    12864 display (ST7920) on Duet 3 Mini5+
    31
    4.3k
    • kgolgerundefined
      kgolger @PCR
      @pcr
      Does the adapter also work with a Duet2 Wifi (Ref. 1.04, Firmware 3.3)?
      DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
      • DIY-O-Sphereundefined
        DIY-O-Sphere @kgolger
        @kgolger
        The input will not match directly by plug. You have to wire them pin by pin.
        @PCR also provides a wired version
        (UTC+1)
          DIY-O-Sphere @DIY-O-Sphere
          Thanks to the support of @pcr i was able to replace my prototype board.
          Finally a clean wiring!
          (UTC+1)
          tecnoundefined 1 Reply Last reply Reply Quote 1
          • DIY-O-Sphereundefined DIY-O-Sphere referenced this topic
          • tecnoundefined
            tecno @DIY-O-Sphere
            @DIY-O-Sphere
            Hello , just got adapterboards from PCR and I can not get things to work OK here.
            Connected as below picture No shorts on 3-pin.
            M918 P1 E-4 F1999999
            M575 P1 S0 B57600 ; enable support for PanelDue
            M550 P"BigDelta"
              DIY-O-Sphere @tecno
              @tecno
              As far as I can tell, the cables on the display are plugged in backwards. I think the noses on the plugs are under the cable and look upwards. But the noses must be above the white boxes.
              (UTC+1)
              tecnoundefined 1 Reply Last reply Reply Quote 0
              • tecnoundefined
                tecno @DIY-O-Sphere
                @DIY-O-Sphere
                No go that way either. (Funny thing is that the display had the nose notches the other way! from factory)
                S O R R Y MY BAD Now working
                  DIY-O-Sphere @tecno
                  @tecno
                  The jumper is only required to enable the sd-card reader.
                  (UTC+1)
                  • tecnoundefined
                    tecno @DIY-O-Sphere
                    @DIY-O-Sphere
                    OK, what pins?
                      DIY-O-Sphere @tecno
                      @tecno
                      For the Mini you can shorten CD_LCD and CD_D pin with the jumper.
                      (UTC+1)
                      • PCRundefined
                        PCR
                        Just a information.
                        Have some left if somebody wants
                        repier37undefined 1 Reply Last reply Reply Quote 1
                        • repier37undefined
                          repier37 @PCR
                          @PCR I know this is old post, but if you have some left, I am interested
                          • chrishammundefined chrishamm referenced this topic
