    Missing Steps - Cant Print SpreadCycle StealthChop tuning help
    286
    32.1k
      droftarts administrators
      Apologies for the lack of updates, mainly because there have been no updates. Thanks for additional information. I’m planning on spending all Thursday looking at this issue (during school holidays I’m only available one day a week), and hopefully @carcamerarig will be joining me for the fun.
      @Argo is low jerk high acceleration really the norm? Prusa3D disagrees with you:
      https://github.com/prusa3d/Prusa-Firmware/blob/eb4cf1a77f57b0825b72c5209d48fceaa8c0ec58/Firmware/Configuration.h#L424
      https://github.com/prusa3d/Prusa-Firmware/blob/eb4cf1a77f57b0825b72c5209d48fceaa8c0ec58/Firmware/variants/1_75mm_MK3S-EINSy10a-E3Dv6full.h#L100
      Segmented curves will tend to print slow with low jerk.
      Also your stealthchop tuning isn’t right, see page 35 and 36 here https://www.trinamic.com/fileadmin/assets/Products/ICs_Documents/TMC2209_Datasheet_V103.pdf#page35
      (If you need more info or an example, let me know and I’ll write it up when I’m at my desk and not on mobile.)
      • Argoundefined
        Argo
        @droftarts
        Default Prusa slicer profile uses 8 mm/s jerk. But yes, still rather high.
        I first stepped over low jerk recommendation in the Duet gcode dictionary.
        M593 suggets "High X and Y jerk values reduce the effectiveness of DAA; therefore you should set the X and Y jerk limits only as high as necessary to allow curves to be printed smoothly."
        So I did some testing and found 4 mm/s (or 240 mm/min) works very well without having issues with curves.
        Also the Klipper input shaper documentation suggests to use low jerk and high acceleration
        "If square_corner_velocity parameter was changed, revert it back to 5.0. It is not advised to increase it when using the input shaper because it can cause more smoothing in parts - it is better to use higher acceleration value instead."
        https://www.klipper3d.org/Resonance_Compensation.html
        What would you suggest to improve the StealthChop tuning procedure?
        carcamerarig already told me about your plans. Very nice offer from you 🙂 I hope you'll find a solution for his issues.
        • oc_geekundefined
          oc_geek @fulg
          @fulg ...for some reason my account login had issues and i wasn't able to login neither to change password...back now
          On my end (and i'm on the THIRD Duet 3 Mini 5+...)
          • i'm running Stand Alone
          • Have OMC 0.9 motors (but extruder)
          • Tried all releases including betas
          1. Always had and have the bangs during prints; was able to "print" but had layer shits on a bunch (3-4) prints (which i attributed at that time to some other cause)
          2. Since a few days i tried to enable mesh. Total disaster ...i started to get 25mm+ layer shifts
          I really hope these issue get fixed and the Duet team takes it on cse i think there are severe issues at the moment to be solved... which make the card almsot unusable...
          It is good that there is discussion and people contribute but the way this thread is turned... it is like users are doing debugging or finding caveats and work arounds to let things do not break apart.... i honestly think is not the way.... i counted few replies from the Duet team... ok take more time...analyze....test ....but come up with something or people will start moving / looking elsewhere (me included)
            dc42 administrators @fulg
            @fulg said in Missing Steps - Cant Print SpreadCycle StealthChop tuning help:
            One thing that was suggested to me (outside of this forum) is that I am not doing M17 and G4 P100 before moving motors the first time, reading the docs this seems to say that the required stealthChop/spreadCycle calibration of the TMC2209 will not occur. I would have expected RRF to do this implicitly, but perhaps it does and I am misunderstanding.
            RRF does not do this automatically. However, if you are switching to spreadCycle mode then it should not be necessary.
              dc42 administrators @dc42
              All who are experiencing the issue of occasional banging/layer shifting during a print, after it has happened please post:
              • A brief description of what happened, including the axis or axes affected if known
              • A M122 report
              • A M569 P# report for each relevant driver number #
              • Your config.g file
              carcamerarigundefined fulgundefined 2 Replies Last reply Reply Quote 0
              • carcamerarigundefined
                carcamerarig @dc42
                @dc42 mine are all contained in this thread from the various modes in both standalone and sbc.
                Argoundefined 1 Reply Last reply Reply Quote 0
                • Argoundefined
                  Argo @carcamerarig
                  @carcamerarig said in Missing Steps - Cant Print SpreadCycle StealthChop tuning help:
                  So he does not have to search for it as the thread has quite exploded:
                  https://forum.duet3d.com/post/223138
                    droftarts administrators @oc_geek
                    @oc_geek thanks for the report. Did the other boards have the same problem?
                    What firmware versions is everyone using? Did you notice the problem in earlier firmware versions, eg 3.2 betas?
                    oc_geekundefined 1 Reply Last reply Reply Quote 0
                    • oc_geekundefined
                      oc_geek @droftarts
                      @droftarts yes they did
                      on my side i've been in 3.2.2, 3.3 beta 1 and 3.3beta2
                      I'll post the files that dc42 indicated later (can't now)
                      Thanks for your support and looking into it. We all appreciate
                      edit: As a head up... a simple mesh enable (corrections are within +/- 0.05) and movement from e.g. X150 Y290 Z5 to X150 Y5 Z150 causes a tremendous shift in Z (it landed at 60 instead of 150...) it shall not be difficult to reproduce... thanks again
                      edit: @dc42 as requested including dumps
                      • M122 report
                      • M569 report
                      • config.g
                        dc42 administrators @Argo
                        @argo said in Missing Steps - Cant Print SpreadCycle StealthChop tuning help:
                        Thanks!
