    PrusaSlicer 2.2 released
    prusaslicer
    18
    46
    3.3k
      droftarts administrators @whosrdaddy
      @whosrdaddy from the video, I thought you could put any Gcode in at a particular layer? Haven’t watched it again, though.
      whosrdaddyundefined 1 Reply Last reply Reply Quote 0
      • zaptaundefined
        zapta @matt3o
        @matt3o said in PrusaSlicer 2.2 released:
        my 2D printer still jams paper...
        Please post your config.h file.
        • zaptaundefined
          zapta @whosrdaddy
          @whosrdaddy said in PrusaSlicer 2.2 released:
          Now that we finally have layer pause option with v2.2
          I saw the announcement about this feature. Previous version had an easy to use pause at layer option that worked very well for me.
          I just move the vertical layer slider to the layer I want and click on the [+] icon next to the slider. The printer then pauses at that layer, and you can change filament or just resume with same filament.
          • whosrdaddyundefined
            whosrdaddy @droftarts
            @droftarts Lol now that you say it, indeed you can. I was too focused on the "pause" thing 😉
            • oliofundefined
              oliof @mrehorstdmd
              @mrehorstdmd they did significant changes to their movement planner. Maybe that helped.
              • zaptaundefined
                zapta @PaulHew
                @PaulHew said in PrusaSlicer 2.2 released:
                S3D, could not justify the cost. £130 per year.
                S3D is in decline, both the company and the product. I have a paid license but I now prefer the free slicers.
                You can get some insight on how the company operates here: https://www.glassdoor.com/Reviews/Simplify3D-Reviews-E1187369.htm
                (They could learn a thing or two from Duet3d which is smaller but is more productive and provides much better customer support.)
                • mrehorstdmdundefined
                  mrehorstdmd @oliof
                  @oliof so it seems!
                  • Turboundefined
                    Turbo
                    It's now my go to slicer instead of Cura, but there's one major issue for me and thats how it handles dual extrusion. Ill set it to extruder 2 and it'll heat up extruder 1, and when 1 heats up, it tries to extrude out of heater 2. I have to manually heat up extruder 2 before sending it gcode, otherwise things aren't pretty
                    Cant stop tuning wont stop tuning.
                    Dbot, Custom i3, Voron 0&2
                    • Danalundefined
                      Danal @Turbo
                      @Turbo said in PrusaSlicer 2.2 released:
                      Hmmm... I'm running SlicerPE output into a toolchanging printer with no editing of the G-Code. Everything heats just fine. Hmmm...
                      Do you have "wait for temp" g-code in your TPOST macros?
                      Turboundefined 1 Reply Last reply Reply Quote 0
                      • Turboundefined
                        Turbo @Danal
                        @Danal Is that within prusaslicer or the firmware? never used dual extrusion before and i half expected it to just insert t0/t1/etc into the gcode. i open up a thread about it:
                        My Post
                        • insertnamehereundefined
                          insertnamehere
                          Another slicer to try is Slic3r++
                          It's a fork of PrusaSlicer, and is currently at 2.2, but also include a lot of extra functionality, like top layer ironing, (see image). Gives great results.
                          droftartsundefined CaiJonasundefined 2 Replies Last reply Reply Quote 0
                            droftarts administrators @insertnamehere
                            @insertnamehere said in PrusaSlicer 2.2 released:
                            This one? https://github.com/supermerill/Slic3r
                            insertnamehereundefined 1 Reply Last reply Reply Quote 0
                              insertnamehere @droftarts
                              @droftarts said in PrusaSlicer 2.2 released:
                              Yes, that's it.
                              • zaptaundefined
                                zapta
                                Apparently PrusaSlicer disables the Filaments management tab in Configuration Assistance for duet printers. That tab is enabled only for prusa and third part printers but not for custom printers. To reproduce install PrusaSlicer with only a duet printer and see if you can see that tab.
                                Developers say it's by design bu I don't understand the logic behind it.
                                PaulHewundefined matt3oundefined 2 Replies Last reply Reply Quote 0
                                • PaulHewundefined
                                  PaulHew @zapta
                                  @zapta Is this the tab you are referring to?
                                  • arhiundefined
                                    arhi
                                    I'm slowly migrating from s3d to ideamaker but am constantly checking out slic3r and ps too and they are producing very good results. PS2.2 fixed the major issue I had with slic3r/PS and that's "lot more movement than s3d/ideamaker for same object", looks like they figured out how to optimize moves.
                                    • matt3oundefined
                                      matt3o @zapta
                                      @zapta I believe the only option that is hidden is the "machine limits" one that is limited to marlin for some reason. As far as I understand it only helps with print-time-prediction though
                                      • CaiJonasundefined
                                        CaiJonas @insertnamehere
                                        @insertnamehere thx for the info, didn't know that
                                        • zaptaundefined
                                          zapta @PaulHew
                                          @PaulHew , that screenshot seems to be an older version (?). I meant for a different Filaments tab.
                                          Look for the top menus for Configuration Assistant or something similar. This is a configuration wizard. If you find it, see if you have on the left hand a tab for managing the filaments that will show up in the slicer.
                                          But if you define a Prusa or Creality printer instead of a custom printer you get also the Filament tab
                                          • PaulHewundefined
                                            PaulHew
                                            @zapta Running latest 2.2.0
