    Displaying current extrusion volume possible?
    Duet Web Control wishlist
    tuning volumetric extrusion
    12
    18
    732
    • o_lampe
      o_lampe last edited by
      Hi guys,
      I'm playing with my new extruder and would like to know how much it extrudes in a real print.
      Is it possible to display extrusion volume in DWC? Printspeed, layerheight and layerwidth? should be available for calculations.
      I extruded in free air to get ballpark numbers, but real life is different.
      o_lampe Argo deckingman 3 Replies Last reply Reply Quote 4
      • o_lampe
        o_lampe @o_lampe last edited by
        @o_lampe
        It would be extra useful, if the background color changes (like with a zprobe) when the extruder skips steps.
        • Barracuda72
          Barracuda72 last edited by
          Would love it too...caculation of Extrusion Volume via Excel sheet seem so 2010 like πŸ˜‰
          • Argo
            Argo @o_lampe last edited by
            +1 that’s the only thing Iβ€˜m missing right now in the web interface πŸ™‚
            Chriss 1 Reply Last reply Reply Quote 2
            • Chriss
              Chriss @Argo last edited by
              +1 This would be nice. And I ask for a Endstop status too!
              samlogan87 1 Reply Last reply Reply Quote 2
              • ramisthand76
                ramisthand76 last edited by
                yes, this is really good
                https://tutuappvip.co/mobdro-download
                https://myfiosgateway.one/
                • samlogan87
                  samlogan87 @Chriss last edited by
                  @chriss end stop status is there. You need to install the external plugin for dwc and it shows up under machine I think it is
                  Custom Core-XY
                  Chriss 1 Reply Last reply Reply Quote 0
                  • Chriss
                    Chriss @samlogan87 last edited by
                    @samlogan87 Do you have a link to the external plugin by hand?
                    chrishamm 1 Reply Last reply Reply Quote 0
                    • chrishamm
                      chrishamm administrators @Chriss last edited by
                      @chriss https://github.com/Duet3D/DSF-Plugins/releases/tag/v3.4.0
                      Duet software engineer
                      • moth4017
                        moth4017 last edited by
                        i would like to see extrusion volume too
                        jackantubis 1 Reply Last reply Reply Quote 0
                        • jackantubis
                          jackantubis @moth4017 last edited by
                          Yes for me too πŸ™‚
                          • deckingman
                            deckingman @o_lampe last edited by
                            @o_lampe said in Displaying current extrusion volume possible?:
                            Hi guys,
                            What should the update criteria or interval be? i.e do you want volume per second say, or volume per n mm of head travel or volume per move or volume for the entire print? A simplified calculation would be the cross sectional area of the filament x the extruder travel.
                            Adamfilip 2 Replies Last reply Reply Quote 0
                            • Adamfilip
                              Adamfilip @deckingman last edited by
                              @deckingman current flow mm3/s updates once per second
                              oliof 1 Reply Last reply Reply Quote 0
                              • Adamfilip
                                @deckingman
                                Even adding a new Chart (new tab on top of existing layer chart) showing volume flow over time, similar to layer chart, so we could see entire time of print job or just last 30 seconds charted would be sweet
                                • oliof
                                  oliof @Adamfilip last edited by
                                  Since extrusion is rarely consistent over a full second on prints of common complexity due to curves, corners, layer changes, overhangs, bridges, infill, inner walls, and outer walls running at various speeds, showing you a sample of what flow was maybe one second ago seems of very little use to me.
                                  The only time it would be useful to me is when I try to determine the max flow of filament at a given temperature whichextrus is part of a tuning routine, where a realtime display also is not super helpful since you can play it by ear/eye it with a simple visual flag on your filament feeder showing when skips start to happen.
                                  I tend to look at the volumetric flow preview in Cura to ensure I didn't configure anything stupid, since if I were to see it while something prints its usually already too late. That could have some improvements (like "show extrusion rate where I point with the mouse") though ...
                                  <>Creality CR-20 IDEX Duet3 mini 5+<>RatRig V-Minion SKR RRF 1.1<>
                                  • deckingman
                                    deckingman @Adamfilip last edited by
                                    @adamfilip Given the variability of the volumetric flow rate, even within a single move (due to factors such as acceleration and deceleration) what would you do with the information? How would it be useful?
                                    • jackantubis
                                      jackantubis last edited by
                                      Yes for me it's max flow calibration of each new filament (avoid manual calculation). Sometimes too much monitoring is too much but love to see parameters flowing during print πŸ™‚
                                      • o_lampe
                                        o_lampe last edited by o_lampe
                                        I want to bump up this thread, since I'm tinkering with a toolchanger and want to optimize print settings for different nozzle sizes.
                                        I also saw that PrusaSlicer (and surely others too) changes extrusion width often.
                                        It's mentioned as a comment in the gcode file.
                                        ;WIDTH:0.727092
                                        Q: would it be possible to see the current extrusion width in the object model? Or extract it somehow?
