    24 volt fan with PWM control
    541
    • Zsevenundefined
      Zseven
      Hello, I have a question about the wiring of a fan.
      I have a 24 volt fan with PWM control.
      My motherboard is a 6XD.
      Can anyone help me?
      ![IMG_0529.jpeg](/assets/uploads/files/1717084212deee41b7e84888f7fc58090366cf.mp4 9702675-img_0529.jpeg) IMG_0530.jpeg
        What is your question? Please provide more information.
        Zsevenundefined 1 Reply Last reply Reply Quote 0
        • Zsevenundefined
          Zseven @Phaedrux
          @Phaedrux
          Which pins can I use?
            Can you give some information about your fan?
            Have you seen this? https://docs.duet3d.com/en/User_manual/Connecting_hardware/Fans_connecting
            • Zsevenundefined
              Zseven @Phaedrux
              @Phaedrux Yes, I have read it but not understood it.
              The fan has 3 pins 1x +24v 1x - 1x pwm
              Which is the pwm output?
              Outx-
              Or outx.tach
                https://docs.duet3d.com/en/User_manual/Connecting_hardware/Fans_connecting#connecting-fans-to-duet-fan-pins
                Click the tab for 4wire fans.
                • Zsevenundefined
                  Zseven @Phaedrux
                  @Phaedrux
                  I have connected the fan and set the parameter Q1000. If I set the speed in the DWC to 95%, the motor burns out!
                    Can you give more detail about what exactly you are connecting?
                    • Zsevenundefined
                      Zseven @Phaedrux
                      @Phaedrux
                      Hello ,
                      I have
                      +24V at Out5 / V_OutLC1
                      -Out 5 / GND
                      PWM at Out 5 / out5-
                      in config.g
                      M950 F2 C‘!out5’ Q1000
                      M106 P2 S0.0 H-1 C ‘Blower’
                      • oliofundefined
                        oliof @Zseven
                        @Zseven I assume this is a CPAP/vacuum blower control PCB and not a standard fan, is that correct?
                        • Zsevenundefined
                          Zseven @oliof
                          @oliof
                          Yes !
                          • oliofundefined
                            oliof @Zseven
                            @Zseven then you need to give us more details. Type of blower, how everything is wired between the PCB and the Blower and the control board, etc.
                            I highly doubt the Duet board can burn out the big blower because those fan ports are limited to 1A; I assume the blowers pull more than that.
                            Zsevenundefined 2 Replies Last reply Reply Quote 0
                            • Zsevenundefined
                              Zseven @oliof
                              @oliof
                              Hello ,
                              I have requested the data sheet from the manufacturer.
                              • Zsevenundefined
                                Zseven @oliof
                                @oliof
                                ello ,
                                I have now got a replacement as the last fan has burnt out.
                                DC7-24V brushless turbo fan motor 100000 rpm high speed aluminium alloy impeller with brushless motor and speed controller
                                I have now connected the fan direnkt to the 24V power supply and I can control it very well with the potentiometer
                                I have now measured the voltage at the potentiometer and between the red and black cable are 5V
                                The yellow cable should be the PWM signal.
                                How can I now control this fan with the Duet 6xd?
                                Witch pins ?
                                • oliofundefined
                                  oliof
                                  The wiring on the photo does not match the wiring on the PCB graphics.
                                  If you could provide a link to the listing and/or a full spec sheet that would help. "PWM control" can mean different things, in this case it could be 0-5V for example which would require extra circuitry.
                                  • Zsevenundefined
                                    Zseven @oliof
                                    @oliof
                                    I have fix it !
                                    • oliofundefined
                                      oliof @Zseven
                                      @Zseven please share your fixed setup for the benefit of all (-;
                                      • Zsevenundefined
                                        Zseven @oliof
                                        @oliof
                                        Hello ,
                                        here is my solution for the 6XD board
