    What firmware version are you using?
    47
    3.5k
    • zaptaundefined
      zapta
      I am on 3.1.1 (2020-05-19b2).
      Does duet3d have any recommendation on what version we should use if want long term support without having to upgrade to each new release?
      • oliofundefined
        oliof
        there is no LTS release. The recommendation so far always was to use the latest stable release (i.e. 3.2.2 right now). In practice, if you are on a release that works for you, there is no need to update. Unless there is (-:
        • martin7404undefined
          martin7404
          On a modified China corexy I run 2.05 and on new Muldex build yesterday 3.11, today 3.2 and at the moment rolling back as far 3.2 have major issues with tool change on my IDEX
          Muldex IDEX Duet2+Duex5
          Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
          Sapphire Pro with Duet2, with closed-loop motors
          custom high temp E3D tool changer with Duet2+Duex
            Phaedrux Moderator @zapta
            @zapta said in What firmware version are you using?:
            Ride the wave!
            zaptaundefined 1 Reply Last reply Reply Quote 0
            • zaptaundefined
              zapta @Phaedrux
              @Phaedrux said in What firmware version are you using?:
              Ride the wave!
              My printer is pretty stable and useful these days so my focus shifted from the printer itself to what I am creating with it.
              Phaedruxundefined 1 Reply Last reply Reply Quote 1
                @zapta well understood. Keep an eye on the release notes to see if anything is relevant to you. Now that rrf3 is maturing more features and improvements are on the way.
                • o_lampeundefined
                  o_lampe @martin7404
                  @martin7404 said in What firmware version are you using?:
                  Is there a separate thread about it?
                  I got pushed to upgrade from 2.05 to 3.2.
                  But now that I'm in the process of building my own tool changer, I am concerned reading this note from you...
                    martin7404
                    Most probably it is some mistake in panel due manual operation, that made me change from - to + tool offset. It seems it is ok now
                    • oliverracingundefined
                      oliverracing
                      Currently running 2.05 on both my machines, but plan on switching to whatever is latest at the time when changing the kinematics of the portable printer (currently polar swing-arm but it's a bit flexy, changing it to corexy).
                      Main printer is hooked up to looks of external stuff and using outputs for things that they probably shouldn't be so will have to rethink before upgrading as that's a big job and it's currently working!
                      • GeneRisiundefined
                        GeneRisi
                        How well does the RRF3 firmware run on the Duet2? It has less compute power than the Duet3, so, while I know it is possible, does it handle conditional gcode well, or is it underpowered?
                        Phaedruxundefined NeoDueundefined 2 Replies Last reply Reply Quote 0
                          Phaedrux Moderator @GeneRisi
                          @GeneRisi said in What firmware version are you using?:
                          It runs it perfectly fine. There are no limitations or draw backs running RRF3 on the Duet2 series boards. Even the Maestro.
                          • Diamondbackundefined
                            Diamondback
                            Yep I can confirm that, been running RRF3 since it came out on my Duet 2 Wifi and there is nothing negative about it. Works perfectly fine and all the goodies are so worth the switch. 🙂
                            • NeoDueundefined
                              NeoDue @GeneRisi
                              @generisi I can confirm that it runs perfectly fine and fast as well.
                              I had the "Operation 3 failed" Wifi problem (https://forum.duet3d.com/topic/21562/firmware-bundle-3-2-2-released/) when upgrading from 3.2.0 to 3.2.2 though.
                              • RyanPundefined
                                RyanP
                                2.05 on all machines. Too much on my plate. But one day I will simply do all machines.
                                CR10S, August 2018
                                Anycubic Photon S December 2019
                                Ender 5 Feb 2020
                                Ender 5 Plus May 2020
                                Anycubic Photon Mono X Nov 2020
                                https://3dimensiongames.com/
                                • EducatingSavvasundefined
                                  EducatingSavvas @Phaedrux
                                  @phaedrux I tried the latest beta version but found the addition of a P parameter to define a spindle tool in the M3 command problematic - so went back to 3.2. I got it working but suspect using/gearing up for multiple tools (tang knife, laser, plotting-pen and spindle) will be over complicated by this. Possibly having to to use separate post processors for each tool, instead of using the tool number in the tool database to determine the tool I am using.
                                    dc42 administrators @EducatingSavvas
                                    @educatingsavvas said in What firmware version are you using?:
                                    You only need the P parameter if you are in CNC mode and you want to control a spindle that is not the one used by the active tool.
                                    EducatingSavvasundefined 1 Reply Last reply Reply Quote 0
                                      EducatingSavvas @dc42
                                      @dc42 Does that mean if R in M950 and P in M563 are the same number during CNC mode, I would not need to write P# when using an M3 command? Should any spindle defining commands be in the tfree#.g tpre#.g and tpost#.g? That is to say I load the spindle separately from config.g file?
                                      I think the confusion with CNC is that you have the spindle and the bits, or tangential knife and blades are referred and all are referred to as tools. And that on a CNC mills the tool database in often part of a complicated control system, while for flat-bed panel CNC machine the tool database in part of the CAM software.
                                        Yes.
                                        There is no need to do that. In config.g, define all your spindles, then for each tool specify which spindle it uses in its M563 command.
                                        EducatingSavvasundefined 1 Reply Last reply Reply Quote 1
                                          Not sure if this got noted @dc42 but I'm finding I still have to write the P# for the M3 command to work - I've start a separate post about this.
                                          • manpowreundefined
                                            manpowre
                                            3.4 beta2 on my Flsun QQ-S pro with duet3d 2 wifi. upgraded today. I had 3.3 beta 2 before this. All working as it should.
                                            The reason I upgraded was the bugfix for loosing z0 position of bed when homing delta. And I want to try out the accelerometer part. just gotta get the accelerometer and hook it up next week.
