Coming soon: Accelerometer Support
@zapta My understanding it's providing real time or near real time feedback that's taken into account for all movement. So in short, a permanent part of the system.
@nuramori on klipper its a run once and remove from the system thing until you change something.
not sure if it will be used in the same way here or not -
@jay_s_uk said in Coming soon: Accelerometer Support:
not sure if it will be used in the same way here or notMy understanding is also that it's a run once to characterise the resonance of the printer.
Input shaping is an open loop approach as far as I understand.
However, the accelerometer needs to be rigidly secured to the print head to accurately measure the printers characteristics so a dedicated mount IMO is a good idea.
That's not to say we won't find other uses for an accelerometer in the the future of course!!
My soon to be installed Sammy/LIS3DH combo.
@nuramori said in Coming soon: Accelerometer Support:
That's nice, I've got an order in for a couple of duet Sammy boards from Germany. Looking forward to having a play with my Duet 3 mini.
So would the accelerometer be mounted to the frame or motor? Does its position matter for it to read any ringing frequency.
This article is interesting:
https://www.omega.com/en-us/resources/accelerometershttps://www.pcb.com/resources/technical-information/mounting
@aprz said in Coming soon: Accelerometer Support:
It would be mounted on the print head. For a bed slinger, you would also need to take measurements with it mounted on the bed.
@aprz This is how/where I'm mounting mine...
@nuramori
I like your silicone-sock wiper -
@dc42 said in Coming soon: Accelerometer Support:
@dc42 Given the bed on a bed slinger increases in mass during a print would it be beneficial to alter the ringing frequency during the print to account for the print mass?
If so I guess we could embed input shaping gcode in the print file or something like that.
Perhaps enter the total print mass at the start of a print and profile the shaping based on % complete and a survey of frequencies across a print mass range.
Interesting
stuff...
@cncmodeller the amount of filament used is known already so it wouldn't be too difficult to track that to mass being added
@Nuramori given these don't need to be a permanent fit, are you fitting a plug at the print head to remove it after doing the resonance survey? I will be as I have a moving bed and will also be using the board to characterise my other printers too.
Therefore:
Should I be adding ballast to account for the loss of mass. Probably not unless the print head is very light?
Also should we be terminating the disconnected wire's at the connector to reduce EMF back to the Duet?
Really looking forward to trying this out.
@cncmodeller said in Coming soon: Accelerometer Support:
When you uninstall it, you also comment out the sensor definition. The pins involved will no longer be 'observed' by RRF
@o_lampe said in Coming soon: Accelerometer Support:
Yeah thinking about it I'm just going to have a temporary loom as well so it'll all get removed all the way back to the Duet.
@cncmodeller
Imagine we'd have to terminate all unused I/O pins on the boards -
@cncmodeller
Imagine we'd have to terminate all unused I/O pins on the boardsAs I understand it there is a difference between unused pins and unterminated flying wires that are still connected. Unterminated wires would just act as an antenna to draw electromagnetic interference into the Duet.
@cncmodeller
Imagine we'd have to terminate all unused I/O pins on the boardsNo need.
@cncmodeller given my liquid cooled head which is not what Iād call light, the 2-5 grams Iām adding is t something Iām going to fuss over, and I plan on just leaving it on the head. I have a toolboard on the back of the print head, so the wiring is short and sweet.
I like your cooling system.
@cncmodeller, looking at your picture, the accelerometer is close to the rail and far from the nozzle. I would think that you want to measure the accelerations of the nozzle which can be different due to mechanical flex and play.
(I am not an expert, just speculating).