                          carcamerarig
                          Config
                          G90                                         ; Send absolute coordinates...
                          M83                                         ; ...but relative extruder moves
                          M550 P"Duet Caribou 420"                        	; Set machine name
                          M552 S1                                     	; Enable network
                          ;*** Access point is configured manually via M587
                          ;M586 P0 S1                                  ; Enable HTTP
                          ;M586 P1 S0                                  ; Disable FTP
                          ;M586 P2 S0                                  ; Disable Telnet
                          M575 P1 S1 B57600							; Panel Due
                          ; Drive Mappings
                          M569 P0.0 S0 V0                             ; Drive 0: X Axis
                          M569 P0.1 S0 V0                             ; Drive 1: Y Axis
                          M569 P0.2 S0 V0                             ; Drive 2:  Z Axis
                          M569 P0.3 S0 V0                             ; Drive 3: E Axis
                          M569 P0.4 S0 V0                             ; Drive 4: E1 used for Z1
                          ; Motor remapping for dual Z and axis Limits
                          M584 X0 Y1 Z2:4 E3				; two Z motors connected to driver outputs Z and E1
                          M671 X-37:287 Y0:0 S4			; leadscrews at left (connected to Z) and right (connected to E1) of X axis
                          ; Micrpstepping and Speed
                          M350 X32 Y32 E16 Z16 I1                     ; Configure microstepping with interpolation
                          M92 X200.00 Y200.00 Z400.00 E830.00         ; Set steps per mm
                          ; Speeds, Acceleration and Jerk
                          M566 X900 Y900 Z25.00 E600.00 P1      ; Set maximum instantaneous speed changes (mm/min)
                          M203 X7500.00 Y7500.00 Z720.00 E1200.00     ; Set maximum speeds (mm/min)
                          M201 X1500.00 Y1500.00 Z1200.00 E4000.00     ; Set accelerations (mm/s^2)
                          ; Motor currents
                          M906 X700.00 Y700.00 Z700.00 E700.00 I20    ; Set motor currents (mA) and motor idle factor in percent X,Y,Z=1000/1.414 E=1400/1.414
                          M84 S30                                     ; Set idle timeout
                          ; Printer geometry
                          M208 X0:250 Y-4:215 Z-0.5:410               ; Axis Limits
                          M564 H0							            ; allow unhomed movement
                          ; Endstops for each Axis
                          M574 X1 S3								 	; Set endstops controlled by motor load detection
                          M574 Y1 S3                               	; Set endstops controlled by motor load detection
                          ; Stallgaurd Sensitivy
                          M915 X S-2 F0 H200 R0		                ; Set X axis Sensitivity
                          M915 Y S-1 F0 H200 R0		                ; Set y axis Sensitivity
                          ; Input Shaper
                          ;M593 F58.5 P4 S0.2  ; Input Shaping 3.3/3.4
                          ;M593 F54.26
                          ; Z-Probe Super PINDA
                          M574 Z1 S2														; Set endstops controlled by probe
                          M558 P5 C"^io3.in" I1 H1 F500 T4800 A30 S0.004
                          ; Mesh Grid
                          M557 X24:221 Y10:195 P8	                         ; Define mesh grid for probing
                          ; Sheets
                          ;G31 P1000 X23 Y5 Z1.730 	                    ; Satin Sheet
                          G31 P1000 X23 Y5 Z1.91 	  	                  ; Textured Sheet
                          ;G31 P1000 X23 Y5 Z1.445 					    ; PEI Sheet
                          ;G31 P1000 X23 Y5 Z1.445 					    ; PEI Sheet 0.6 nozzle -10 offset
                          ; Heatbed Heaters and Thermistor Bed
                          M308 S0 P"temp0" Y"thermistor" T100000 B4725 C7.060000e-8       ; Set thermistor + ADC parameters for heater 0 Bed
                          M950 H0 C"out0" T0 Q10					                        ; Creates Bed Heater Qnn PWM frequency in Hz. Valid range: 0-65535, default: 500. (optional) 10hz stopped clicking
                          M307 H0 R0.273 C345.3 D10.89 S1.00 V23.8						; PID 3.2
                          M140 H0										                    ; Bed uses Heater 0
                          M143 H0 S120                                                    ; Set temperature limit for heater 0 to 120C Bed
                          ; HotEnd Heaters and Thermistor HotEnd
                          M308 S1 P"temp1" Y"thermistor" T500000 B4725 C1.19622e-7	       	; define E0 temperature sensor e3d
                          M950 H1 C"out1" T1 						                            ; Create HotEnd Heater
                          M307 H1 R2.383 C178.5:130.6 D5.32 S1.00 V23.9						; PID
                          M143 H1 S285                                                    	; Set temperature limit for heater 1 to 285C HotEnd
                          M302 S185 R185
                          M950 F1 C"out5" Q250				; Creates HOTEND Fan
