    Issues with pressure advance since RRF 3.4
    308
    39.3k
    • gloomyandyundefined
      gloomyandy @Argo
      @Argo No problem, could you post your klipper and slicer settings (maybe post the gcode file you used with Klipper as that will have a lot of the details in it).
      Argoundefined 1 Reply Last reply Reply Quote 0
      • Argoundefined
        Argo @gloomyandy
        @gloomyandy
        BulgeCheck.gcode
        For Klipper itself nothing fancy.
        square corner velocity = 5 mm/s
        max feedrate = 350 mm/s
        max acceleration = 5000 mm/s
        Slicer speed settings:
        • gnydickundefined
          gnydick
          Been following this thread for a while now, 🎧 , and wondering if there's been any concrete, official update?
          • Argoundefined
            Argo @gnydick
            @gnydick
            Latest official statement is that the Duet team can't reproduce the issue so I assume there won't be a fix. That's why I'm glad I found a partial fix by using Super Slicer extrusion roles:
            https://forum.duet3d.com/post/298231
            At the moment I'm using 0.052 PA for every role except perimeter which use 0.075 PA (PLA filament).
            CCS86undefined 1 Reply Last reply Reply Quote 0
            • CCS86undefined
              CCS86 @Argo
              @Argo said in Issues with pressure advance since RRF 3.4:
              @gnydick
              As you found, that isn't great though, since the change in PA causes the printer to dwell.
                From my own testing a while ago I had noticed a difference in extruder jerk when I was getting some bulging corners. After retuning E jerk and PA it improved.
                Has anyone noticed a difference in E jerk?
                gnydickundefined Heartleander81undefined 2 Replies Last reply Reply Quote 0
                • gnydickundefined
                  gnydick @Phaedrux
                  @Phaedrux possibly. It at least seems to be very sensitive to it. Right now, with even just a low poly curved surface, each segment is ~1.5mm long, I get a bulge at every direction change.
                  • Heartleander81undefined
                    Heartleander81 @Phaedrux
                    @Phaedrux
                    Yes, definitely.
                    If I increase or decrease the extruder pressure, I can influence whether there is more or less overshoot. But I can't get rid of it completely.
                    • Argoundefined
                      Argo @CCS86
                      @CCS86
                      Yes it’s far from optimal. But at least parts are usable again. Though I had Klipper flashed and it hasn’t the flaws I’m not really into using Klipper. Just a personal preference. But wouldn’t wonder if someone switches because of that.
                      Heartleander81undefined 1 Reply Last reply Reply Quote 0
                        Heartleander81 @Argo
                        @Argo
                        I will only use it as an emergency backup. Sure if RRF fits again I'll switch back, I think. I'm already a fan of Duet.
                        But to test whether my hardware fits, I'll try Klippers. The last parts will arrive in the days for the test with me.
                        • jens55undefined
                          jens55
                          I don't know if this helps but I decided to run some tests. Two printers were used to compare the output. One is a CR10-S5 and one is a Jubilee printer. The CR10 is running a Duet2wifi and a Duex5 expansion card, the Jubilee is running a Duet3-6HC with the extruder being run off a tool board.
                          In both cases the extruder is a direct drive extruder. Both use firmware 3.4.0.
                          I used a pressure advance python script that I plugged the correct data into in order for it to generate a gcode file. The file prints a single line with fast and slow segments. Slow segment was 5 mm/sec, fast segment was 100 mm/sec.
                          The same filament (same roll) was used in both cases.
                          It probably has been well over a year since I last ran this pressure advance test but it used to show very clearly what the pressure advance should be set to.
                          I can report that the result was absolutely useless - there was no discernible difference in the layer lines. I ran pressure advance from 0.000 to 1.000 just to cover my bases but did more in-detail testing in the 0.000 to 0.080 range which is the expected range for a direct drive extruder.
                          There was an occasional abnormality here and there but it was not consistent and certainly was not repeatable.
                          I have set config.g on both printers to 0.01 as a wild guess. I could have chosen pretty much any figure between 0.00 to 0.08 as the test print showed no difference in the output.
                          When I was getting close to 1.0, I was seeing some issues but again, there was no clear 'this is good' and 'this is bad'.
                          I am left with two possible alternative explanations: 1) I don't know what I am doing or 2) PA is completely and utterly borked.
