    My DIY Maestro powered Bed-Slinger (many photos inside)
    My Duet controlled machine
    12
    27
    2.9k
    • sonderzugundefined
      sonderzug
      Hi Max,
      the goal was to have all of the components inside the 30 cm cubed frame with none sticking out on the sides. Not definitely a must have but I think it's a rather elegant solution (again copied off the Protoworx printer).
      For my upgrade this design will also allow me to only use plain ball bearings instead of toothed idlers which is a win in my book.
      Tony, it was nice meeting you at the fair! Thanks for the compliment, and there is more to come!
      • mrehorstdmdundefined
        mrehorstdmd
        I've broken taps in plates before. Ouch! There's no good way to get them out short of using a hole saw to cut around them. Was that a custom heater or did you mill/drill the plate to match the heater you had?
        Are the bearings in the linear guides adjustable?
        It looks like a solid build...
        sinned6915undefined 1 Reply Last reply Reply Quote 0
        • jens55undefined
          jens55
          Broken taps can be removed with an EDM setup. Probably $50 to have it done but of course you need to remove the bed fro the printer.
            Can you post some more photos of the Z axis arrangement? I see it's belted, but can't see much else.
              sonderzug
              Hi everyone,
              thanks for the replies. The tap end is stuck there for sure, but it's not a big problem as 1) the position of the spring is variable as long as it's in the proximity of the respective support screw and 2) I have a second base plate left over. The only slight nuisance was that I had to go back to the hardware store to get another M3 tap.
              @mrehorstdmd ,
              the heater was custom made to my drawing. I had every component (well, the critical ones) designed before I ordered the first part for this build.
              the bearings are not adjustable, which is my big concern with these rails. That's the wrong choice I was referring to earlier. The Drylin W rail is also available with round guides (which is actually the standard variant). For the round rails, there are bearing blocks with pre-tension by spring or screw available.
              The play in the bearing blocks plus not perfectly tensioned belts lead to backlash which leads to un-round holes (at least that's my theory).
              @Phaedrux ,
              see below the setup of the z axis. There is a 8 mm rod underneath that connects both belts, which is driven by the stepper with a 2:1 reduction for extra resolution and torque. There are standard pulleys on each end driving the belt. There are little idler plates at the top of the frame, which are also used for tensioning the belt by pushing these upward (a screw through the upper frame member would propably be the more elegant solution).
              Edit: the obvious disadvantage is that the x-axis drops like a stone when the steppers have no power applied. I'm thinking about a little servo with a lever that will support the x-axis in the upmost position, once the print has finished. Another Idea would be to add a relais that could short-circuit one or two coils of the z-axis stepper motor, which would be controllable by G-Code, with the short-circuited coils having enough holding torque to steady the x-axis. Has anyone tried this? Problem could be that this acts like unplugging the stepper from the board while on, which is a no-go...
              Best regards, Niklas
              zaptaundefined 2 Replies Last reply Reply Quote 1
                mrehorstdmd
                Shorting the coils of the motor will not stop the bed from dropping. There is no current in the coils unless the shaft turns, and the current is somewhat proportional to how fast the shaft turns. I tried it and found that it slowed the drop a little at first, and then the torque slips and the bed drops like a rock (my bed assembly weights 3.5 kg).
                Someone at the makerspace used one of this type of motor/gearbox to drive a Z axis and it works well.
                I used a Rino 30:1 worm gear reducer in my printer. The bed doesn't move at all when power is cut, so in theory, I can resume prints after a power failure.
                You can buy motors with built in brakes, but they usually cost more than a motor with a gearbox.
                You can work up a mechanical arrangement similar to the brake that stops a seat belt from moving in a car.
                  A Former User
                  Re shorting coils, think the Up! Mini 2 does this with a relay as it will hold the bed in position even if the power fails with the original electronics. When run of the duet the bed falls like a brick when steppers are disabled. But the bed is tiny and the needed holding torque is minimal on the Up! Mini 2, no idea how well it scales but you could try it, and look into disabling the stepper driver just before shorting out the coils if it gets you enough hold.
                  • NitroFreakundefined
                    NitroFreak
                    Hi Niklas,
                    I think your best bet is one of three:
                    1. use a high inductance motor for the Z, they have a very high "turning resistance", I´d call it
                    2. use a higher gear ratio so that your normal motor is OK
                    3. Tension the belts a lot more
                      (4.) use a nema 23. That will have enough resistance when it is powered off.
                    Grüße,
                    Max
                      droftarts administrators
                      There was a thread about shorting motor coils to ground with a relay a couple of months ago, but can't find it now! Anyone's else's searching-foo better than mine?
                      • zaptaundefined
                        zapta @sonderzug
                        @sonderzug said in My DIY Maestro powered Bed-Slinger (many photos inside):
                        Counter balance it with some weight? Use a warm gear between the motor and the belt?
                          mrehorstdmd @A Former User
                          @bearer Shorting the coils does not stop the motor from turning. There is no current in the coils unless and until the motor turns. If the motor turns, the bed is by definition, dropping.
                          Without a counterweight, the gears/screws/nuts remain engaged at all times regardless of direction of motion so there's no possibility of backlash. If you unload the gears/screws/nuts by adding a counterweight, you introduce the possibility of backlash.
