Industrial 3D printer designed & made in NZ
My Duet controlled machine
10
22
1.8k
    Christoph13524
    Nice ABS prints!
    What's the chamber temperature?
    And is the bed heated? When yes, is it as high as the chamber temperature is?
    Printing with an UMO+
    Duet 2 WiFi 1.04
      T3P3Tony administrators @nz_andy
      @nz_andy thanks for sharing, looking forward to adding you guys to the list of Duet controlled machines!
        nz_andy
        A short video showing this machine running.
        https://youtu.be/iDEyjMv7538
        https://palmerdesign.co.nz/
        https://www.instagram.com/palmerdesign.co.nz/
        undefined 1 Reply Last reply 6 Feb 2020, 21:01 Reply Quote 1
          Phaedrux Moderator @nz_andy
          @nz_andy Very fast! But what is the brief pause before the travel move? Retraction?
            nz_andy
            Hi Christoph, that is retraction, so some tweaking to do.
            It is the accuracy at speed that is important don't you think, many printers can run fast but start to round out corners etc, especially when you have a big printer like this, 520x520x600 build heated chamber.
            We are printing 470mm long ABS parts that shrink 2mm on cool-down and end up with 0.2mm end to end accuracy.
            This printer uses lead screws, this would seem a bit crazy to some people, Our gantry and print head are very light, custom machined and titanium 3D printed print head. We have not spared expense as this is our workhorse. Our V2 printer is nearly finished now.
            Answering your earlier questions, we do have heated bed, but it was not turned on for this print. Chamber at 85degC with vacuum bed on PEI.
              nz_andy
              A few pictures of some big prints we did last year on this machine, these are ABS:
              undefined 1 Reply Last reply 14 Feb 2020, 10:27 Reply Quote 1
                fma
                Very impressive!
                Frédéric
                  richardmckenna @nz_andy
                  @nz_andy wow! How many parts is that top one made up of and any idea what it weighs?
                    nz_andy
                    That big print was about 18KG or 40lb, it was about 12 parts, we could have done it in 6 parts but it was more economic to break it up more. The finish is a bead blast before painting.
                      nz_andy
                      A few pictures of our V2 machine. the printer is about 6.5ft tall.
                      It has heated filament chamber and auto filament change over.
                      Heated bed is 1kw, chamber is 5kw
                        It's a beast! Thanks for sharing.
                          jens55
                          Impressive! .... are there any projections on retail price (afraid to ask but what the hell)
                            nz_andy
                            Thanks for the encouragement. At this point we are just making machines for our own use and need more to keep up with our printing work.
                            We have had a few people ask lately and maybe we should consider selling these because of the amount of time that has gone into the design. At a guess it would be about 80K USD for one of these.
                            undefined undefined undefined 3 Replies Last reply 21 Nov 2020, 05:29 Reply Quote 1
                              aprz @nz_andy
                              @nz_andy said in Industrial 3D printer designed & made in NZ:
                              Wow great job. Those parts came out great.👍
                                jens55 @nz_andy
                                Thanks for the encouragement. At a guess it would be about 80K USD for one of these.
                                Gasp .... but yeah, that is what I was afraid of.
                                  jens55
                                  Could you give a bit more details on the vacuum PEI print bed ?
                                  Are you just using vacuum to hold the PEI to the aluminum bed or have you figured out a way to have the vacuum assist in holding down the part somehow?
                                  Even if the vacuum is just holding down the PEI sheet it's a rather interesting concept since I have experienced curling of PEI when you get into more than about 90 to 100 degrees for the bed temperature. I would imagine this also helps tremendously in terms of pulling out the just finished print (with the PEI) to let it cool while using a new sheet of PEI for the next print.
                                  A very interesting concept !
                                  Titanium 3D printed printhead ..... oh man ..... I am lost for words !
                                  nz_andyundefined 2 Replies Last reply 24 Nov 2020, 06:45 Reply Quote 0
                                  • nz_andyundefined
                                    nz_andy @jens55
                                    @jens55 The vacuum bed works great. Have not had any issues even at 220deg C. There is literally tones of force holding it down.
                                    Yes works great for part removal. I normally don't even wait for it to cool down, just peel it off.
                                    The door is power actuated so we can automate later.
                                    • nz_andyundefined
                                      nz_andy @jens55
                                      @jens55
                                      here is some 100% polycarbonate coming off a 145degC platform (125C chamber), dead flat , love the sound of this stuff.
                                      https://youtu.be/C7J8eOxjqNY
                                      We are using polycarbonate parts in-place of metal in suitable applications we build automated machines and this get used as a material of choice now.
                                      • 3DPMicroundefined
                                        3DPMicro @nz_andy
                                        @nz_andy 80k is reasonable and in the ball park with a Stratasys 400 or 3Dxtech Gearbox, actually about 20k less for yours. Agree that leadscrews/ballscrews are the way to go especially on larger volumes. Theres a pretty good sized Open Builds machine and a few others with lead or ball screws that produces really nice prints
                                        Duet controlled Lathe, micro mill, 3d printer and 1992 Haas VF2 VMC
                                        nz_andyundefined 1 Reply Last reply 9 Jul 2021, 04:04 Reply Quote 0
                                        • nz_andyundefined
                                          nz_andy @3DPMicro
                                          @3dpmicro
                                          The lead screws are American made, supper nice, they alone are $1500 but worth every cent in this machine.
                                          laelundefined 1 Reply Last reply 8 Aug 2021, 23:06 Reply Quote 1