                          M106 P1 T45 S235 H1                 ; HOTEND Fan Settings
                          M950 F0 C"out6" Q100				; Creates PARTS COOLING FAN
                          M106 P0 H-1                         ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off PARTS COOLING FAN
                          M563 P0 D0 H1 F0                            ; Define tool 0
                          G10 P0 X0 Y0 Z0                             ; Set tool 0 axis offsets
                          G10 P0 R0 S0                                ; Set initial tool 0 active and standby temperatures to 0C
                          ; StealthCop calibration
                          M17
                          G4 P150
                          G1 X1 Y1 Z1
                          G4 S2
                          M84 ; disable motors
                          ; Filament Sensor Logic
                          M98 P"0:/macros/02_Functions/StartupFilamentSensorCheck"  ; Runout Sensor Logic: Startup with filament = runout sensor active   Startup without filament = autoload active
                          M569 P0.1
                          Drive 1 runs in reverse, active low enable, timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, tpwmthrs 0 (inf mm/sec), pwmScaleSum 11, pwmScaleAuto 4, pwmOfsAuto 255, pwmGradAuto 39, pos 68
                          M569 P0.0
                          Drive 0 runs in reverse, active low enable, timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, tpwmthrs 0 (inf mm/sec), pwmScaleSum 12, pwmScaleAuto 5, pwmOfsAuto 255, pwmGradAuto 50, pos 764
                          Pre print M122
                          M122
                          RepRapFirmware for Duet 3 Mini 5+ version 3.3beta2 running on Duet 3 Mini5plus WiFi (standalone mode)
                          Board ID: Z9NZN-A296U-D65J0-40KM4-LY03Z-ZPQPD
                          Used output buffers: 3 of 40 (18 max)
                          Static ram: 99720
                          Dynamic ram: 106476 of which 24 recycled
                          Never used RAM 34628, free system stack 112 words
                          Tasks: NETWORK(ready,227) HEAT(delaying,317) CanReceiv(notifyWait,943) CanSender(notifyWait,358) CanClock(delaying,340) TMC(notifyWait,109) MAIN(running,363) IDLE(ready,20) AIN(delaying,269)
                          Owned mutexes: WiFi(NETWORK)
                          Last reset 00:04:51 ago, cause: power up
                          Last software reset at 2021-04-08 23:50, reason: User, GCodes spinning, available RAM 34628, slot 2
                          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00446000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                          Error status: 0x00
                          Aux0 errors 0,0,0
                          Aux1 errors 0,0,0
                          Supply voltage: min 0.0, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                          Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/782/782, gc cycles 3
                          Driver 0: position 39400, standstill, SG min/max 0/416, read errors 0, write errors 0, ifcnt 15, reads 41502, writes 15, timeouts 101, DMA errors 0, failedOp 0x6a
                          Driver 1: position 19000, standstill, SG min/max 0/440, read errors 0, write errors 0, ifcnt 17, reads 41598, writes 17, timeouts 3, DMA errors 0, failedOp 0x01
                          Driver 2: position 20000, standstill, SG min/max 0/282, read errors 0, write errors 0, ifcnt 16, reads 41602, writes 16, timeouts 0, DMA errors 0
                          Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 41606, writes 11, timeouts 0, DMA errors 0
                          Driver 4: position 0, standstill, SG min/max 0/284, read errors 0, write errors 0, ifcnt 16, reads 41602, writes 16, timeouts 0, DMA errors 0
                          Driver 5: position 0, assumed not present
                          Driver 6: position 0, assumed not present
                          Date/time: 2021-04-13 10:58:56
                          Cache data hit count 494597420
                          Slowest loop: 5.57ms; fastest: 0.07ms
                          === Storage ===
                          Free file entries: 10
                          SD card longest read time 1.2ms, write time 0.0ms, max retries 0
                          DMs created 83, maxWait 145592ms, bed compensation in use: none, comp offset 0.000
                          === MainDDARing ===
                          Scheduled moves 42, completed moves 42, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 4], CDDA state -1
                          === AuxDDARing ===
                          Bed heaters = 0 -1, chamberHeaters = -1 -1
                          Segments left: 0
                          Movement lock held by null
                          HTTP is idle in state(s) 0
                          Telnet is idle in state(s) 0
                          File is idle in state(s) 0
                          USB is idle in state(s) 0
                          Aux is idle in state(s) 0
                          Trigger is idle in state(s) 0
                          Queue is idle in state(s) 0
                          LCD is idle in state(s) 0
                          SBC is idle in state(s) 0
                          Daemon is idle in state(s) 0
                          Aux2 is idle in state(s) 0
                          Code queue is empty.
