    PrusaSlicer 2.2 released
    prusaslicer
    18
    46
    3.4k
    • oliofundefined
      oliof @mrehorstdmd
      @mrehorstdmd they did significant changes to their movement planner. Maybe that helped.
      • zaptaundefined
        zapta @PaulHew
        @PaulHew said in PrusaSlicer 2.2 released:
        S3D, could not justify the cost. £130 per year.
        S3D is in decline, both the company and the product. I have a paid license but I now prefer the free slicers.
        You can get some insight on how the company operates here: https://www.glassdoor.com/Reviews/Simplify3D-Reviews-E1187369.htm
        (They could learn a thing or two from Duet3d which is smaller but is more productive and provides much better customer support.)
        • mrehorstdmdundefined
          mrehorstdmd @oliof
          @oliof so it seems!
          • Turboundefined
            Turbo
            It's now my go to slicer instead of Cura, but there's one major issue for me and thats how it handles dual extrusion. Ill set it to extruder 2 and it'll heat up extruder 1, and when 1 heats up, it tries to extrude out of heater 2. I have to manually heat up extruder 2 before sending it gcode, otherwise things aren't pretty
            Cant stop tuning wont stop tuning.
            Dbot, Custom i3, Voron 0&2
            • Danalundefined
              Danal @Turbo
              @Turbo said in PrusaSlicer 2.2 released:
              Hmmm... I'm running SlicerPE output into a toolchanging printer with no editing of the G-Code. Everything heats just fine. Hmmm...
              Do you have "wait for temp" g-code in your TPOST macros?
              Turboundefined 1 Reply Last reply Reply Quote 0
              • Turboundefined
                Turbo @Danal
                @Danal Is that within prusaslicer or the firmware? never used dual extrusion before and i half expected it to just insert t0/t1/etc into the gcode. i open up a thread about it:
                My Post
                • insertnamehereundefined
                  insertnamehere
                  Another slicer to try is Slic3r++
                  It's a fork of PrusaSlicer, and is currently at 2.2, but also include a lot of extra functionality, like top layer ironing, (see image). Gives great results.
                  droftartsundefined CaiJonasundefined 2 Replies Last reply Reply Quote 0
                    droftarts administrators @insertnamehere
                    @insertnamehere said in PrusaSlicer 2.2 released:
                    This one? https://github.com/supermerill/Slic3r
                    insertnamehereundefined 1 Reply Last reply Reply Quote 0
                      insertnamehere @droftarts
                      @droftarts said in PrusaSlicer 2.2 released:
                      Yes, that's it.
                      • zaptaundefined
                        zapta
                        Apparently PrusaSlicer disables the Filaments management tab in Configuration Assistance for duet printers. That tab is enabled only for prusa and third part printers but not for custom printers. To reproduce install PrusaSlicer with only a duet printer and see if you can see that tab.
                        Developers say it's by design bu I don't understand the logic behind it.
                        PaulHewundefined matt3oundefined 2 Replies Last reply Reply Quote 0
                        • PaulHewundefined
                          PaulHew @zapta
                          @zapta Is this the tab you are referring to?
                          • arhiundefined
                            arhi
                            I'm slowly migrating from s3d to ideamaker but am constantly checking out slic3r and ps too and they are producing very good results. PS2.2 fixed the major issue I had with slic3r/PS and that's "lot more movement than s3d/ideamaker for same object", looks like they figured out how to optimize moves.
                            • matt3oundefined
                              matt3o @zapta
                              @zapta I believe the only option that is hidden is the "machine limits" one that is limited to marlin for some reason. As far as I understand it only helps with print-time-prediction though
                              • CaiJonasundefined
                                CaiJonas @insertnamehere
                                @insertnamehere thx for the info, didn't know that
                                • zaptaundefined
                                  zapta @PaulHew
                                  @PaulHew , that screenshot seems to be an older version (?). I meant for a different Filaments tab.
                                  Look for the top menus for Configuration Assistant or something similar. This is a configuration wizard. If you find it, see if you have on the left hand a tab for managing the filaments that will show up in the slicer.
                                  But if you define a Prusa or Creality printer instead of a custom printer you get also the Filament tab
                                  • PaulHewundefined
                                    PaulHew
                                    @zapta Running latest 2.2.0
                                    • zaptaundefined
                                      zapta @PaulHew
                                      @PaulHew, do you have only the Duet printer defined? If so, when you open Configuration | Configuration Assistant, do you see the Filaments tab on the left?
                                      (your screen looks different than mine, possibly OS dependent).
                                      • PaulHewundefined
                                        PaulHew
                                        @zapta Ubuntu 18.04 (I know nothing about it!)
                                        I deleted my config folder so PrusaSlicer was a vanilla ish!
                                        I now see what you mean.
                                        For instance, if you do not select a 'Prusa Printer' the filament thing on the side of Config Wizard disappears.
                                        If you only have a 'Custom Printer' you will not see any filaments!
                                        Just been playing with it further.
                                        Selected the Prusa Mini, all the filaments, Creality Ender3.
                                        You can change the dependency of the filament to 'Detached' and then use it with any printer, by using the 'Detach from system preset' button, on the right.
                                        Hope that helps.
                                        Paul.
                                        zaptaundefined 1 Reply Last reply Reply Quote 1
                                        • zaptaundefined
                                          zapta @PaulHew
                                          @PaulHew, thanks, I will give it a try.
                                          I don't understand why the developers singled out custom FDM printers. Are the stock filament profiles customized per printer brand/model?
                                          PaulHewundefined 1 Reply Last reply Reply Quote 0
                                          • PaulHewundefined
                                            PaulHew @zapta
                                            @zapta Just selecting the Ender3 you get 2 Prusa and 3 generic abs, petg and pla.
                                            I use someones 'Config Bundle' for my Railcore, as he understands it better! I just tweak his profiles to suit my filamernt for my RC, like Z Offset.
                                            Sounds like you are right, they have probably tested those 'Premium' filaments and dialed them in for their printers.
                                            P.
