    ethernet to esp breakboard
    36
    1.8k
      jay_s_uk @apak
      @apak fair enough. It's just not what the schematics implies
      apakundefined 1 Reply Last reply Reply Quote 0
      • apakundefined
        apak @jay_s_uk
        seems everything is in place, also the 74HC74
        guess that the chinnese clons just install everything for the wifi version and then just plug the ethernet board
        • arhiundefined
          arhi @alankilian
          @alankilian said in ethernet to esp breakboard:
          @apak If you ever want to do this kind of thing again, you might want to use these surface-mount 0.1" header pins.
          https://www.digikey.com/en/products/detail/oupiin/2015-1X40G01DBB/13251225
          pay attention that these are not super strong and that, especially with 3 raw's of pins, removing the board from the socket requires a lot of force and it can rip the pins off the board ... happened to me too many times to count 😞 that I avoid using the smd .1" pins any time I can
          taking into account how free the boards at jlcpcb are I'd go with 4 layer, put all the traces inside and ground on the outside, it should help with EMI and the behavior of the ESP module and would not change the price of the board significantly
          • apakundefined
            apak @arhi
            @arhi
            I had to make my own pin strip since on my local store didn´t have them
            It´s working fine, no disconnections while printing like with the first prototype
            photo_2021-04-26_09-34-29.jpg photo_2021-04-26_09-34-28.jpg photo_2021-04-26_10-29-33.jpg photo_2021-04-26_10-29-31.jpg photo_2021-04-26_10-29-29.jpg photo_2021-04-26_10-29-26.jpg photo_2021-04-26_10-29-22.jpg photo_2021-04-26_10-29-19.jpg
            arhiundefined CNCModellerundefined 2 Replies Last reply Reply Quote 1
            • arhiundefined
              arhi @apak
              @apak said in ethernet to esp breakboard:
              I have never seen those disconnect from vibrations, I had them rip out the pads when you try to remove them from the header
              • apakundefined
                apak @arhi
                @arhi I meant the the first prototype had wifi disconections due to long tracks, this one has shorter pads, and looks like it works just fine while printing. The first one just didn´t work while printing
                alankilianundefined arhiundefined 2 Replies Last reply Reply Quote 2
                • alankilianundefined
                  alankilian @apak
                  @apak Excellent work.
                  It's great to see prototypes make progress to working products.
                  • arhiundefined
                    arhi @apak
                    @apak glad to hear, I assumed since you tagged me you were talking about other stuff :D, but yes, I mentioned both things so makes sense 🙂 ... great that it works!!! I myself converted few from wifi to eth 😄 I hate wifi on static equipment
                    • CNCModellerundefined
                      CNCModeller @apak
                      @apak
                      That looks the part alright. Can you please share the PCB design so I can order one for my Duet?
                      Many thanks
                      Barry M
                      Polar Duet3 Mini + 1HCL
                      https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
                      Wanhao D4S: Duet2
                      https://forum.duet3d.com/post/296755
                      K40 Laser, Duet2
                      https://forum.duet3d.com/post/312082
                      Wanhao D5S
                      https://www.youtube.com/CNCModellerUK
                      • apakundefined
                        apak @CNCModeller
                        @cncmodeller
                        do it at your own risk!!! 🙂
                        https://easyupload.io/cbfp23