                          === Filament sensors ===
                          Extruder 0 sensor: ok
                          === CAN ===
                          Messages queued 2640, send timeouts 2636, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 16)
                          Last cancelled message type 30 dest 127
                          === Network ===
                          Slowest loop: 10.41ms; fastest: 0.00ms
                          HTTP sessions: 1 of 8
                          - WiFi -
                          Network state is active
                          WiFi firmware version 1.25beta0
                          WiFi MAC address f4:cf:a2:6f:e9:78
                          WiFi Vcc 3.36, reset reason Power up
                          WiFi flash size 2097152, free heap 24936
                          WiFi IP address 192.168.1.226
                          WiFi signal strength -43dBm, mode 802.11n, reconnections 0, sleep mode modem
                          Clock register 00002002
                          Post incident M122 (mini bangs during infill
                          M122
                          Used output buffers: 3 of 40 (26 max)
                          Static ram: 99720
                          Dynamic ram: 106476 of which 200 recycled
                          Never used RAM 34452, free system stack 108 words
                          Tasks: NETWORK(ready,227) HEAT(delaying,293) CanReceiv(notifyWait,943) CanSender(notifyWait,358) CanClock(delaying,340) TMC(delaying,109) MAIN(running,363) IDLE(ready,20) AIN(delaying,260)
                          Last reset 00:30:14 ago, cause: power up
                          Error status: 0x00
                          Aux0 errors 0,0,0
                          Aux1 errors 0,0,0
                          Supply voltage: min 23.4, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                          Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/1076/1022, gc cycles 21
                          Driver 0: position 32245, ok, SG min/max 0/510, read errors 0, write errors 0, ifcnt 21, reads 6782, writes 6, timeouts 1380, DMA errors 0, failedOp 0x71
                          Driver 1: position 22305, ok, SG min/max 0/494, read errors 0, write errors 0, ifcnt 23, reads 8094, writes 6, timeouts 67, DMA errors 0, failedOp 0x41
                          Driver 2: position 582, ok, SG min/max 0/286, read errors 0, write errors 0, ifcnt 21, reads 8139, writes 5, timeouts 23, DMA errors 0, failedOp 0x41
                          Driver 3: position 0, ok, SG min/max 0/486, read errors 0, write errors 0, ifcnt 13, reads 8148, writes 2, timeouts 18, DMA errors 0, failedOp 0x6a
                          Driver 4: position 0, ok, SG min/max 0/286, read errors 0, write errors 0, ifcnt 21, reads 8163, writes 5, timeouts 0, DMA errors 0
                          Date/time: 2021-04-13 11:24:19
                          Cache data hit count 2624084504
                          Slowest loop: 114.04ms; fastest: 0.09ms
                          === Storage ===
                          Free file entries: 9
                          SD card longest read time 90.0ms, write time 0.0ms, max retries 0
                          DMs created 83, maxWait 278053ms, bed compensation in use: mesh, comp offset 0.000
                          === MainDDARing ===
                          Scheduled moves 8766, completed moves 8726, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 233, 0], CDDA state 3
                          === AuxDDARing ===
                          Heater 0 is on, I-accum = 0.5
                          Heater 1 is on, I-accum = 0.6
                          Segments left: 1
                          File is doing "G1 X182.190 Y111.523 E0.01708" in state(s) 0
                          === CAN ===
                          Messages queued 13708, send timeouts 13708, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
                          Last cancelled message type 4514 dest 127
                          === Network ===
                          Slowest loop: 200.28ms; fastest: 0.08ms
                          - WiFi -
                          Failed messages: pending 0, notready 0, noresp 1
                          WiFi flash size 2097152, free heap 23248
                          WiFi signal strength -40dBm, mode 802.11n, reconnections 0, sleep mode modem
                          Post travel bang ( large)
                          M122
                          Static ram: 99720
                          Tasks: NETWORK(ready,225) HEAT(delaying,293) CanReceiv(notifyWait,943) CanSender(notifyWait,358) CanClock(notifyWait,340) TMC(notifyWait,100) MAIN(running,363) IDLE(ready,20) AIN(notifyWait,260)
                          Last reset 00:43:12 ago, cause: power up
                          Error status: 0x00
                          Aux0 errors 0,0,0
                          Aux1 errors 0,0,0
                          Supply voltage: min 23.4, current 23.5, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
                          Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/1748/1694, gc cycles 30
                          Driver 0: position 16627, assumed not present
                          Driver 1: position 17876, assumed not present
                          Driver 2: position 1882, ok, SG min/max 0/288, read errors 0, write errors 0, ifcnt 21, reads 38565, writes 0, timeouts 17, DMA errors 0, failedOp 0x6a
                          Driver 3: position 0, ok, SG min/max 0/498, read errors 0, write errors 0, ifcnt 13, reads 38581, writes 0, timeouts 1, DMA errors 0, failedOp 0x41
                          Driver 4: position 0, ok, SG min/max 0/228, read errors 0, write errors 0, ifcnt 21, reads 38581, writes 0, timeouts 0, DMA errors 0
                          Date/time: 2021-04-13 11:37:17
                          Cache data hit count 3697243847
                          Slowest loop: 76.79ms; fastest: 0.09ms
                          === Storage ===
                          SD card longest read time 76.4ms, write time 0.0ms, max retries 0
                          DMs created 83, maxWait 0ms, bed compensation in use: mesh, comp offset 0.000
                          === MainDDARing ===
                          Scheduled moves 47674, completed moves 47666, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 603, 0], CDDA state 3
                          === AuxDDARing ===
                          Segments left: 1
                          File is doing "G1 F4800.000" in state(s) 0
                          === CAN ===
                          Messages queued 7006, send timeouts 7006, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
                          === Network ===
                          Slowest loop: 202.00ms; fastest: 0.08ms
                          - WiFi -
                          Failed messages: pending 0, notready 0, noresp 2
                          WiFi flash size 2097152, free heap 23136
                          WiFi signal strength -42dBm, mode 802.11n, reconnections 0, sleep mode modem
                            dc42 administrators @carcamerarig
                            @carcamerarig, thanks for that. The M122 report shows a large number of timeouts in the driver status. On the last one, the communication has failed so badly that the firmware has flagged drivers 0 and 1 as "assumed not present". So it's possible that the problem is caused by communication errors between the processor and the stepper drivers.
                            carcamerarigundefined Argoundefined oc_geekundefined 3 Replies Last reply Reply Quote 1
                              carcamerarig @dc42
                              @dc42 Does that point to a faulty board or corrupt fw? Im going to Ian's on Thursday is this something he can investigate further, fix or replace the board?
                              • fulgundefined
                                fulg @dc42
                                @dc42 The requested info was already posted but unfortunately everything is scattered about in this thread, so here are direct links:
                                M122 reports:
                                https://forum.duet3d.com/post/224293 (only the driver bits)
                                https://forum.duet3d.com/post/224581
                                I always see these timeout errors, it is quite worrisome...
                                Full config + repro file:
                                https://forum.duet3d.com/post/224661
                                @droftarts I was running RRF 3.2.2 but upgraded to 3.3b2 to see if it would help, no difference.
