    Coming soon: Accelerometer Support
    Beta Firmware
    14
    76
    7.5k
    • Nuramoriundefined
      Nuramori @jay_s_uk
      @jay_s_uk rats. 😛
      I'm designing the mount for the accelerometer, and now I'm trying to understand the "Inn" orientation parameter for M955. It's not quite clear how to determine the correct value. I have a core xy (BLV cube) and I'm looking to orient the board 90 degrees from what the board symbol shows, which would otherwise align with the printer x/y axis. So if the "default" is 21, I'm not sure what it would be if I rotated the board clockwise 90 degrees.
      dc42undefined zaptaundefined 2 Replies Last reply Reply Quote 0
        dc42 administrators @Nuramori
        @nuramori, the documentation was wrong. The default (which corresponds to the chip axes lining up with the machine axes) is 20, not 21.
        When you rotate the chip, if chip +Z is still up then the first digit 2 doesn't change. The second digit will be 1 if the chip +X direction faces the machine +Y direction, or 5 if it faces machine -Y.
        Nuramoriundefined 1 Reply Last reply Reply Quote 0
        • Nuramoriundefined
          Nuramori @dc42
          @dc42 aaaah, I get it now, thanks! The silkscreen arrow on the adafruit board helps put that together.
          • zaptaundefined
            zapta @Nuramori
            @nuramori said in Coming soon: Accelerometer Support:
            I'm designing the mount for the accelerometer..
            Is the accelerometer supposed to be mounted permanently or just used one time to measure the reassurance frequency(s) of the system?
            • Nuramoriundefined
              Nuramori @zapta
              @zapta My understanding it's providing real time or near real time feedback that's taken into account for all movement. So in short, a permanent part of the system.
                jay_s_uk @Nuramori
                @nuramori on klipper its a run once and remove from the system thing until you change something.
                not sure if it will be used in the same way here or not
                CNCModellerundefined 1 Reply Last reply Reply Quote 1
                • CNCModellerundefined
                  CNCModeller @jay_s_uk
                  @jay_s_uk said in Coming soon: Accelerometer Support:
                  My understanding is also that it's a run once to characterise the resonance of the printer.
                  Input shaping is an open loop approach as far as I understand.
                  However, the accelerometer needs to be rigidly secured to the print head to accurately measure the printers characteristics so a dedicated mount IMO is a good idea.
                  That's not to say we won't find other uses for an accelerometer in the the future of course!!
                  Polar Duet3 Mini + 1HCL
                  https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
                  Wanhao D4S: Duet2
                  https://forum.duet3d.com/post/296755
                  K40 Laser, Duet2
                  https://forum.duet3d.com/post/312082
                  Wanhao D5S
                  https://www.youtube.com/CNCModellerUK
                  • Nuramoriundefined
                    Nuramori
                    My soon to be installed Sammy/LIS3DH combo.
                    image of accelerometer mockup
                      CNCModeller @Nuramori
                      That's nice, I've got an order in for a couple of duet Sammy boards from Germany. Looking forward to having a play with my Duet 3 mini.
                      Wanhao D4S: Duet2
                      K40 Laser, Duet2
                      Wanhao D5S
                      • aprzundefined
                        aprz
                        So would the accelerometer be mounted to the frame or motor? Does its position matter for it to read any ringing frequency.
                        This article is interesting:
                        https://www.omega.com/en-us/resources/accelerometers
                        https://www.pcb.com/resources/technical-information/mounting
                        dc42undefined Nuramoriundefined 2 Replies Last reply Reply Quote 0
                          dc42 administrators @aprz
                          @aprz said in Coming soon: Accelerometer Support:
                          It would be mounted on the print head. For a bed slinger, you would also need to take measurements with it mounted on the bed.
                          CNCModellerundefined 1 Reply Last reply Reply Quote 0
                          • Nuramoriundefined
                            Nuramori @aprz
                            @aprz This is how/where I'm mounting mine...
                            o_lampeundefined CNCModellerundefined aprzundefined 3 Replies Last reply Reply Quote 0
                            • o_lampeundefined
                              o_lampe @Nuramori
                              @nuramori
                              I like your silicone-sock wiper 🙂
                                CNCModeller @dc42
                                @dc42 said in Coming soon: Accelerometer Support:
                                @dc42 Given the bed on a bed slinger increases in mass during a print would it be beneficial to alter the ringing frequency during the print to account for the print mass?
                                If so I guess we could embed input shaping gcode in the print file or something like that.
                                Perhaps enter the total print mass at the start of a print and profile the shaping based on % complete and a survey of frequencies across a print mass range.
                                Interesting 🤓 stuff...
                                Wanhao D4S: Duet2
                                K40 Laser, Duet2
                                Wanhao D5S
                                  jay_s_uk @CNCModeller
                                  @cncmodeller the amount of filament used is known already so it wouldn't be too difficult to track that to mass being added
                                    @Nuramori given these don't need to be a permanent fit, are you fitting a plug at the print head to remove it after doing the resonance survey? I will be as I have a moving bed and will also be using the board to characterise my other printers too.
                                    Therefore:
                                    Should I be adding ballast to account for the loss of mass. Probably not unless the print head is very light?
                                    Also should we be terminating the disconnected wire's at the connector to reduce EMF back to the Duet?
                                    Really looking forward to trying this out. 🙂
                                    Wanhao D4S: Duet2
                                    K40 Laser, Duet2
                                    Wanhao D5S
                                    o_lampeundefined Nuramoriundefined zaptaundefined 3 Replies Last reply Reply Quote 0
                                    • o_lampeundefined
                                      o_lampe @CNCModeller
                                      @cncmodeller said in Coming soon: Accelerometer Support:
                                      When you uninstall it, you also comment out the sensor definition. The pins involved will no longer be 'observed' by RRF
                                        CNCModeller @o_lampe
                                        @o_lampe said in Coming soon: Accelerometer Support:
                                        Yeah thinking about it I'm just going to have a temporary loom as well so it'll all get removed all the way back to the Duet.
                                        Wanhao D4S: Duet2
                                        K40 Laser, Duet2
                                        Wanhao D5S
                                        • o_lampeundefined
                                          @cncmodeller
                                          Imagine we'd have to terminate all unused I/O pins on the boards 😵
                                          CNCModellerundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                            @cncmodeller
                                            As I understand it there is a difference between unused pins and unterminated flying wires that are still connected. Unterminated wires would just act as an antenna to draw electromagnetic interference into the Duet.
                                            Wanhao D4S: Duet2
                                            K40 Laser, Duet2
                                            Wanhao D5S
