    Ender 3 nothing working right
    My Duet controlled machine
    ender 3 duet 2 wifi help
    3.4k
    • waggonburner3undefined
      waggonburner3
      I just installed the duet 2 the pt100 board and duepanle uploaded firmware and used configuring tool and y runs to the top and keeps going then goes down to the end stop and stops. X hits the end stop tries to keep going then stops. Y hits end stop and moved forword slightly. Extruder works. I tried to print and it set up with a prime on the left side like normal then the z shots up 50mm and starts printing at that height. I'm at my wits end this is a week iv been fighting this thing. Please help.
      • mudcruzrundefined
        mudcruzr
        Please post your config.g and your homing files (homeall.g, homex.g, homey.g and homez.g)
          waggonburner3
          Ok I'll upload them this evening.
            Did you test the endstops? https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Test_endstop_switches
            waggonburner3undefined 1 Reply Last reply Reply Quote 1
              waggonburner3 @dc42
              @dc42 no I did not test them I will test them tonight after I post my settings.
                dc42 administrators @waggonburner3
                @waggonburner3 said in Ender 3 nothing working right:
                Also remember that 2-wire switch endstops use the 2 outer pins of the endstop connector on the Duet, which is not the same as on some other controller boards.
                  waggonburner3 @dc42
                  @dc42 yep that's how I have them hooked up.
                  • 3dmntbighkerundefined
                    3dmntbighker
                    Almost nothing on the Ender matches Duet wiring. I had to juggle wires everywhere on mine. Creality doesn't even follow industry standards when they exist šŸ˜ž
                    Let me add that mine prints amazingly well now šŸ™‚
                    Scratch built CoreXY with Maestro
                    Heavily modified Ender 3 with Maestro
                    MPCNC work in progress with Duet WiFi
                      waggonburner3
                      I reinstalled everything hardware and software all endstops working everything moving in the right direction. Now trying to get the heater 1 to tune and not fault out everytime.
                      Wyvernundefined 1 Reply Last reply Reply Quote 0
                      • mudcruzrundefined
                        mudcruzr
                        Glad you're getting everything sorted out.
                        • Wyvernundefined
                          Wyvern @waggonburner3
                          @waggonburner3
                          On my 24V 40W heater I had to reduce max PWM to 90% otherwise it will overshoot and fail the auto pid tune.
                            waggonburner3 @Wyvern
                            @wyvern thank you
                              waggonburner3
                              Thank you to everyone for the help I'm getting decent prints now I'll probably hooking up the bltouch in a day or so hope u can handle that by my self but I'm not holding my breath. Lol
                              • Wyvernundefined
                                Wyvern
                                Just a note, don't know if it was my network or what, but yesterday I could not connect the printer, after an hour of farting around I ran M552 on the panel due- the IP address changed after a month of flawless communication.
                                So keep that in mind if that happens to you.
                                  dc42 administrators @Wyvern
                                  @wyvern said in Ender 3 nothing working right:
                                  The IP address is allocated by the router. Most routers will allow you to set an IP address reservation so that the router always assigns the same IP address to a particular device. The router identifies devices from their MAC addresses. The MAC address of a Duet WiFi should never change unless you replace the WiFi module.
                                  • Martin1454undefined
                                    Martin1454
                                    I think it is amazing that you have installed an Duet wifi in a printer that cost almost the same as the duet šŸ˜„
                                    Looking foward to see then end result. šŸ™‚ šŸ‘
                                    3dmntbighkerundefined 1 Reply Last reply Reply Quote 1
                                      3dmntbighker @Martin1454
                                      @martin1454 said in Ender 3 nothing working right:
                                      My Maestro Ender 3 works fantastic. I saw it as a cheap way to acquire the basic bits, and build what I wanted. I probably could have sourced the same parts from China for less, but this was a lot easier and faster.
                                      dc42undefined 1 Reply Last reply Reply Quote 3
                                        dc42 administrators @3dmntbighker
                                        @3dmntbighker said in Ender 3 nothing working right:
                                        Yes, the Maestro is better matched to the Ender 3 from a pricing perspective, also the use of 24V power and lower current motors on the Ender 3 is a good match for the Maestro. A WiFi derivative of the Maestro (which would cost a little less to manufacture than the Ethernet version) might be an even better match, provided that the WiFi antenna can be kept out of the enclosure metalwork.
                                        • JamesMundefined
                                          JamesM
                                          I love my Ender 3 with the Duet Wifi...it works great and now greatly out performs my Taz 6 printer in both speed and quality. Granted...my ender 3 is far from stock using a geared printable extruder first was using a Greg's wade bowden variant and now one called the Pitan, linear guide for the bed, polycarbonate v-slot wheels on the x and z axis as well as dual z rods and stepper motors.
                                          The thing is so reliable now, just set and go.
                                          • Wyvernundefined
                                            Wyvern
                                            There are really only 4 tiers of 3D printers.
                                            Super low end- they just barely run and cost under $200, avoid.
                                            Clone/enthusiast grade- usually do a good job with a little tweaking and sourcing of better parts- it's possible to get high end results with enough patience. $250-500
                                            High end enthusiast- usually setup with all the goodies, think ultimaker- out of the box run like a expert adjusted/modified clone. $1000-3000
                                            Commercial grade- huge machines- huge price tag, made for business unless you just really like 3D printing and have a huge wallet $5000+++
                                            I have seen parts come out of my $270 Qidi Xone-2 come out as good as a ultimaker, the little guy has a mic6 build plate, 24V,32 bit board, all steel construction and 10 mm Z rods. 150X150X150 build size and weighs about 35lbs!
                                            My Folgertech FT-5 has about $900 now, I have yet to install some of the upgrades, but I am just now getting the Qidi quality- hoping to surpass it after the bed/z axis upgrades.
                                            IMHO it's worth putting a duet Wifi in a cheaper clone, part of the fun is making a clone/kit work as good or better than a $2000 printer, as they say built not bought.