                          Here's a belt driven Z axis that does not move when power is cut:
                            A Former User
                            I haven't studied the solution employed by tiertime, but it seems the 19v supply for the drivers is either feed to the drivers, or shorted to ground, resulting in the the bed not dropping if the motors are disabled and/or the power is lost; and if it moves a fraction of a 0.9 degree step and stays there then close enough. They do have a power fail resume function, but as it doesn't preheat the machine its of limited use. On the other hand power failure doesn't result in the bed dropping backriving the board with potential "high" voltage.
                            I'm pretty sure the lost microsteps + theoretical backlash in gears, axle torsion and belt strech is comparable to whatever motion is present on the Up Mini 2 when compared to the overall rigidity of the machine (which on the Up Mini 2 is a joke). Everything moves, not everything matters.
                              It was @smece in this thread https://forum.duet3d.com/topic/12341/e-_endstop-laser-and-rotary-filament-sensors-motor-enable, who was going to...
                              make small daugterpcb
                              ... using ...
                              the ENABLE signal I need is the ENN net found on expansion port pin 28, so even easier to access
                              ... to check the motor status and short the coils if turned off. Did he ever do it?!
                              @mrehorstdmd shorting the coils certainly makes the harder to turn, and has been used on a number of printers to hold the bed at power off. If the weight of the bed does cause the motor to turn still, there may at least be enough resistance to stop the bed "dropping like a stone" and causing damage. So may be an easier modification than redesigning the Z axis. Depends on what the objective is.
                                A Former User @droftarts
                                @droftarts said in My DIY Maestro powered Bed-Slinger (many photos inside):
                                yes, works as expected 😄
                                z motor is not very powerful so with original screw on ender5 it "kinda works" so with the glass off the bed it holds the bed, but barely, if there's a print on the bed it will sometimes slowly start to drop.. maybe glass is too heavy, there are also the big hands stiffening the bed, the precision piezo sensors.. but it holds it from "dropping like a stone" as it did before this mod. I'm now waiting for the new replacement screw (with 1 start compared to 4 starts on original one) and with backlash nut (not required for this use but backlash nut adds additional tension to the screw increasing friction) it will stay still even without this mod and with this mod I believe it will be rock solid. Unfortunately, we had a month of post on strike here so everything is now delayed 😞 I doubt I'll get the new screw this year.. I will also replace original motor with the .9 degree one as I have few of them but they are high impedance so too slow for anything else so why not use it to increase precission even more :D, Z is slow anyhow 🙂
                                  mrehorstdmd
                                  If all you're worried about is the bed somehow doing some damage when it drops, almost anything can be used including putting a couple springs at the bottom of the Z axis so the bed will make a soft landing.
                                  If you want to absolutely stop bed motion when power is lost so that you can resume a print after a power interruption, you need either a brake, a worm gear drive, or some other solution that locks the bed in position. A high ratio conventional gearbox (or a series of pulleys and belts) may work if the detent torque of the motor multiplied by the gear ratio is greater than the torque created by the potentially falling mass.
                                  If the bed drops and you want to resume a print, you have to have an accurately calibrated Z ordinate for the bottom of the Z axis. Then you can just move the bed back to the previous Z ordinate and resume printing. It might be useful to use a switch at the bottom of the Z axis.
                                    Phaedrux Moderator @A Former User
                                    @smece said in My DIY Maestro powered Bed-Slinger (many photos inside):
                                    I think you'll likely notice the 1 start lead screw is more than enough to stop any automatic downward movement. The backlash nut would likely add enough extra friction in that case to allow for easy binding. At least that's what I found with my 1mm pitch single start lead screws. My bed assembly is very heavy and during a power loss there is no movement whatsoever, even when loaded up with several kilograms of filament on the bed. When I first tested the anti backlash nuts the z axis would bind and stall at the start of long travel moves. I had to reduce the acceleration dramatically to overcome that. I gave up on the anti backlash nuts after that.
                                      A Former User @Phaedrux
                                      @Phaedrux said in My DIY Maestro powered Bed-Slinger (many photos inside):
                                      I'll do the test when the darn thing finally arrives... with a month of strike the amount of backlog our post office now has and the half of January in holidays I'm lucky if I get it during winter 😞
                                      My first experience with Z screws and anti-backlash nuts was some ~10 years ago on RapMan by bitsfrombytes (the duet team surely knows them, they were from uk too, one of the pioneers) and they used plexy + two M8 screws with a spring to create anti-backlash contraption. The first mod for rapman was to remove that spring as a bed that heavy had no need for those springs 🙂 and that simple mod made the Z work great (and mind they used nema23 motors, quite power ones) ... so yes I also believe that nut will lose the anti-backlash part ... but .. will know when it arrive 🙂
                                        A Former User @mrehorstdmd
                                        @mrehorstdmd said in My DIY Maestro powered Bed-Slinger (many photos inside):
                                        It can still generate quite the voltage spike even if the mechanical fall is cushioned; and again - print resume with shorted coils work just fine for the tolerances applicable in consumer 3d printer as proven by Tiertimes design in the Up Mini 2. I can find a flat earther leaflet for you if you wanna keep arguing pointless stuff:P
                                          sonderzug
                                          Hey all,
                                          thanks for the discussion around keeping the bed, or x-axis beam in my case, steady without enabled steppers. Let's postpone this discussion though, as it seems to get a little pointless without test results from my side.
                                          ... I hope to make some progress this weekend.
                                          • sinned6915undefined
                                            sinned6915 @mrehorstdmd
                                            You can use Alum to dissolve a broken drill or steel tap in aluminum.
