    3D Printer Connectors - What's best for in-line connections?
    3D Printing General Chat
    14
    29
    4.0k
    • timothyzundefined
      timothyz
      I just thought I would bring/post about a connector I found that Molex makes that I think would work well for hotend connections, as well as elsewhere on my printer. What does everyone prefer to use for their hotend heater thermistor, and fan connections out by the extruder? I know the Voron guys like the microfit 3.0, and Lulzbot had the normal dupont style pins, some people use JST on daughter boards.
      Molex makes some crimpable wire to wire connectors that are kinda cool (available on digikey). They call them ditto connectors since there is only one kind of crimp and one kind of housing (no male and female, but insertion is one way). Here's a video: https://www.youtube.com/watch?v=R-sWcdPl7Dc
      They make 2.5mm pitch connectors, so pretty compact for what they are: https://www.digikey.com/en/products/detail/0368770004/WM10902-ND/5114214?itemSeq=354314114
      Any thoughts? Is there any connector that is ideal that I just haven't heard about?
      Thanks in advance.
      -Tim
      zaptaundefined 1 Reply Last reply Reply Quote 1
      • fcwiltundefined
        fcwilt
        I've been using the "dupont" connectors for so long I really haven't paid attention to what else is out there.
        Those Molex units look sensible if you can cope with the somewhat larger size.
        • sebkritikelundefined
          sebkritikel
          I like Molex Microfit 3.0 as well as Molex SL series for my in-line connections.
          Large(ish?) IDEX - 6HC, 1HCL
          Stratasys Dimension 1200es to 6HC Conversion
          • jens55undefined
            jens55 @fcwilt
            @fcwilt I find that the dupont style connector does not have enough current handling capacity for the hot end heater if it is a 12V system. The connectors in the stepper circuit seem ok but because of my experience with the heater line, I can't recommend dupont for a 12V system.
            Commented only for future users referencing this post.
            As always, YMMV
            • fcwiltundefined
              fcwilt @jens55
              @jens55 said in 3D Printer Connectors - What's best for in-line connections?:
              It seems that heater cartridges have much longer wires than things like fans and thermistors.
              I cannot recall actually having to extend a heater.
              • zaptaundefined
                zapta @timothyz
                @timothyz said in 3D Printer Connectors - What's best for in-line connections?:
                That's not necessarily good. The gender often prevent you from connecting thing that shouldn't be connected. For example, with RC batteries you want to be able to connect a battery to load but not to another battery. Same goes for connecting two Duet driver outputs to each other.
                timothyzundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                • timothyzundefined
                  timothyz @zapta
                  @zapta
                  That's understandable, with this really being focused to the hotend, I guess I would be able to connect a fan outputs to another fan outputs if I wired them to two pin connectors. Looking at the size of everything, there really isn't much difference so I'll probably buy some more microfit 3.0 connectors (they are basically the same size as nanofit, weirdly enough).
                  • fcwiltundefined
                    fcwilt @zapta
                    @zapta said in 3D Printer Connectors - What's best for in-line connections?:
                    You would have to use connectors with different numbers of pins for each "class" of device - not ideal.
                    • o_lampeundefined
                      o_lampe
                      I don't like crimp connectors.
                      You never have the right crimp tool at hand (at home) nor can be sure, the cable has the right wire gauge (AmericanWireGauge [AWG] or metric system)
                      I solder everything and protect it with shrinktube.
                      fcwiltundefined Vetiundefined 2 Replies Last reply Reply Quote 0
                      • fcwiltundefined
                        fcwilt @o_lampe
                        @o_lampe said in 3D Printer Connectors - What's best for in-line connections?:
                        Look in my tool drawer - I think you will find the crimper you need - if you rummage around long enough.
                        • Vetiundefined
                          Veti @o_lampe
                          i can crimp nearly everything 3d printer related with the engineer pa-09
                          • jens55undefined
                            jens55
                            Crimp connections are more reliable if done correctly. If you can't do them right then soldering is likely better for you.
                            • hackinistratorundefined
                              hackinistrator
                              properly crimped connectors are better then soldered , specially on high speed moving parts like 3d printer .
                              i use molex and AMP connectors . for high current heaters (no longer use them , moved to mains powered) i used RC soldered connectors like XT60 and XT30 .
                              • taconiteundefined
                                taconite
                                I personally hate dupont but e.g. for stepper wires its super conveniant because you can change direction.
                                On heaters I use Molex Micro fit or Mini fit Jr.
                                Custom ANET A8
                                Custom Delta: D-PATCH (Delta Printer with Automatic Tool CHanging) https://forum.duet3d.com/topic/16082/d-patch?_=1596131234754
                                All I do here is under this license: CC BY-NC-SA
                                • Vetiundefined
                                  Veti @taconite
                                  i use Molex Micro fit for heaters as well.
                                  for other i use jst locking ones
                                  https://www.aliexpress.com/item/32856368582.html?spm=a2g0s.9042311.0.0.27424c4dyysxU1
                                  • zaptaundefined
                                    zapta @hackinistrator
                                    @hackinistrator said in 3D Printer Connectors - What's best for in-line connections?:
                                    I got recently this version of XT60 with the black covers and like it more than the older shrink tube version.
                                    Other interesting high current connector are Anderson Powerpole https://en.wikipedia.org/wiki/Anderson_Powerpole which are modular and genderless.
                                    Apropos connectors, WhamBam came recently with an interesting 3D printer gantry connector system https://whambamsystems.com/mutant
                                    theruttmeisterundefined 1 Reply Last reply Reply Quote 0
                                    • theruttmeisterundefined
                                      theruttmeister @zapta
                                      @zapta said in [3D Printer Connectors - What's best for in-line connections?](/post
                                      Shame they can't design a belt drive correctly... 😬
                                      Isolate, substitute, verify.
                                        sebkritikel
                                        And if you don't want to crimp...
                                        https://www.amphenol-industrial.com/images/catalogs/PT.pdf
                                        https://www.peigenesis.com/en/shop/part-information/PT01E84PSR/APH/EACH/69387.html#mates
                                        https://www.peigenesis.com/en/shop/part-information/PT06A84SSR/APH/EACH/72221.html
                                        Could get worse!
                                        • jens55undefined
                                          jens55
                                          I know this is an old topic but I have a relevant update:
                                          I started with Dupont style connections for the hot end heater for my 12V based printer. That caused all kinds of grief fairly quickly due to overheating of the connector (40W heater). I then went to a JST style interlocking connector. That worked for a while but is again causing failures due to overheating of the connector.
                                          Up to now, these connectors where sourced from China .... and are costing me way more in frustration and spoiled prints than they are worth.
                                          My next and hopefully final connector style will be a genuine Molex Microfit 3.0 connection system sourced from Digikey. I just had a print abort after about 4 hours of printing and it just isn't worth the pain and suffering any more.
                                          Even at ten times the price of the China product, it's worth it if it fixes this mess!
                                          • o_lampeundefined
                                            o_lampe @jens55
                                            @jens55
                                            dc42 also suggested to use the MicroFit 3.0, but I couldn't find a reseller (accepting paypal) with all the required parts in Stock. I guess, the German/EU components-market is empty, due to the well known issues. (and the supercontainership blocking Suez-channel forever)
                                            PaulHewundefined DIY-O-Sphereundefined zaptaundefined dc42undefined 4 Replies Last reply Reply Quote 0
