    Coming soon: Accelerometer Support
    Beta Firmware
    14
    76
    7.5k
      jay_s_uk @Nuramori
      @nuramori on klipper its a run once and remove from the system thing until you change something.
      not sure if it will be used in the same way here or not
      CNCModellerundefined 1 Reply Last reply Reply Quote 1
      • CNCModellerundefined
        CNCModeller @jay_s_uk
        @jay_s_uk said in Coming soon: Accelerometer Support:
        My understanding is also that it's a run once to characterise the resonance of the printer.
        Input shaping is an open loop approach as far as I understand.
        However, the accelerometer needs to be rigidly secured to the print head to accurately measure the printers characteristics so a dedicated mount IMO is a good idea.
        That's not to say we won't find other uses for an accelerometer in the the future of course!!
        Polar Duet3 Mini + 1HCL
        https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
        Wanhao D4S: Duet2
        https://forum.duet3d.com/post/296755
        K40 Laser, Duet2
        https://forum.duet3d.com/post/312082
        Wanhao D5S
        https://www.youtube.com/CNCModellerUK
        • Nuramoriundefined
          Nuramori
          My soon to be installed Sammy/LIS3DH combo.
          image of accelerometer mockup
            CNCModeller @Nuramori
            @nuramori said in Coming soon: Accelerometer Support:
            That's nice, I've got an order in for a couple of duet Sammy boards from Germany. Looking forward to having a play with my Duet 3 mini.
            Wanhao D4S: Duet2
            K40 Laser, Duet2
            Wanhao D5S
            • aprzundefined
              aprz
              So would the accelerometer be mounted to the frame or motor? Does its position matter for it to read any ringing frequency.
              This article is interesting:
              https://www.omega.com/en-us/resources/accelerometers
              https://www.pcb.com/resources/technical-information/mounting
              dc42undefined Nuramoriundefined 2 Replies Last reply Reply Quote 0
                dc42 administrators @aprz
                @aprz said in Coming soon: Accelerometer Support:
                It would be mounted on the print head. For a bed slinger, you would also need to take measurements with it mounted on the bed.
                CNCModellerundefined 1 Reply Last reply Reply Quote 0
                • Nuramoriundefined
                  Nuramori @aprz
                  @aprz This is how/where I'm mounting mine...
                  o_lampeundefined CNCModellerundefined aprzundefined 3 Replies Last reply Reply Quote 0
                  • o_lampeundefined
                    o_lampe @Nuramori
                    @nuramori
                    šŸ‘
                    I like your silicone-sock wiper šŸ™‚
                      CNCModeller @dc42
                      @dc42 said in Coming soon: Accelerometer Support:
                      @dc42 Given the bed on a bed slinger increases in mass during a print would it be beneficial to alter the ringing frequency during the print to account for the print mass?
                      If so I guess we could embed input shaping gcode in the print file or something like that.
                      Perhaps enter the total print mass at the start of a print and profile the shaping based on % complete and a survey of frequencies across a print mass range.
                      Interesting šŸ¤“ stuff...
                      Wanhao D4S: Duet2
                      K40 Laser, Duet2
                      Wanhao D5S
                        jay_s_uk @CNCModeller
                        @cncmodeller the amount of filament used is known already so it wouldn't be too difficult to track that to mass being added
                          @Nuramori given these don't need to be a permanent fit, are you fitting a plug at the print head to remove it after doing the resonance survey? I will be as I have a moving bed and will also be using the board to characterise my other printers too.
                          Therefore:
                          Should I be adding ballast to account for the loss of mass. Probably not unless the print head is very light?
                          Also should we be terminating the disconnected wire's at the connector to reduce EMF back to the Duet?
                          Really looking forward to trying this out. šŸ™‚
                          Wanhao D4S: Duet2
                          K40 Laser, Duet2
                          Wanhao D5S
                          o_lampeundefined Nuramoriundefined zaptaundefined 3 Replies Last reply Reply Quote 0
                          • o_lampeundefined
                            o_lampe @CNCModeller
                            @cncmodeller said in Coming soon: Accelerometer Support:
                            When you uninstall it, you also comment out the sensor definition. The pins involved will no longer be 'observed' by RRF
                              CNCModeller @o_lampe
                              @o_lampe said in Coming soon: Accelerometer Support:
                              Yeah thinking about it I'm just going to have a temporary loom as well so it'll all get removed all the way back to the Duet.
                              Wanhao D4S: Duet2
                              K40 Laser, Duet2
                              Wanhao D5S
                              • o_lampeundefined
                                @cncmodeller
                                Imagine we'd have to terminate all unused I/O pins on the boards 😵
                                CNCModellerundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                  @cncmodeller
                                  As I understand it there is a difference between unused pins and unterminated flying wires that are still connected. Unterminated wires would just act as an antenna to draw electromagnetic interference into the Duet.
                                  Wanhao D4S: Duet2
                                  K40 Laser, Duet2
                                  Wanhao D5S
                                    dc42 administrators @o_lampe
                                    @cncmodeller
                                    No need.
                                    • Nuramoriundefined
                                      Nuramori @CNCModeller
                                      @cncmodeller given my liquid cooled head which is not what I’d call light, the 2-5 grams I’m adding is t something I’m going to fuss over, and I plan on just leaving it on the head. I have a toolboard on the back of the print head, so the wiring is short and sweet.
                                      • aprzundefined
                                        aprz @Nuramori
                                        I like your cooling system.
                                        • zaptaundefined
                                          zapta @CNCModeller
                                          @cncmodeller, looking at your picture, the accelerometer is close to the rail and far from the nozzle. I would think that you want to measure the accelerations of the nozzle which can be different due to mechanical flex and play.
                                          (I am not an expert, just speculating).
                                          CNCModellerundefined arhiundefined 2 Replies Last reply Reply Quote 0
                                            CNCModeller @zapta
                                            @zapta Hi it's not my printer its @aprz
                                            But as the print head is pretty much a solid item i'd think it won't really matter. Most if not all of the flex in the printer and hence the source of resonance is in the structure and drive system in my opinion.
                                            Wanhao D4S: Duet2
                                            K40 Laser, Duet2
                                            Wanhao D5S
