ethernet to esp breakboard
36
1.7k
    dc42 administrators @jay_s_uk
    The other thing that may be missing on an Ethernet board is the 74HC74 chip. However, if you use wifi firmware 1.24 or later then you can bypass it by installing R82.
      apak @jay_s_uk
      @jay_s_uk all that should be already on the duet board, we are talking to direct pin contact between alt comm ports and the esp solder traces...
      At this point I point out that I have just converted ethernet clone boards to esp-07s so far with no trouble, but soldering the esp to the board traces
      undefined 1 Reply Last reply 14 Apr 2021, 10:53 Reply Quote 0
        jay_s_uk @apak
        @apak fair enough. It's just not what the schematics implies
        undefined 1 Reply Last reply 15 Apr 2021, 08:59 Reply Quote 0
          apak @jay_s_uk
          seems everything is in place, also the 74HC74
          guess that the chinnese clons just install everything for the wifi version and then just plug the ethernet board
            arhi @alankilian
            @alankilian said in ethernet to esp breakboard:
            @apak If you ever want to do this kind of thing again, you might want to use these surface-mount 0.1" header pins.
            https://www.digikey.com/en/products/detail/oupiin/2015-1X40G01DBB/13251225
            pay attention that these are not super strong and that, especially with 3 raw's of pins, removing the board from the socket requires a lot of force and it can rip the pins off the board ... happened to me too many times to count 😞 that I avoid using the smd .1" pins any time I can
            taking into account how free the boards at jlcpcb are I'd go with 4 layer, put all the traces inside and ground on the outside, it should help with EMI and the behavior of the ESP module and would not change the price of the board significantly
            undefined 1 Reply Last reply 26 Apr 2021, 08:35 Reply Quote 0
              apak @arhi
              @arhi
              I had to make my own pin strip since on my local store didn´t have them
              It´s working fine, no disconnections while printing like with the first prototype
              photo_2021-04-26_09-34-29.jpg photo_2021-04-26_09-34-28.jpg photo_2021-04-26_10-29-33.jpg photo_2021-04-26_10-29-31.jpg photo_2021-04-26_10-29-29.jpg photo_2021-04-26_10-29-26.jpg photo_2021-04-26_10-29-22.jpg photo_2021-04-26_10-29-19.jpg
              undefined undefined 2 Replies Last reply 26 Apr 2021, 09:46 Reply Quote 1
                arhi @apak
                @apak said in ethernet to esp breakboard:
                I have never seen those disconnect from vibrations, I had them rip out the pads when you try to remove them from the header
                undefined 1 Reply Last reply 26 Apr 2021, 10:08 Reply Quote 0
                  apak @arhi
                  @arhi I meant the the first prototype had wifi disconections due to long tracks, this one has shorter pads, and looks like it works just fine while printing. The first one just didn´t work while printing
                  undefined undefined 2 Replies Last reply 26 Apr 2021, 11:25 Reply Quote 2
                    alankilian @apak
                    @apak Excellent work.
                    It's great to see prototypes make progress to working products.
                      arhi @apak
                      @apak glad to hear, I assumed since you tagged me you were talking about other stuff :D, but yes, I mentioned both things so makes sense 🙂 ... great that it works!!! I myself converted few from wifi to eth 😄 I hate wifi on static equipment
                        CNCModeller @apak
                        @apak
                        That looks the part alright. Can you please share the PCB design so I can order one for my Duet?
                        Many thanks
                        Barry M
                        Polar Duet3 Mini + 1HCL
                        https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
                        Wanhao D4S: Duet2
                        https://forum.duet3d.com/post/296755
                        K40 Laser, Duet2
                        https://forum.duet3d.com/post/312082
                        Wanhao D5S
                        https://www.youtube.com/CNCModellerUK
                        undefined 1 Reply Last reply 27 Apr 2021, 14:38 Reply Quote 0
                          apak @CNCModeller
                          @cncmodeller
                          do it at your own risk!!! 🙂
                          https://easyupload.io/cbfp23
