Parts are coming out too small...
533
    3DPMicro @dakingofhearts2003
    @dakingofhearts2003 when you say smaller how much are we talking? .1mm or 1mm?
    Duet controlled Lathe, micro mill, 3d printer and 1992 Haas VF2 VMC
    undefined 1 Reply Last reply 4 Apr 2021, 23:57 Reply Quote 0
      dakingofhearts2003 @alankilian
      @alankilian @alankilian I have the duet wifi and it is a qidi tech 1 which is a flashforge clone. I am using the lastest version of the firmware it always has printed since i configured it but the parts are inaccurate since i changed boards.
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Jul 25 2020 12:56:48 GMT-0400 (Eastern Daylight Time)
      M550 P"Qidi nova" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S1 ; disable Telnet
      M564 H0 ; allow not homed axis movement
      M569 P1 S0 ; physical drive 1 goes forwards
      M569 P2 S1 ; physical drive 2 goes backwards
      M569 P3 S0 ; physical drive 3 goes forwards
      M350 X32 Y32 Z32 E32 I1 ; configure microstepping with interpolation
      M92 X160.00 Y160.00 Z800.00 E909.59 ; set steps per mm
      M566 X800.00 Y800.00 Z20.00 E400.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X40000.00 Y40000.00 Z200.00 E2200.00 ; set maximum speeds (mm/min)
      M201 X4500.00 Y4500.00 Z200.00 E1000.00 ; set accelerations (mm/s^2)
      M906 X800 Y700 Z500 E950 I15 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      ; pressure advance ;set pressure advance for direct drive nova hotend
      M572 D0 S0.04
      M208 X225 Y145 Z165 S0 ; set axis maxima
      M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
      M574 Z0 ; configure Z-probe endstop for low end on Z
      M558 P9 H5 F500 T4000 X0 Y0 Z1 :set probe type and mode. not using on xy but using it on z axis
      M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F6000 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P50 X-49.41 Y8.53 Z4.207 ; set Z probe trigger value, offset and trigger height
      M557 X10:205 Y10:145 S10 ; define mesh grid
      ; autosave 911
      M911 S21.0 R23.0 P"M913 X0 Y0MG91 M83 G1 Z3 E-5 F1000
      M106 P0 S1 H0:2 ; set fan 1 value. Thermostatic control is turned on
      M106 P1 S1 H0:1 T45 ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"fan1" Q500 ; create fan 2 on pin fan1 and set its frequency
      M106 P2 S1 H0:1 T45 ; set fan 2 value. Thermostatic control is turned on
      M563 P0 S"Extruder" D0 H1 F0 ; define tool 0
      M501
      M500
      M564 H0
      undefined 1 Reply Last reply 5 Apr 2021, 00:30 Reply Quote 0
        dakingofhearts2003 @3DPMicro
        @3dpmicro ![alt text](167436737_492954335048248_3909494894066276714_n.jpg 167345623_448152912958867_6238981510628835996_n.jpg image url)
        one comes out the right size on my tevo but the duet board died and before that would always disconnect so im about to throw one of my old boards with marlin on it in it. I'd like to get this one right first though...
        undefined 1 Reply Last reply 5 Apr 2021, 09:45 Reply Quote 0
          sebkritikel @dakingofhearts2003
          @dakingofhearts2003 said in Parts are coming out too small...:
          How did you calculate the X and Y steps per mm? Is your Z steps per mm correct?
          Taking a stab, but 20mm/24.2mm=83%. 160steps/mm / 200steps/mm=80%.
          Are you sure you've properly calculated the X and Y steps per mm? I think its likely you have 16 teeth pulleys instead of 20 teeth (or an equivalent mistake).
          Large(ish?) IDEX - 6HC, 1HCL
          Stratasys Dimension 1200es to 6HC Conversion
          undefined 1 Reply Last reply 5 Apr 2021, 00:46 Reply Quote 0
            dakingofhearts2003 @sebkritikel
            @sebkritikel i tried the old numbers from the makerbot and used the 80 80 400 standard of marlin. the old makerbot numbers just made it print off the bed and etc. the marlin standard made the parts come out undersized
            undefined 1 Reply Last reply 5 Apr 2021, 00:57 Reply Quote 0
              Thanks for the update!
              Take a look at those formulas I posted - it’s fairy straight forward. Looks like your motors are 1.8deg motors, so 200 steps/rev (360/1.8). Per your M350, you have 32x micro stepping. Your belt pitch is likely 2mm.
              In your case the ‘80 80 400’ “standard” doesn’t work as you have 32x microsteping. Had you selected 16x, bam, the ‘80 80 400’ would likely have worked.
              However, those numbers aren’t working for you, and ~20% is fairly significant to be attributed to the extruder. The last variable in the equation is the pulley size/setup... double check that.
              Plugging numbers into config.g willy nilly can get you far, but it’s always good to fall back on documented formulas to work out issues like this.
              undefined 1 Reply Last reply 5 Apr 2021, 01:11 Reply Quote 0
                @sebkritikel when i did the extruder calibration it was correct. I did make a start mark on the bed and did a 50mm in the x direction and i measured 42.17. I didnt know i was going to need to be an engineer to change boards and firmware i see why people buy prusas now cause im sick of tinkering and wasting filament...
                undefined 1 Reply Last reply 5 Apr 2021, 01:25 Reply Quote 0
                  @dakingofhearts2003 well let me know if you need more help. Bummed to hear I didn’t get you pointed in the right direction.
                    dakingofhearts2003
                    @sebkritikel i think im going back i'm just tired of it...
                      o_lampe @dakingofhearts2003
                      I can partly understand your frustration, as RRF and Duet boards are getting more and more sophisticated
                      They offer more options, but also ask more from the user. Like reading manuals and listen to experienced users....
                      13 out of 13