                          Since these tests have been a good indicator for PA before, I am leaning towards #2.
                          In all fairness, it did take me some time to tweak the python script to work with a multi extruder printer which initially also caused no change in the printed output. That was caused by me printing with extruder 1 but setting the pressure advance for extruder 0 ... doooohhhh ..... but I did correct that and feel that I have valid gcode files and pressure advance is simply not working. I have run M572 on the active extruder and as far as I can tell, the printer thinks it is set to the right pressure advance.
                          gloomyandyundefined Adrian52undefined 2 Replies Last reply Reply Quote 2
                            gloomyandy @jens55
                            @jens55 What was the version of firmware you were using when this test worked? Has anything else changed in your printer setup (hardware or configuration) since then?
                            If you think this is a problem with 3.4 that did not exist on an earlier version please switch back to that earlier version and publish the results from both. So far I do not think we have any examples that show this is a change between versions of the firmware (when using the same settings and hardware for both new and old versions). If you are using any 3.4 features (like input shaping), you may want to try disabling them and re-run the 3.4 test again before switching back to the older version.
                            jens55undefined 1 Reply Last reply Reply Quote 0
                            • jens55undefined
                              jens55 @gloomyandy
                              @gloomyandy, I do not use input shaping. It's been likely a year or more since I last ran these tests. I can not reasonably claim that nothing else has changed. Heck, I wouldn't even know where to start the recreating of old config.g files. I am not in a position to start reverting to old versions. I have neither the time nor the energy to go through that process in a thorough manner. I will likely continue my experimenting for a while but it isn't an exhaustive investigation (and is not meant as such). I am simply throwing my observations into the mix of things.
                              gloomyandyundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                                gloomyandy @jens55
                                @jens55 If you are not using any 3.4 features, I don't think switching to 3.3 would be a big problem, your 3.4 configuration should work I think.
                                  jay_s_uk @jens55
                                  @jens55 i've ran a 3.4 config with 3.2 quite happily
                                  • Argoundefined
                                    Argo @jay_s_uk
                                    @jay_s_uk
                                    Did you already have the time to print a comparison between RRF and Klipper on your setup?
                                    • Adrian52undefined
                                      Adrian52 @jens55
                                      @jens55 I was stimulated by your post to try again a gcode script I use to calibrate PA, adapted from a previous post. For me, this seems to work as expected:
                                      It does 4 lines at 20mm/sec, then 4 lines speeding up from 20mm/sec to 100mm/sec and back for each PA setting - I have pictured to speeding up section, where you can clearly see the effect of PA, and confirming the .04 I usually use.
                                      My system is pretty basic - duet2wifi with no SBC running 3.4.4, with mzv IS, single nozzle, direct drive orbiter 2.
                                      Adrian52undefined 1 Reply Last reply Reply Quote 0
                                      • Adrian52undefined
                                        Adrian52 @Adrian52
                                        @Adrian52 should add that the script is adapted from that posted by DonStauffer (https://forum.duet3d.com/user/donstauffer) here
                                        https://forum.duet3d.com/post/250961
                                        I found it quicker without a raft, so made an anchor piece to start the test strips . Apologies to DonStauffer for mangling your script.
