    Software bundle 3.4.1RC1 now available
    Firmware installation
    10
    17
    1.7k
      I am pleased to announce the availability of software 3.4.1 release candidate 1. This fixes a number of bugs in 3.4.0 and improves the handling of and recovery from SPI errors when using an attached single board computer.
      Users of Duet + SBC should upgrade from the unstable feed on the Duet3D package server as usual. Other users can find the files at https://github.com/Duet3D/RepRapFirmware/releases/tag/3.4.1rc1.
      Here are the links to the change lists:
      • RepRapFirmware: https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-RC#reprapfirmware-341rc1
      • Duet Web Control: https://github.com/Duet3D/DuetWebControl/wiki/Changelog-DWC-3.x-RC#version-341-rc1
      • Duet Software Framework: https://github.com/Duet3D/DuetSoftwareFramework/wiki/Changelog-DSF-3.x-RC#version-341-rc1
      If you encounter problems with this release, please start a new thread to describe the issue.
      Del87undefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 4
      • Del87undefined
        Del87 @dc42
        @dc42 typo in changelog
        M952 nonlinear extrusion (must be M592)
        btw it is possible to add more decimal places to the A coefficient?
        Dmitry
        • T3P3Tonyundefined
          T3P3Tony administrators @Del87
          @del87 said in Software bundle 3.4.1RC1 now available:
          fixed this, thanks
          www.duet3d.com
          • T3P3Tonyundefined
            T3P3Tony administrators @dc42
            I would also encourage the use of the ReleaseMgr plugin by @MintyTrebor to help with highlighting the changes in the release notes that match your duet configuration.
            comments/notes here: https://forum.duet3d.com/topic/27582/releasemgr-dwc-plugin-v0-01-13-17-03-22
            www.duet3d.com
            • Alex.crundefined
              Alex.cr
              Are the standard plugins getting updates as well to keep them usable?
              Mainly speaking about closed loop and Input shaper.
              Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
              • BoAundefined
                BoA
                I uploaded to Duet3 standalone, and board no longer starts. I think I need to find some recovery from this state.
                Update from 3.4 -> 3.4.1RC1
                Edit. Restored 3.4 with bossa, flashed 3.4.1rc1 again - no issues this time. So some kind of a glitch 🙂
                  jay_s_uk @BoA
                  @boa i had an issue with 3.4 where the firmware got wiped from the board.
                  plug a USB in and see if a BOSSA port appears. If so, reflash the firmware
                  • chrishammundefined
                    chrishamm administrators @Alex.cr
                    @alex-cr There is no need to update them because they target 3.4 and not 3.4.0. If you run into problems, try to download and reinstall the affected plugin(s).
                    Duet software engineer
                    oozeBotundefined Alex.crundefined Exerqtorundefined 3 Replies Last reply Reply Quote 0
                    • oozeBotundefined
                      oozeBot @chrishamm
                      @dc42 We finally had time to install this on a machine. No issues so far, but testing has just begun. Something we'd really like to see addressed in 3.4.1 is fixing job progress when thumbnails are used as the current calculation appears to count the thumbnails as part of the print job, skewing the results.
                        @oozebot said in Software bundle 3.4.1RC1 now available:
                        This should only be an issue when the print file is small. It won't be changed in 3.4.1 but is already on the list for 3.5.
                        oozeBotundefined 1 Reply Last reply Reply Quote 0
                        • oozeBotundefined
                          oozeBot @dc42
                          @dc42 Thanks for the response. I do want to point out that it does affect larger jobs as well when multiple thumbnails are embedded. However, this isn't a showstopper - just something we'd like to see addressed soon as we really like the thumbnail feature!
                          • Alex.crundefined
                            Alex.cr @chrishamm
                            @chrishamm said in Software bundle 3.4.1RC1 now available:
                            After reinstall they worked again. Thanks for the help!
                            • Exerqtorundefined
                              Exerqtor @chrishamm
                              Having issues with the 3.4.0-b1 input shaping plugin not wanting to install on DWC 3.4.1-rc1 for some reason 🤔
                              EDIT: found out that the plugin was looking for DWC 3.4.0, changed it to 3.4 and repacked it so now it works ✌
                              CR3Dundefined 1 Reply Last reply Reply Quote 0
                              • CR3Dundefined
                                CR3D @Exerqtor
                                it still contains the following BUG:
                                https://forum.duet3d.com/topic/27288/rrf-3-4-beta-7-tool-offsets-issue
                                Regards Christian (CR-3D)
                                Christian from CR-3D
                                Homepage:
                                www.cr-3d.de
                                Facebook:
                                https://www.facebook.com/cr3d.official
                                Our Discord Server
                                https://discord.gg/SxRaPNuRdA
                                Thingiverse Profile:
                                https://www.thingiverse.com/cr-3d_official/about
                                  jay_s_uk @CR3D
                                  @cr3d no it doesnt
                                  • CR3Dundefined
                                    CR3D @jay_s_uk
                                    @jay_s_uk
                                    do you know the solution?
                                    I have made a video today...
                                    Homepage:
                                    www.cr-3d.de
                                    Facebook:
                                    Our Discord Server
                                      dc42 administrators @CR3D
                                      @cr3d I have replied to the thread that you linked to.