                                VORON V2 CoreXY + Duet3 Mini5+ Ethernet v1.0 with Mini2+ expansion, VORON V0 CoreXY + Duet2 Maestro
                                • Argoundefined
                                  Argo @dc42
                                  I'm in middle of a print and did a M122 report just out curiosity.
                                  Driver 0: position 31835, assumed not present
                                  Driver 1: position 16605, assumed not present
                                  Driver 2: position 23041, assumed not present
                                  But I do not observe bangs or layer shifts.
                                  I did use your "preview" build from this posting: https://forum.duet3d.com/post/225143
                                  M122
                                  RepRapFirmware for Duet 3 Mini 5+ version 3.3beta2+1 (2021-04-11 10:20:02) running on Duet 3 Mini5plus Ethernet (standalone mode)
                                  Board ID: ZDWF8-8296U-D65J0-40KMU-J603Z-77MM8
                                  Used output buffers: 3 of 40 (40 max)
                                  Static ram: 100072
                                  Dynamic ram: 103000 of which 176 recycled
                                  Never used RAM 37600, free system stack 100 words
                                  Tasks: NETWORK(ready,204) ETHERNET(notifyWait,557) ACCEL(notifyWait,345) HEAT(delaying,300) CanReceiv(notifyWait,944) CanSender(notifyWait,357) CanClock(notifyWait,332) TMC(notifyWait,99) MAIN(running,312) IDLE(ready,20) AIN(notifyWait,259)
                                  Owned mutexes:
                                  Last reset 14:52:29 ago, cause: software
                                  Last software reset at 2021-04-13 00:05, reason: User, GCodes spinning, available RAM 37776, slot 2
                                  Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                                  Error status: 0x04
                                  Aux0 errors 0,0,0
                                  Aux1 errors 0,0,0
                                  MCU revision 3, ADC conversions started 63542814, completed 63542813, timed out 0, errs 0
                                  tnd=0 rnd=0 wrd=0 wtd=0 war=0
                                  Supply voltage: min 22.6, current 23.7, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
                                  Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/610/576, gc cycles 634
                                  Driver 3: position 0, assumed not present
                                  Driver 4: position 0, standstill, SG min/max 0/354, read errors 0, write errors 0, ifcnt 141, reads 59413, writes 0, timeouts 0, DMA errors 0
                                  Date/time: 2021-04-13 14:57:52
                                  Slowest loop: 16.75ms; fastest: 0.09ms
                                  === Storage ===
                                  SD card longest read time 14.3ms, write time 0.0ms, max retries 0
                                  === MainDDARing ===
                                  Scheduled moves 112179, completed moves 112166, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
                                  === AuxDDARing ===
                                  Heater 0 is on, I-accum = 0.2
                                  Heater 1 is on, I-accum = 0.8
                                  Segments left: 1
                                  File is doing "G1 X158.218 Y83.922 E0.04566" in state(s) 0
                                  Code queue is not empty:
                                  Queued 'M106 S255' for move 112171
                                  Queued 'M106 S216.75' for move 112171
                                  Queued 'M106 S216.75' for move 112178
                                  Queued 'M106 S255' for move 112179
                                  5 of 16 codes have been queued.
                                  === CAN ===
                                  Messages queued 49339, send timeouts 49339, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
                                  === Network ===
                                  Slowest loop: 16.10ms; fastest: 0.03ms
                                  - Ethernet -
                                  State: active
                                  Error counts: 0 0 0 0 0
                                  Socket states: 2 2 2 2 2 0 0 0
                                  M569 P0.0
                                  Drive 0 runs forwards, active low enable, timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, tpwmthrs 0 (inf mm/sec), pwmScaleSum 76, pwmScaleAuto 2, pwmOfsAuto 232, pwmGradAuto 19, pos 612
                                  M569 P0.1
                                  Drive 1 runs in reverse, active low enable, timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, tpwmthrs 0 (inf mm/sec), pwmScaleSum 161, pwmScaleAuto 1, pwmOfsAuto 254, pwmGradAuto 40, pos 190
                                  M569 P0.2
                                  Drive 2 runs forwards, active low enable, timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, tpwmthrs 0 (inf mm/sec), pwmScaleSum 89, pwmScaleAuto 26, pwmOfsAuto 255, pwmGradAuto 52, pos 595
                                  ;config.g
                                  M550 P"Pruset II MK3s"                        	; Set machine name
                                  ; Drive Mappings
                                  M569 P0.0 S1 V0                             ; Drive 0: X Axis
                                  M569 P0.2 S1 V0                             ; Drive 2:  Z Axis
                                  M569 P0.3 S1 V0                             ; Drive 3: E Axis
                                  M569 P0.4 S1 V0                             ; Drive 4: E1 used for Z1
                                  M671 X-37:287 Y0:0 S10			; leadscrews at left (connected to Z) and right (connected to E1) of X axis
                                  M92 X200.00 Y200.00 Z400.00 E415.00         ; Set steps per mm
                                  M566 X240.00 Y240.00 Z25.00 E600.00 P1      ; Set maximum instantaneous speed changes (mm/min)
                                  M203 X7500.00 Y7500.00 Z730.00 E1200.00     ; Set maximum speeds (mm/min)
                                  M201 X2000.00 Y2000.00 Z1200.00 E5000.00     ; Set accelerations (mm/s^2)
                                  ; Motor currents
                                  M906 X600.00 Y600.00 Z600.00 E450.00 I20    ; Set motor currents (mA) and motor idle factor in percent
                                  ; Printer geometry
                                  M208 X0:250 Y-4:215 Z-0.5:205               ; Axis Limits
                                  M915 X S2 F0 H200 R0		                ; Set X axis Sensitivity
                                  M915 Y S2 F0 H200 R0		                ; Set y axis Sensitivity
                                  ; Input Shaper and Accelerometer
                                  M955 P0 C"io2.out+io2.in"
                                  M593 F42.6 S0.3
