    Dual Markforged :idle IDEX carriage is not still during print
    916
    • martin7404undefined
      martin7404
      HI,
      I did build a Dual markforge kinematics IDEX printer, based on Muldex design. I am using Duet wifi + duex5 boards. The machine has 2 Y motors, 3Z independent Z motors and 1 each for X and U. Recently I spotted, that during printing with 1 carriage, the other that is idle at the moment is moving a little forth and back ( about few tents of a millimetre).
      Checked the mechanics twice
      here is my config
      G90                                             ; send absolute coordinates...
      M83                                             ; ...but relative extruder moves
      M550 P"Muldex"                                  ; set printer name
      M552 S1                                        ; enable network
      M586 P0 S1                                      ; enable HTTP
      M586 P1 S0                                      ; disable FTP
      M586 P2 S0                                      ; disable Telnet
      M569 P0 S0                                     ; X physical drive 0 goes backwards
      M569 P1 S0                                     ; Y right physical drive 1 goes backwards
      M569 P2 S1                                      ; Y left physical drive 2 goes forwards
      M569 P3 S1                                      ; U physical drive 3 goes forwards
      M569 P4 S1                                     ; E1 physical drive 4 goes backwards
      M569 P5 S1                                      ; Z left physical drive 5 goes backwards
      M569 P6 S1                                     ; Z center physical drive 6 goes backwards
      M569 P7 S0                                      ; Z right physical drive 7 goes forwards
      M569 P8 S1                                      ; E2 physical drive 8 goes forwards
      M584 X1 Y0:2 U3 Z5:6:7 E4:8                     ; set drive mapping
      M350 X16 U16 Y16 Z16 E16:16 I1                                                           ; configure microstepping with interpolation
      M92 X100 U100 Y100 Z799.2:799.2:799.2 E813.07:830.00                        ; set steps per mm (1760nimble)
      M566 X600.00 U600.00 Y600.00 Z80.00:80.00:80.00 E100.00:100.00                ; set maximum instantaneous speed changes (mm/min)(Nimble 40)
      M203 X12000.00 U12000.00 Y12000.00 Z1000.00:1000.00:1000.00 E4200.00:4200.00    ; set maximum speeds (mm/min)
      M201 X800.00 U800.00 Y800.00 Z350.00:350.00:350.00 E600.00:600.00                    ; set accelerations (mm/s^2)(500)(Nimble 120)
      M906  Y700 Z700:700:700 E1000:1000 I50                                        ; set motor currents (mA) and motor idle factor in per cent(Nimble 500)
      M906 X700 U700  I50
      M84 S120        ; Set idle timeout
      M208 X-18 Y0 U40 Z0 S1                          ; set axis min - adjust X to align nozzle
      M208 X350 U422.7 Y333 Z300 S0                   ; set axis max
      M669 K0 Y1:1:0:1				                ; select Markforged Kinematics Y to react with X and U
      M574 X1 S1 P"xstop"                             ;X axis active high endstop switch
      ;M574 Y2 S1 P"ystop+e1stop"                      ;Y Double max active high endstop switch
      M574 Y1 S4 ; configure sensorless endstop for low end on Y
      ;M574 Y1 S4 ; configure sensorless endstop for low end on Y
      M574 U2 S1 P"e0stop"                            ;U axis active high endstop switch
      ;M574 Z2 S4
      ;Stall Detection(no used)
      ;M574 Y1 S4                                     ; Y axis stall detection
      ;M915 P1:9 S3 F1 R0                             ; Y axis stall detection
      M671 X-20.6:200:420.6 Y14.3:333.3:14.3 S10       ; Locations left, center, right
      M950 S0 C"duex.e6heat"                          ; create servo pin 0 for BLTouch
      M558 P9 C"zprobe.in+zprobe.mod" H10 F600 A1 T8000   ; set Z probe type to bltouch and the dive height + speeds
      G31 P25 X-29 Y0 Z0.80                          ; set Z probe trigger value, offset and trigger height(lower number farther away)1.8build 1.7glass
      M557 X10:320 Y20:290 S60                       ; probe from X=10 to 390, Y=10 to 290mm with a mesh spacing of 20mm
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4534 C9.565227e-8      ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                                            ; create bed heater output on bedheat and map it to sensor 0
      M143 H0 S120                                                     ; set temperature limit for heater 0 to 120C
      M307 H0 B0 S1.00                                                 ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                                          ; map heated bed to heater 0
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C0 R4700  ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                                             ; create nozzle heater output on e0heat and map it to sensor 1
