Duet3 -> SBC wiring (without the ribbon cable)
I'm (currently) using the duet3 with an attached RaspPi 4. The RaspPi is powered via the RaspPi wall wart (not from the duet3.) Would it be reasonable to replace the bulky and cumbersome ribbon cable with just 6 wires with female dupont connectors?
I'm guessing I could just connect the following pins from the duet3's SBC connector to the same numbered pins on the RaspPi:
19 - SPI_MOSI
20 - GND
21 - SPI_MISO
22 - TFR_RDY
23 - SPI_SPCK
24 - SPI_NPCS0(This would leave unconnected pins 2/4 (+5VDC) and pins 6/9/14/25 (all GND)) I think my biggest concern is if all 5 of the duet3 "GND" pins are interconnected on the duet. If they are, just using pin 20 should be okay.
If so, would 24 AWG silicone wires be suitable for a length of 150 to 200mm?
Thanks
Gary -
yes, that should work.
I believe @bearer was using his own cable rather than the supplied one. -
@jay_s_uk said in Duet3 -> SBC wiring (without the ribbon cable):
I believe @bearer was using his own cable rather than the supplied one.Thank you. I did see an old post from @bearer who said there might be an even older post showing a picture what he did, but I can't seem to find that oldest post, so wasn't sure which pins he used (and which ones he didn't.)
So - figured I'd ask here to be certain that ignoring all but those 6 specific pins would be okay.
we mainly wire up the SBC on the LPC/STM port stuff.
All the correct pins on the pi are detailed here
https://github.com/gloomyandy/RepRapFirmware/wiki/SKR-SBCpretty picture
https://github.com/gloomyandy/RepRapFirmware/wiki/SKR-SBCThat's interesting: You use pin 6 for GND instead of pin 20. Is there a particular reason? (My reasoning for using pin 20 was so that it'd be clustered with the other 5 required pins, allowing the use of two 1x3 or one 2x3 housing(s.)
@garyd9 no reason at all.
I should probably change it to 20. They all do the same thing. -
I'm kind of curious: what kind of board is that diagram wiring to? If resistors are needed on the signal lines, I'm guessing it's not electrically identical to a duet3 board...
@garyd9 said in Duet3 -> SBC wiring (without the ribbon cable):
BigTreeTech SKR V1.3
@garyd9 yep, an SKR 1.3. It was just the quickest thing I had to hand that showed the pi pins.
We have resistors on the SPI lines as on the duet they're built in whereas they aren't for us. Just adds a bit more protection. -
which pin used for ground shouldn't matter, I used pin 20 along with the 5 signal lines and pin 6 & 9 along with the 5V for power. (i guess in theory more ground lines are more better from a signal integrity point of view but never had any issues with the SPI speed used at the time)
@bearer said in Duet3 -> SBC wiring (without the ribbon cable):
Maybe I'm just unlucky but tried to use my own cable a number of times and got random disconnections between SBC and Duet.
Have tried incorporating two ground connections instead of just pin 20 and also made a lead a short as possible.
The reason for using my own cable was that I needed some free gpio pins on the pi.
Back on the ribbon cable now without any problems and got access to the gpio pins by cutting back the appropriate cables on the ribbon. -
I suggest using at least two ground wires, the two closest to the SPI signals. Run all the wires close together. Duets need the 3.3V connection too, except for MB6HC version 0.6.
@dc42 said in Duet3 -> SBC wiring (without the ribbon cable):
So pin1 (and/or pin 17?) also needs a connection for v1.0.x DHC boards? Can I suggest that the image shown on the wiki (https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Wiring_Diagram) updated to include that pin in the "SBC 26 Pin Header" list?
@garyd9 Thanks for pointing that out, I have updated the diagram.
@T3P3Tony said in Duet3 -> SBC wiring (without the ribbon cable):
Thank you. Thank you also for clarifying in the diagram that it's pin 17 (not pin 1) that needs the connection.
That suggests that I can run a 5x2 covering pins 17-26 on a (much) smaller ribbon cable which would cover all the SPI related pins, 3.3vdc on 17, and the GND's on 20 and 25.
It just so happens that I have a few 300mm 5x2 ribbon cables that I purchased for a duet/wifi to paneldue connection (that I later changed to a simple 4 wire connection.) I'll have to give one of them a try for a duet3/SBC connection and see what happens. (I'm not assuming success due to it being 300mm, but duet3d stuff tends to be over-engineered, so it might work fine.)
Again - thank you!
Could somebody confirm the latest pin outs for the sbc ribbon connects on a Mini 5 and Pi4B please?
@Phaedrux got it thanks
@carcamerarig For Raspberry Pi pinout, see https://pinout.xyz/#
For Duet 3 Mini 5+ pinout, see https://duet3d.dozuki.com/Wiki/Duet_3_Mini_5plus_WiringBasically, the Duet SBC port is the same pinout as the Raspberry Pi, with the Duet replicating pins 1 to 26. The top of each header is pin 1 (on the top left) and pin 2 (top right).
You need to connect, pin to pin, pins
17 (3.3V), 19 (SPIO MOSI), 20 (GND), 21 (SPIO MOSI), 22 (SBC_DATA_RDY), 23 (SPIO_SCK), 24 (SPIOSS) and 25 (GND).Ian
5 x 2 Dupont block.