                                  M558 P5 C"^io3.in" I1 H0.7 F520 T6000 A50 S0.005  	; PINDA
                                  ; Mesh Grid
                                  M557 X24:233 Y15:195 P8                         ; Define mesh grid for probing
                                  ; Sheets
                                  G31 P1000 X23 Y5 Z1.715 	                    ; Satin Sheet
                                  ;G31 P1000 X23 Y5 Z1.630 	                    ; Textured Sheet
                                  ;G31 P1000 X23 Y5 Z1.450 					    ; PEI Sheet
                                  ;G31 P1000 X23 Y5 Z1.440 					    ; PEI Sheet 0.6 nozzle -10 offset
                                  M950 H0 C"out0" T0 Q100					                        ; Creates Bed Heater
                                  M307 H0 R0.276 C365.2 D12.50 S1.00 V24.0 B0						; PID 3.2
                                  M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.060000e-8       	; define E0 temperature sensor e3d
                                  M950 H1 C"out1" T1 Q100					                            ; Create HotEnd Heater
                                  M307 H1 R2.301 C162.7:122.2 D7.10 S1.00 V24.3 B0					; PID
                                  M302 S185 R185
                                  M950 F1 C"out5" Q100				; Creates HOTEND Fan
                                  M106 P1 T45 S200 H1                 ; HOTEND Fan Settings
                                  M17
                                  G4 P150
                                  G1 X1 Y1 Z1
                                  G4 S2
                                  • oc_geekundefined
                                    oc_geek @dc42
                                    @dc42 it seems the timeouts are a common thing. Everyone i spoke with had those in the drivers report, me included (see files i posted earlier)
                                      dc42 administrators @oc_geek
                                      All those of you having this problem and running firmware 3.3beta2, please upgrade to the firmware build at https://www.dropbox.com/sh/0mwfe22wepk5efh/AAB6Lp0rwBPjVK2R4SxbKhLya?dl=0. If the problem continues when running this firmware, please post M122 logs as before.
                                      If you are not yet running 3.3beta2 but you are happy to run it, please upgrade to 3.3beta2 first (from the unstable package feed if running with SBC, or from https://github.com/Duet3D/RepRapFirmware/releases/tag/3.3beta2 if running standalone), then upgrade the main board firmware to the version in the above link.
                                      carcamerarigundefined 3 Replies Last reply Reply Quote 1
                                        carcamerarig @dc42
                                        @dc42 On it now, thanks and ill report back. Whats the map file for?
                                          carcamerarig @dc42
                                          Pre print
                                          m122
                                          RepRapFirmware for Duet 3 Mini 5+ version 3.3beta2+2 (2021-04-13 18:55:38) running on Duet 3 Mini5plus WiFi (standalone mode)
                                          Static ram: 100040
                                          Dynamic ram: 106532 of which 0 recycled
                                          Never used RAM 34276, free system stack 112 words
                                          Tasks: NETWORK(ready,222) HEAT(notifyWait,314) CanReceiv(notifyWait,944) CanSender(notifyWait,357) CanClock(delaying,332) TMC(notifyWait,99) MAIN(running,335) IDLE(ready,20) AIN(notifyWait,266)
                                          Last reset 00:01:56 ago, cause: software
                                          Error status: 0x00
                                          Aux0 errors 0,0,0
                                          Aux1 errors 0,0,0
                                          MCU revision 3, ADC conversions started 138432, completed 138431, timed out 0, errs 0
                                          Supply voltage: min 23.8, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                                          Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/662/662, gc cycles 1
                                          Driver 0: position 39400, standstill, SG min/max 150/502, read errors 0, write errors 1, ifcnt 34, reads 6815, writes 14, timeouts 0, DMA errors 0
                                          Driver 1: position 19000, standstill, SG min/max 42/402, read errors 0, write errors 1, ifcnt 34, reads 6815, writes 14, timeouts 0, DMA errors 0
                                          Driver 2: position 20000, standstill, SG min/max 114/496, read errors 0, write errors 1, ifcnt 32, reads 6815, writes 13, timeouts 0, DMA errors 0
                                          Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 22, reads 6818, writes 10, timeouts 0, DMA errors 0
                                          Driver 4: position 0, standstill, SG min/max 54/280, read errors 0, write errors 1, ifcnt 32, reads 6816, writes 13, timeouts 0, DMA errors 0
                                          Date/time: 2021-04-13 19:28:15
                                          Cache data hit count 198108627
                                          Slowest loop: 5.51ms; fastest: 0.07ms
                                          === Storage ===
                                          SD card longest read time 1.5ms, write time 0.0ms, max retries 0
                                          DMs created 83, maxWait 47069ms, bed compensation in use: none, comp offset 0.000
                                          === MainDDARing ===
                                          Scheduled moves 42, completed moves 42, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1
                                          === AuxDDARing ===
                                          Segments left: 0
                                          === CAN ===
                                          Messages queued 1063, send timeouts 1059, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 16)
                                          === Network ===
                                          Slowest loop: 10.12ms; fastest: 0.00ms
                                          - WiFi -
                                          WiFi flash size 2097152, free heap 25016
                                          1st move from purge bang
                                          m122
                                          Static ram: 100040
                                          Dynamic ram: 106532 of which 176 recycled
                                          Never used RAM 34100, free system stack 112 words
                                          Tasks: NETWORK(ready,222) HEAT(delaying,300) CanReceiv(notifyWait,944) CanSender(notifyWait,357) CanClock(notifyWait,332) TMC(notifyWait,99) MAIN(running,335) IDLE(ready,20) AIN(notifyWait,266)
                                          Last reset 00:05:40 ago, cause: software
                                          Error status: 0x00