      M143 H1 S280                                                     ; set temperature limit for heater 1 to 280C
      M307 H1 B0 S1.00                                                 ; disable bang-bang mode for heater  and set PWM limit
      M308 S2 P"e1temp" Y"thermistor" T100000 B4725 C0 R4700 ; configure sensor 2 as thermistor on pin e1temp
      M950 H2 C"e1heat" T2                                             ; create nozzle heater output on e1heat and map it to sensor 2
      M143 H2 S280                                                     ; set temperature limit for heater 2 to 280C
      M307 H2 B0 S1.00                                                 ; disable bang-bang mode for heater  and set PWM limit
      M950 F0 C"fan0" Q500                             ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                               ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                             ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45                                ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"fan2" Q500                             ; create fan 2 on pin fan2 and set its frequency
      M106 P2 S0 H-1                                   ; set fan 2 value. Thermostatic control is turned off
      M950 F3 C"duex.fan8" Q500                        ; create fan 3 on pin duex.fan8 and set its frequency
      M106 P3 S1 H2 T45                                ; set fan 3 value. Thermostatic control is turned on
      ; LEDs
      M950 F4 C"duex.fan6" ;Q500                       ; create LED 4 on pin duex.fan6 and set its frequency
      M106 P4 S128 H-1                                 ; set LED 4 value. Thermostatic control is turned OFF
      M950 F5 C"duex.fan7" ;Q500                       ; create LED 5 on pin duex.fan7 and set its frequency
      M106 P5 S128 H-1                                 ; set LED 5 value. Thermostatic control is turned OFF
      M563 P0 D0 H1 F0 S"Left"                         ; define tool 0 Left
      G10 P0 X0 Y0 Z0                       ; set tool 0 axis offsets y was .45
      G10 P0 R0 S0                                     ; set initial tool 0 active and standby temperatures to 0C
      M563 P1 D1 H2 X3 F2 S"Right"                     ; define tool 1 Right
      G10 P1 X0 Y0 Z0                ; set tool 1 axis offsets - adjust Y to alignn nozzle
      G10 P1 R0 S0                                     ; set initial tool 1 active and standby temperatures to 0C
      M563 P2 D0:1 H1:2 X0:3 F0:2 S"Copy"              ; define tool 2 Copy
      G10 P2 X90 Y0 U-90 S0 R0                         ; set tool 2 axis offsets (WAS 105)
      M567 P2 E1:1
      M568 P2 S1 ; turn on mixing for tool 2           ; set mix ratio 100% on both extruders
      ;G10 L1 P1 X0.0 Y0.0 Z-2.55
      M501                                             ; Record
      M593 F66.6
      ;T0 PO
      M575 P1 S1 B57600                                ;Panel due
      Muldex IDEX Duet2+Duex5
      Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
      Sapphire Pro with Duet2, with closed-loop motors
      custom high temp E3D tool changer with Duet2+Duex
      • sebkritikelundefined
        sebkritikel
        Few tenths of a millimeter? Anything like this:
        https://drmrehorst.blogspot.com/2020/12/x-axis-wobble-in-ummd.html
        Large(ish?) IDEX - 6HC, 1HCL
        Stratasys Dimension 1200es to 6HC Conversion
        martin7404undefined 1 Reply Last reply Reply Quote 0
          martin7404 @sebkritikel
          @sebkritikel https://www.youtube.com/watch?v=ImSpw3hpFJg
            sebkritikel
            @martin7404 said in Dual Markforged :idle IDEX carriage is not still during print:
            Muldex
            Looks very similar to what I suspected. Forgive me, as I am not an expert in the Markforged kinematics system (or even CoreXY at that). Can you spot any errant rotation on the U-stepper motor during those motion changes?
            The response of the U axis is consistent with the direction changes on combined tool 0 motion - mechanical, belt, etc? Unfortunately I don't have any specifics tips I could offer you at this time.
              @sebkritikel Yes everything looks OK. There is more it exactly the same when U is printing and X have to be idle, then X is making the same small movement back and forth. So I suspect a problem with one of the Y motors setup or in the electronics
              sebkritikelundefined 1 Reply Last reply Reply Quote 0
                sebkritikel @martin7404
                @martin7404 Maybe a long shot, but can you try tweaking the
                command? S1000? Just a guess
                • o_lampeundefined
                  o_lampe @martin7404
                  Maybe I'm wrong, but IMHO the U-axis specs (and other axis, if there are any) have to come after Z-axis.
                  Not sure, if that was M350-related or another command...
                  Better do it in the right order in every command.
                    martin7404
                    It is getting more and more interesting.
