Z-Wobble vs temperature instability - Video
TL;DR: 'bang bang' is bad.
CNC Kitchen released an interesting video about using a Duet with Prusa MK3 and how poor thermal stabilization can cause Z-banding like artifacts.
i have noticed that one also.. so if the light flash fast its pid if its slowly on and off its bang bang..
I find it difficult to believe that a temperature change of +- 1 degree makes any difference. Maybe if you get to +_ 10 degrees I could agree with what is being said.
I would be more inclined to think that if your bed is heated by the same power supply that is used for everything else then that is much more likely to cause theses issues.
I did not notice if the testing included a configuration with an externally powered bed or not ....Lastly, this is a gut feeling and no testing has been done so don't jump on my case
My gut says 2deg cant possibly have that affect. Even if a plastic spacer is being effected by the temperature swing your talking sub micron changes and from the heating elements outward there is some stability and less resistance to change over a short time
https://goodcalculators.com/thermal-expansion-calculator/
Maybe still farfetched but seems more likely the flucuating load on the power supply could be effecting the driver and/or z motors causing inconsistencies relative to the target step or ms on layer change.
Dont Prusas have very high lead screws, like 8mm? -
Anyone have a dial indicator they can throw on the bed?
Not my gif.
@phaedrux said in Z-Wobble vs temperature instability - Video:
I have a high quality 0.0001" indicator that I have used to do this before, just too see how it all went down. Results were all over the place and I gave up. I need to try again at some point. Usually when I do these types of measurements(on machine tools) I have a nice big piece of steel around to hook the magbase too. On the printer I could see the effect of me walking around the room on the cantilevered bed machine I did the checks to.
I seen this exact effect with an old mk42 clone. Even on PID it would do it a little. It just seemed to have very slow response either from the heater or the thermistor, I'm not sure. I did several tests with it, and when I printed with the bed heat off, the z wobble effect disappeared entirely. Swapped the bed after that and never had the problem again.
We've been advising users to use PID for the bed for years because of exactly this issue.
My bed is 400x400mm 850W Bang bang controlled DC Aluminum 8mm bed. It does expand initially but settles after target is reached and doesn't rise/lower when heater is turned off/on. Temperature fluctuates +/-0.2 Degrees. The heater is turned always on when temperature goes below target temperature, which I don't think is a good way to control temperature via SSR as it connects so rapidly. Is there a way to add hysteresis to bang bang controlled bed (for RRF3.2 / Duet 3)?
My bed heat expansion:
https://youtu.be/tOQ3MXlgEK0 -
@visionary, I must admit that I am floored by the amount of change in your bed height .... I was expecting (gut feeling) 0.1 mm or so but a full 0.4 mm is amazing.
I am usually quite casual about heating up the bed before doing measurements except when doing a full bed probe. Your video clip has instilled in me new respect for heat related dimensional change. Thanks for posting !
@visionary said in Z-Wobble vs temperature instability - Video:
That's at the thermistor. Can it have larger fluctuations at other points of the bed?
Hard to say. The thermistor is embedded in silicon heater that is glued to 8mm aluminum plate. In order to measure temperature on other points I would need several thermistors placed in many different points or perhaps a really good thermal imager. Note that I never have had to re-level the bed because of it, but only set new endstop trigger height.
That´s a very interesting Topic
2 Weeks ago, i changed my 450x450x4mm stock-print bed to a face milled 10mm Cast Aluminum Plate with a 1200W AC Keenovo Heaterwith the new 3.3beta and PID, the temperature barely fluctuates slow around 0.1°C when heated to 65°C.
I also have a few 0.01 indicators (digital/analog) and will test that also with the plate alone and again with an additional 4mm borosilicate glass plate on top or a FR4 that i have laying around.
@Visionary
That thermal expansion is amazing !
How long was that in real time ? -
I think this effect is most common on thing PCB heaters. Silicone AC heater pads bonded to thick aluminum plates are a bit different.
From what I've gathered it's not so much the aluminum expanding and contracting as it is the traces of the heater itself rapidly heating and cooling that is causing it to change shape. The thermistor may only report a 1c oscillation, but the heater traces themselves will be changing much more than that since it's going from full power to no power.
Another interesting experiment that doesn't require equipment is to try to induce z-banding via bed temp changes. E.g. with PID enabled, and using the slicer's layer change script set alternate bed temperature every few layers (e.g. 60C, 50C, 60C, ...).
@phaedrux This is definitely where I've seen it happen. With the large PCB heater bed I initially had on my coreXY, it was profound. I could see it plainly by eye, no indicator necessary.
I took some time to test this pseudo z wobble thing out on one of my printers with the same configuration as the one in the video, aka Prusa style bed slinger. The biggest difference with mine is that it has a fair bit more glass between the edge of the heater and where the bed is supported on the ends. about 80mm. The 4mm boro bed measures 380x250 with a 200x200 keenovo 500w a/c heater in the center configured as PID but I also manually turned the bed on and off to maintain +-1°.
The heat input is not causing thermal growth in the way I was thinking its making the bed buckle downward in the center (expanding the heater side surface, dah). Using 3, Interapid tenths indicators (i'm converting from imperial) positioned at center and ends the center drops .2mm between 30 and 100° and the center indicator starts moving as soon a the bed gets power. When it noses over at 100c and cuts the power the bed comes back up .1mm then it wallows around until the temp starts to stabilize. When it does stabilize the temp fluctuates .4° and the indicator moves over a range of .01mm. Not bad. Moving all 3 indicators over the heater I did notice the bed is not bowing in a consistent arc. The hinge appears to be right at the edge of the silicone so the bed seems to be staying flat in the heater area just moving up and down.
Repeating the test with the different indicator positions and manually cycling the bed to get the +-1° it is creating the effect CNC kitchen described. The bed is moving over a range of .05mm which obviously is a lot. Even with a sloppy PID range of 1° is still moving .04mm so having PID doesn't guarantee you wont have a problem, the temp needs to be dialed in to hold at most .4 or .5° range in my case.
I would also theorize that if the heater wasnt producing consistent heat throughout then the part could be tilting as the heater cycled. The taller the print, the more pronounced this will become. Geez, this is getting messy
Another useful thing I got out of this was measuring the actual bed surface temperature. I have always checked it in the past with an IR gun and its been within a few degrees of the thermistor. While testing with the indicators I used thermocouples specifically designed to measure surface temp. Using 3 different setups to validate it is at best 20 deg lower than the thermistor is reading. Perhaps this is because the IR thermometer is measuring the source of IR not the surface temp of the glass. Not sure -
Next time any of you guys with bed slingers run a print would you mind looking to see if your bed temp is stable? When I auto tune the bed it's dead on and doesn't budge. Maybe .1deg here and there then when I start printing it starts to fluctuate with an occasional swing of almost 2 degrees. Now that I know the bed moves alot over this range I'm thinking this may be why I've been chasing quality issues for so long on this machine
@3dpmicro, I have two bed slingers. One is running in bang-bang mode and fluctuates about 2 degrees C. It is a 300X300 CR10. I see no obvious issues.
I also have a 500x500 CR10-5S with PWM heat control and it is rock steady.I do have issues here and there but bed heat is not anywhere near the top of my 'need to fix' list. If your printer is perfect in any other way (which by definition excludes a bed slinger IMHO), then you can worry about bed heat.
Thanks @jens55 Since I've recently verified that a 2 deg swing raises the bed up and down a total of 25% of my preferred layer height (.2mm) Im thinkin' that's a big'en