                                          Aux0 errors 0,0,0
                                          Aux1 errors 0,0,0
                                          MCU revision 3, ADC conversions started 402873, completed 402872, timed out 0, errs 0
                                          Supply voltage: min 23.5, current 23.6, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                                          Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/1964/1934, gc cycles 3
                                          Driver 0: position 30573, ok, SG min/max 0/396, read errors 0, write errors 0, ifcnt 40, reads 13009, writes 6, timeouts 0, DMA errors 0
                                          Driver 1: position 21158, ok, SG min/max 2/466, read errors 0, write errors 0, ifcnt 40, reads 13009, writes 6, timeouts 0, DMA errors 0
                                          Driver 2: position 108, standstill, SG min/max 0/278, read errors 0, write errors 0, ifcnt 37, reads 13011, writes 5, timeouts 0, DMA errors 0
                                          Driver 3: position 0, ok, SG min/max 0/340, read errors 0, write errors 0, ifcnt 24, reads 13013, writes 2, timeouts 0, DMA errors 0
                                          Driver 4: position 0, standstill, SG min/max 0/284, read errors 0, write errors 0, ifcnt 37, reads 13010, writes 5, timeouts 0, DMA errors 0
                                          Date/time: 2021-04-13 19:31:59
                                          Cache data hit count 533316832
                                          Slowest loop: 115.81ms; fastest: 0.09ms
                                          === Storage ===
                                          SD card longest read time 1.3ms, write time 0.0ms, max retries 0
                                          DMs created 83, maxWait 145636ms, bed compensation in use: mesh, comp offset 0.000
                                          === MainDDARing ===
                                          Scheduled moves 297, completed moves 275, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 1, 0], CDDA state 3
                                          === AuxDDARing ===
                                          Heater 0 is on, I-accum = 0.6
                                          Heater 1 is on, I-accum = 0.4
                                          Segments left: 1
                                          File is doing "G1 X184.099 Y93.163 E0.43669" in state(s) 0
                                          === CAN ===
                                          Messages queued 2021, send timeouts 2021, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
                                          === Network ===
                                          Slowest loop: 200.83ms; fastest: 0.08ms
                                          - WiFi -
                                          WiFi flash size 2097152, free heap 26592
                                          Travel bang 2
                                          m122
                                          Used output buffers: 3 of 40 (27 max)
                                          Static ram: 100040
                                          Tasks: NETWORK(ready,222) HEAT(notifyWait,298) CanReceiv(notifyWait,944) CanSender(notifyWait,357) CanClock(delaying,332) TMC(notifyWait,99) MAIN(running,335) IDLE(ready,20) AIN(notifyWait,266)
                                          Last reset 00:09:34 ago, cause: software
                                          Error status: 0x00
                                          Aux0 errors 0,0,0
                                          Aux1 errors 0,0,0
                                          MCU revision 3, ADC conversions started 668004, completed 668003, timed out 0, errs 0
                                          Supply voltage: min 23.4, current 23.9, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
                                          Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/1556/1502, gc cycles 6
                                          Driver 0: position 21006, ok, SG min/max 0/466, read errors 0, write errors 0, ifcnt 40, reads 12887, writes 0, timeouts 0, DMA errors 0
                                          Driver 1: position 20378, ok, SG min/max 0/440, read errors 0, write errors 0, ifcnt 40, reads 12887, writes 0, timeouts 0, DMA errors 0
                                          Driver 2: position 122, standstill, SG min/max 0/4, read errors 0, write errors 0, ifcnt 37, reads 12886, writes 0, timeouts 0, DMA errors 0
                                          Driver 3: position 0, ok, SG min/max 0/490, read errors 0, write errors 0, ifcnt 24, reads 12887, writes 0, timeouts 0, DMA errors 0
                                          Driver 4: position 0, standstill, SG min/max 0/8, read errors 0, write errors 0, ifcnt 37, reads 12887, writes 0, timeouts 0, DMA errors 0
                                          Date/time: 2021-04-13 19:35:54
                                          Cache data hit count 824357935
                                          Slowest loop: 99.51ms; fastest: 0.09ms
                                          === Storage ===
                                          SD card longest read time 46.6ms, write time 0.0ms, max retries 0
                                          === MainDDARing ===
                                          Scheduled moves 607, completed moves 600, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 10, 0], CDDA state 3
                                          === AuxDDARing ===
                                          Heater 0 is on, I-accum = 0.4
                                          Segments left: 1
                                          File is doing "G1 X91.220 Y90.225 E0.61454" in state(s) 0
                                          === CAN ===
                                          Messages queued 2109, send timeouts 2109, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
                                          === Network ===
                                          Slowest loop: 201.84ms; fastest: 0.08ms
                                          - WiFi -
                                          WiFi signal strength -45dBm, mode 802.11n, reconnections 0, sleep mode modem
                                          Layer 4 solid infill bang
                                          m122
                                          Static ram: 100040
                                          Last reset 00:19:56 ago, cause: software
                                          Error status: 0x00
                                          Aux0 errors 0,0,0
                                          Aux1 errors 0,0,0
                                          MCU revision 3, ADC conversions started 1383243, completed 1383242, timed out 0, errs 0
                                          Supply voltage: min 23.4, current 23.8, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                                          Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/476/422, gc cycles 14