                                        ;	set variables
                                        var StartX = -70
                                        var StartY = -25
                                        var LinesPerTest = 4
                                        var LinesBetweenTests = 4
                                        var AnchorLines = 10
                                        var TempBed = 60
                                        var TempTool = 195
                                        var ToolNum = 0
                                        var Ext1 = 0
                                        var Ext2 = 1
                                        var Width = 0.55
                                        var Height = 0.2
                                        var ExFactor = 1.0
                                        var Retract = 1.0
                                        var Prime = 0	;	Before Raft
                                        var PALow = 0.0
                                        var PAHigh = 0.07
                                        var PAIncrement = 0.01
                                        var SpeedRaft = 400
                                        var SpeedSlow = 1200
                                        var SpeedFast = 6000
                                        var SpeedTravelXY = 9000
                                        var SpeedTravelZ = 1200
                                        var SpeedRetract = 7200
                                        ;	Calculated and Utility Variables
                                        var TestCount = 1 + floor((var.PAHigh - var.PALow) / var.PAIncrement + 0.5)
                                        var FilFactor = var.ExFactor * var.Width * var.Height / (pi * 1.75 * 1.75 / 4)
                                        var PA = var.PALow - var.PAIncrement
                                        var Dist = 0
                                        ;	PREPARE
                                        T{var.ToolNum}
                                        M82	;	Extruder Absolute Mode
                                        ;	Heat Bed and set Hot Ends to Standby
                                        M400
                                        M117 "Heat"
                                        M140 S{var.TempBed}				;	set Bed Temp
                                        M568 P{var.ToolNum} S{var.TempTool} A2	;	set Tool Temp
                                        M116 H{var.ToolNum + 1} S1			;	Wait for temp
                                        G4 S12					;	Delay to Allow for Overshoot
                                        M116 H{var.ToolNum + 1} S1		;	Wait for Recovery
                                        M116 H0 S1					;	Wait for Bed
                                        M400
                                        M117 "Home"
                                        G1 Z30 F3000
                                        G30
                                        M400
                                        ;M117 "Anchor"
                                        ;	Go to StartX - Width *5, StartY
                                        G90	;	Absolute
                                        G92 E0
                                        G0 E{-var.Retract} F{var.SpeedRetract}
                                        G1 X{var.StartX - var.Width * (var.AnchorLines-4) } Y{var.StartY} F{var.SpeedTravelXY}
                                        G1 Z{var.Height} F{var.SpeedTravelZ}
                                        G91	;	Relative
                                        set var.Dist = (2 * var.TestCount * var.LinesPerTest + var.LinesBetweenTests * (var.TestCount - 1)) * var.Width
                                        M221 S110 ;set extrusion factor to 110% for anchor
                                        while iterations < var.AnchorLines
                                        	;	Draw anchor Line
                                        	G0 Y{var.Dist} E{abs(var.Dist) * var.FilFactor} F{var.SpeedRaft}
                                        	G92 E0
                                        	;	Break here if last time
                                        	if iterations + 1 >= var.AnchorLines
                                        		break
                                        	;	Move Over
                                        	G0 X{var.Width} E{var.Width * var.FilFactor} F{var.SpeedRaft}
                                        	G92 E0
                                        	set var.Dist = -var.Dist
                                        G0 E{-var.Retract} F{var.SpeedRetract}	;	Retract
                                        ;	BEGIN TEST PATTERN
                                        M400
                                        M117 "Test Pattern"
                                        ;	Go to StartX, StartY
                                        G90	;	Absolute
                                        G1 X{var.StartX} Y{var.StartY} F{var.SpeedTravelXY}
                                        G91	;	Relative
                                        while iterations < var.TestCount
                                        	;	set PA
                                        	set var.PA = var.PA + var.PAIncrement
                                        	M572 D{var.Ext1} S{var.PA}
                                        	M572 D{var.Ext2} S{var.PA}
                                        	echo "PA=",{var.PA}
                                        	;	Draw Reference Lines
                                        	while iterations < var.LinesPerTest
                                        		G0 E0 F{var.SpeedRetract}		;	Unretract
                                        		G0 X140 F{var.SpeedSlow} E{140 * var.FilFactor}
                                        		G92 E0
                                        		G1 Y{var.Width} F{var.SpeedTravelXY}
                                        		G1 X-140 F{var.SpeedTravelXY}
                                        	;	Draw Test Lines
                                        		G0 X35 F{var.SpeedSlow} E{35 * var.FilFactor}
                                        		G0 X70 F{var.SpeedFast} E{105 * var.FilFactor}
                                        		G0 X35 F{var.SpeedSlow} E{140 * var.FilFactor}
                                        		G92 E0
                                        	;	Move to start of next comparison
                                        	G1 Y{var.LinesBetweenTests * var.Width} F{var.SpeedTravelXY}
                                        ;	Finish up
                                        M400
                                        M117 "Done"
                                        G10 P0 S0 ; turn off temperature
                                        M140 S0  ;turn off bed heater
                                        G28  ; home
                                          jay_s_uk @Argo
                                          @Argo I have but I'm awaiting some feedback for I post anything
                                          • jens55undefined
                                            jens55 @Adrian52
                                            @Adrian52, thanks for posting the script and the results. I will see if I can get that working here!
