
                                    But M308 S0 and S1 reporting "Sensor does not exist" does seem to imply there is a problem with your M308 definition in config.g. What happens if you send M308 S0 P"temp0" Y"thermistor" A"Bed Temp" T100000 B4700 C0.0000000706?
                                    • Donpiundefined
                                      Donpi @droftarts
                                      @droftarts strange this work well.
                                      and if I call M308 S0, it says :
                                      Sensor 0 (bed Temp) type bla bla bla...
                                      It's like my config.g is not readed or somthing reset everything
                                      • Donpiundefined
                                        Donpi @Veti
                                        @Veti With a complettely new copnfiguration strait from the generator I have the same behaviour
                                        • Vetiundefined
                                          Veti
                                          what version of the duet web control are you running?
                                          Donpiundefined 2 Replies Last reply Reply Quote 0
                                          • Donpiundefined
                                            Donpi @Veti
                                            @Veti
                                            I'am a bit puzzled ...
                                            I have created a macro with my config.g.
                                            And running the macro I get the tootls and heaters...
                                            It' just give me this errors
                                            I don't know why my config.g is ignored...