                    Today moved the Z motors to Wifi and X,Y,Y and u on DUEX
                    And my center Z , connected on P2 is not working, switched to P0 same story, made a mistake in updating config and it works look at this config.g, it is working properly, but it should not
                    ;M569 P0 S0                                     ; X physical drive 0 goes backwards
                    M569 P1 S1 ; Z
                    M569 P2 S1
                    M569 P3 S0
                    ;M569 P1 S0                                     ; Y right physical drive 1 goes backwards
                    ;M569 P2 S1                                      ; Y left physical drive 2 goes forwards
                    ;M569 P3 S1                                      ; U physical drive 3 goes forwards
                    M569 P5 S0 ; X
                    M569 P6 S1 ; Y right
                    M569 P7 S0 ; Y left
                    ;M569 P5 S1                                      ; Z left physical drive 5 goes backwards
                    ;M569 P6 S1                                     ; Z center physical drive 6 goes backwards
                    ;M569 P7 S0                                      ; Z right physical drive 7 goes forwards
                    M569 P9 S1 ; U
                    M584 X5 Y6:7 U9 Z1:0:3 E4:8                     ; set drive mapping
                    M906 X700 U700  I50
                    ;M574 Z2 S4
                    ; LEDs
                    M563 P1 D1 H2 X9 F2 S"Right"                     ; define tool 1 Right
                    M563 P2 D0:1 H1:2 X0:9 F0:2 S"Copy"              ; define tool 2 Copy
                    M567 P2 E1:1
                    M501                                             ; Record
                    This config is working OK,
                    But in M569 P2 is active and P0 is not active
                    IN M584 P0 is assigned and P2 not ?????
                    and this is working
                    something is wrong with my DUET wifi for sure
                      Can you send M98 P"config.g" and post the results?
                      Z799.2:799.2:799.2
                      Remove the duplicate entries for the Z axis. All the linear axis are configured as a single axis. It's only the extruders which remain independent and need to be configured per driver.
                      There appears to be an extra space after M906. Not sure it matters.
                      You can send the motor config commands by themselves to check that they are configured as expected. For instance, sending M906 in the console to see what the motor currents are actually set to.
                      martin7404undefined 2 Replies Last reply Reply Quote 1
                        @sebkritikel i tried 100 % idle current, no change
                          martin7404 @Phaedrux
                          @Phaedrux
                          M98 P"config.g"
                          HTTP is enabled on port 80
                          FTP is disabled
                          TELNET is disabled
                          Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
                          The M568 command is no longer needed
                          Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 723C
                          Warning: Heater 2 appears to be over-powered. If left on at full power, its temperature is predicted to reach 528C
                            @Phaedrux ```
                            m906
                            Motor current (mA) - X:700, Y:700, Z:500, U:700, E:1000:1000, idle factor 50%
                            3/8/2021, 11:35:56 PM	M98 P"config.g"
                              Phaedrux Moderator @martin7404
                              m906
                              How bout for the other commands? M92 M305 M201 M203 etc etc
                                @Phaedrux
                                m203
                                Max speeds (mm/min): X: 12000.0, Y: 12000.0, Z: 1000.0, U: 12000.0, E: 4200.0:4200.0, min. speed 30.00
                                3/9/2021, 7:12:00 AM	m201
                                Accelerations (mm/sec^2): X: 800.0, Y: 800.0, Z: 350.0, U: 800.0, E: 600.0:600.0
                                3/9/2021, 7:11:43 AM	m950
                                Error: M950: exactly one of FHJPS must be given
                                3/9/2021, 7:11:32 AM	m308
                                Error: M308: missing parameter 'S'
                                3/9/2021, 7:11:21 AM	m305
                                Error: M305: M305 has been replaced by M308 and M950 in RepRapFirmware 3
                                3/9/2021, 7:05:16 AM	m92
                                Steps/mm: X: 100.000, Y: 100.000, Z: 799.200, U: 100.000, E: 813.070:830.000
                                3/9/2021, 7:03:45 AM	Connection established
                                  martin7404
                                  I have a solution of the problem by chance.
                                  I am still waiting for my new Duet wifi , and the setup is the strange one with Z on duet and X,y and U on Duex.
                                  Because the machine is working somehow I continued with the commissioning I started Dual material print with both tools and in the begining of gcode both tools are defined temps with G10 and then with Tn P0 , both are activated for a moment in order to reach standby temp. Then G28 G29 etc....
                                  It happens that when both tools are activated and the idle is on standby there is no movement in stanby tool
                                    martin7404
                                    My new duet wifi is here , installed, updated firmware to 3.2.2, X,Y,U axes are back on mainboard, first print ongoing
                                      martin7404
                                      So it is printing with U carriage at the moment an the X carriage that is standby is dead still during print
                                        dc42 administrators @martin7404
                                        Assuming you home both carriages before doing a print, then both motors should have current flowing in them, unless you subsequently use M18 or M84 to set one or more motors idle.
                                          martin7404 @dc42
                                          @dc42 in the start G code there is always homing X U Y Z. But when I enable only Left or Right extruder with G10 in the beginning, during print the tool that was not active was moving a little back and forth with Y-axis changing direction.
                                          Then I found a faulty mainboard
                                          The whole time there was no unactivated axis motor
                                          So I think it is now sorted with new mainboard
