    Input Shaping and PA
    • PCR
      PCR last edited by
      i made some tests with PA an IS.
      Upper one without IS
      The other one with IS
      is this expected @dc42 ?
      This is my IS
      M593 P"ei3" F50.2
      • T3P3Tony
        T3P3Tony administrators @PCR last edited by
        @pcr can you describe the differences you are seeing? It might be easier with your description as well as the photos.
        Pressure advance works separately from input shaping, although as you have seen input shaping affects PA. I would get IS set to what you want then retune PA to match.
        www.duet3d.com
        PCR 1 Reply Last reply Reply Quote 0
        • PCR
          PCR @T3P3Tony last edited by
          @t3p3tony yep it seems that with IS in you need Higher PA ;(
          Argo 1 Reply Last reply Reply Quote 0
          • Referenced by  PCR PCR
          • Argo
            Argo @PCR last edited by
            @pcr
            My findings are that increasing PA to almost absurd levels for clean‘ish corners causes other issues in infill areas.
            What are your observations?
            Alex.cr 1 Reply Last reply Reply Quote 0
            • Alex.cr
              Alex.cr @Argo last edited by
              @argo said in Input Shaping and PA:
              @pcr
              I am running into similar issues. It also seems to effect small features such as small gear teeth.
              Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
              • sebkritikel
                sebkritikel last edited by
                The impacts on PA likely vary with the input shaping algorithm and targeted frequency. I'm running MZV at 23.85 HZ and my PA tuning strips look nearly identical.
                • Referenced by  oliof oliof