                                          Driver 0: position 12223, ok, SG min/max 0/508, read errors 0, write errors 0, ifcnt 40, reads 35114, writes 0, timeouts 0, DMA errors 0
                                          Driver 1: position 23768, ok, SG min/max 0/490, read errors 0, write errors 0, ifcnt 40, reads 35114, writes 0, timeouts 0, DMA errors 0
                                          Driver 2: position 338, ok, SG min/max 0/218, read errors 0, write errors 0, ifcnt 37, reads 35114, writes 0, timeouts 0, DMA errors 0
                                          Driver 3: position 0, ok, SG min/max 0/500, read errors 0, write errors 0, ifcnt 24, reads 35114, writes 0, timeouts 0, DMA errors 0
                                          Driver 4: position 0, ok, SG min/max 0/264, read errors 0, write errors 0, ifcnt 37, reads 35114, writes 0, timeouts 0, DMA errors 0
                                          Date/time: 2021-04-13 19:46:15
                                          Cache data hit count 1699858608
                                          Slowest loop: 93.01ms; fastest: 0.09ms
                                          === Storage ===
                                          SD card longest read time 85.2ms, write time 0.0ms, max retries 0
                                          === MainDDARing ===
                                          Scheduled moves 3320, completed moves 3311, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 86, 0], CDDA state 3
                                          === AuxDDARing ===
                                          Heater 1 is on, I-accum = 0.7
                                          Segments left: 1
                                          File is doing "G1 X61.113 Y115.954 E1.24148" in state(s) 0
                                          === CAN ===
                                          Messages queued 5596, send timeouts 5596, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
                                          === Network ===
                                          Slowest loop: 199.63ms; fastest: 0.08ms
                                          - WiFi -
                                          Failed messages: pending 0, notready 0, noresp 3
                                          WiFi signal strength -44dBm, mode 802.11n, reconnections 0, sleep mode modem
                                            carcamerarig @dc42
                                            g15% infill mini bangs (after cancel)
                                            m122
                                            Used output buffers: 4 of 40 (27 max)
                                            Static ram: 100040
                                            Tasks: NETWORK(ready,220) HEAT(delaying,298) CanReceiv(notifyWait,944) CanSender(notifyWait,357) CanClock(delaying,332) TMC(notifyWait,99) MAIN(running,335) IDLE(ready,20) AIN(notifyWait,266)
                                            Last reset 00:22:44 ago, cause: software
                                            Error status: 0x00
                                            Aux0 errors 0,0,0
                                            Aux1 errors 0,0,0
                                            MCU revision 3, ADC conversions started 1578534, completed 1578533, timed out 0, errs 0
                                            Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/480/480, gc cycles 16
                                            Driver 0: position 2000, standstill, SG min/max 0/492, read errors 0, write errors 0, ifcnt 41, reads 9590, writes 1, timeouts 0, DMA errors 0
                                            Driver 1: position 0, standstill, SG min/max 0/466, read errors 0, write errors 0, ifcnt 41, reads 9590, writes 1, timeouts 0, DMA errors 0
                                            Driver 2: position 4510, standstill, SG min/max 0/302, read errors 0, write errors 0, ifcnt 38, reads 9591, writes 1, timeouts 0, DMA errors 0
                                            Driver 3: position 0, standstill, SG min/max 2/506, read errors 0, write errors 0, ifcnt 25, reads 9591, writes 1, timeouts 0, DMA errors 0
                                            Driver 4: position 0, standstill, SG min/max 0/176, read errors 0, write errors 0, ifcnt 38, reads 9590, writes 1, timeouts 0, DMA errors 0
                                            Date/time: 2021-04-13 19:49:03
                                            Cache data hit count 1952316320
                                            Slowest loop: 111.22ms; fastest: 0.07ms
                                            === Storage ===
                                            SD card longest read time 30.4ms, write time 5.0ms, max retries 0
                                            === MainDDARing ===
                                            Scheduled moves 6966, completed moves 6966, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 82, 0], CDDA state -1
                                            === AuxDDARing ===
                                            Segments left: 0
                                            === CAN ===
                                            Messages queued 1512, send timeouts 1512, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
                                            === Network ===
                                            Slowest loop: 199.57ms; fastest: 0.08ms
                                            - WiFi -
                                            Failed messages: pending 0, notready 0, noresp 4
                                            M569 P0.0
                                            Drive 0 runs in reverse, active low enable, timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, tpwmthrs 0 (inf mm/sec), pwmScaleSum 10, pwmScaleAuto 3, pwmOfsAuto 255, pwmGradAuto 49, pos 4
                                            M569 P0.1
                                            Drive 1 runs in reverse, active low enable, timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, tpwmthrs 0 (inf mm/sec), pwmScaleSum 15, pwmScaleAuto 8, pwmOfsAuto 255, pwmGradAuto 44, pos 644
                                            ; Drive Mappings
                                            ; Motor currents
                                            ; Printer geometry
                                            ; Input Shaper
                                            ;M593 F54.26
                                            ; Mesh Grid
                                            ; Sheets
                                            M302 S185 R185
                                            M17
                                            G4 P150
                                            G1 X1 Y1 Z1
                                            G4 S2
                                            ![Screenshot 2021-04-13 at 19.51.45.png](/assets/uploads/files/1618340118910-screenshot-2021-04-13-at-19.51.45.png)
                                            ![Screenshot 2021-04-13 at 19.51.39.png](/assets/uploads/files/1618340118851-screenshot-2021-04-13-at-19.51.39.png)
