    PrusaSlicer 2.2 released
    prusaslicer
    18
    46
    3.4k
      I first tried PrusaSlicer two days ago, because I needed to test the new object cancellation facility in RRF, which relies on object labelling. I am impressed by it, and planning to switch over to it from S3D. It has other benefits too, such as the built-in file upload to Duets and support for firmware retraction.
      droftartsundefined 1 Reply Last reply Reply Quote 2
        droftarts administrators @dc42
        @dc42 said in PrusaSlicer 2.2 released:
        I was about to ask which slicers support that! Any others?
        There was a couple of things in the video I liked the look of. The main thing missing, for me, seems to be tree support, but I don’t use it that frequently in Cura.
        • whosrdaddyundefined
          whosrdaddy
          Been using prusaslicer/Slic3r PE for years now and has never let me down...
          Now that we finally have layer pause option with v2.2 it's sad that it only emits M601 but RRF only support M226 for pausing the print.
          @dc42 can you implement M601 as an alias for M226 in the firmware? 😉
          droftartsundefined zaptaundefined 2 Replies Last reply Reply Quote 0
            droftarts administrators @whosrdaddy
            @whosrdaddy I don’t think M601 is defined, so you can make a macro in the sys folder called M601.g which will be called when RRF encounters it in Gcode. Then put M226 in that macro. At least, in theory...
              whosrdaddy
              @droftarts didn't know about that one.
              Printer is busy printing atm but will test this asap, that would be awesome! 👌
              • mrehorstdmdundefined
                mrehorstdmd
                I sliced a 42 MB STL file to a 280 MB gcode file a couple days ago and it ran fine on the printer. I've had trouble in the past with slicing very large STL/gcode files, so they must have fixed something.
                  @whosrdaddy from the video, I thought you could put any Gcode in at a particular layer? Haven’t watched it again, though.
                  whosrdaddyundefined 1 Reply Last reply Reply Quote 0
                  • zaptaundefined
                    zapta @matt3o
                    @matt3o said in PrusaSlicer 2.2 released:
                    my 2D printer still jams paper...
                    Please post your config.h file.
                    • zaptaundefined
                      zapta @whosrdaddy
                      @whosrdaddy said in PrusaSlicer 2.2 released:
                      I saw the announcement about this feature. Previous version had an easy to use pause at layer option that worked very well for me.
                      I just move the vertical layer slider to the layer I want and click on the [+] icon next to the slider. The printer then pauses at that layer, and you can change filament or just resume with same filament.
                        whosrdaddy @droftarts
                        @droftarts Lol now that you say it, indeed you can. I was too focused on the "pause" thing 😉
                        • oliofundefined
                          oliof @mrehorstdmd
                          @mrehorstdmd they did significant changes to their movement planner. Maybe that helped.
                          • zaptaundefined
                            zapta @PaulHew
                            @PaulHew said in PrusaSlicer 2.2 released:
                            S3D, could not justify the cost. £130 per year.
                            S3D is in decline, both the company and the product. I have a paid license but I now prefer the free slicers.
                            You can get some insight on how the company operates here: https://www.glassdoor.com/Reviews/Simplify3D-Reviews-E1187369.htm
                            (They could learn a thing or two from Duet3d which is smaller but is more productive and provides much better customer support.)
                              mrehorstdmd @oliof
                              @oliof so it seems!
                              • Turboundefined
                                Turbo
                                It's now my go to slicer instead of Cura, but there's one major issue for me and thats how it handles dual extrusion. Ill set it to extruder 2 and it'll heat up extruder 1, and when 1 heats up, it tries to extrude out of heater 2. I have to manually heat up extruder 2 before sending it gcode, otherwise things aren't pretty
                                Cant stop tuning wont stop tuning.
                                Dbot, Custom i3, Voron 0&2
                                • Danalundefined
                                  Danal @Turbo
                                  @Turbo said in PrusaSlicer 2.2 released:
                                  Hmmm... I'm running SlicerPE output into a toolchanging printer with no editing of the G-Code. Everything heats just fine. Hmmm...
                                  Do you have "wait for temp" g-code in your TPOST macros?
                                  Turboundefined 1 Reply Last reply Reply Quote 0
                                  • Turboundefined
                                    Turbo @Danal
                                    @Danal Is that within prusaslicer or the firmware? never used dual extrusion before and i half expected it to just insert t0/t1/etc into the gcode. i open up a thread about it:
                                    My Post
                                    • insertnamehereundefined
                                      insertnamehere
                                      Another slicer to try is Slic3r++
                                      It's a fork of PrusaSlicer, and is currently at 2.2, but also include a lot of extra functionality, like top layer ironing, (see image). Gives great results.
                                      droftartsundefined CaiJonasundefined 2 Replies Last reply Reply Quote 0
                                        droftarts administrators @insertnamehere
                                        @insertnamehere said in PrusaSlicer 2.2 released:
                                        This one? https://github.com/supermerill/Slic3r
                                        insertnamehereundefined 1 Reply Last reply Reply Quote 0
                                          insertnamehere @droftarts
                                          @droftarts said in PrusaSlicer 2.2 released:
                                          Yes, that's it.
                                          • zaptaundefined
                                            zapta
                                            Apparently PrusaSlicer disables the Filaments management tab in Configuration Assistance for duet printers. That tab is enabled only for prusa and third part printers but not for custom printers. To reproduce install PrusaSlicer with only a duet printer and see if you can see that tab.
                                            Developers say it's by design bu I don't understand the logic behind it.
                                            PaulHewundefined matt3oundefined 2 Replies Last reply Reply Quote 0
