    Duet3 1LC 1.0 vs 1.1
    • RyanPundefined
      RyanP
      I recently purchased a 1LC board from my local dealer (digitmakers in Toronto).
      The board I was provided was the 1.0 board.
      I've heard that the 1.1 board is needed to utilize an accelerometer. If true, Should I be asking for them to replace it with the 1.1 board?
      CR10S, August 2018
      Anycubic Photon S December 2019
      Ender 5 Feb 2020
      Ender 5 Plus May 2020
      Anycubic Photon Mono X Nov 2020
      https://3dimensiongames.com/
      jens55undefined engikeneerundefined 2 Replies Last reply Reply Quote 0
      • jens55undefined
        jens55 @RyanP
        @ryanp, I would .... ver 1.1 has been shipping for a while now. Ver 1.0 does not have an accelerometer on it.
        • engikeneerundefined
          engikeneer @RyanP
          @ryanp v1.1 has the accelerometer built-in. If you have a v1.0 you can still get a separate accelerometer chip and hook it up
          i3 clone with a bunch of mods
          • o_lampeundefined
            o_lampe @engikeneer
            @engikeneer said in Duet3 1LC 1.0 vs 1.1:
            Which is the more versatile option IMHO. Even dc42 mentioned, it would make sense to measure hotend versa bed ringing.
            How would you do that with 1.1?
              dc42 administrators @o_lampe
              @o_lampe said in Duet3 1LC 1.0 vs 1.1:
              That's on a bed slinger style of printer.
              anironundefined 1 Reply Last reply Reply Quote 0
              • anironundefined
                aniron @dc42
                @dc42 how do you best use that information, though? IF I am not mistaken, you still need to select a single frequency for suppression, not separate ones per axis?
                Do you pick the highest amplitude, the average of the peaks, or something else?
                Or is this meant for upcoming features?
                  dc42 administrators @aniron
                  @aniron said in Duet3 1LC 1.0 vs 1.1:
                  In the immediate future, you will either pick the frequency with the worst ringing, or a shaper that provides reasonable suppression at both frequencies.
                  We will probably offer the ability to configure different frequencies on X and Y axes in future, at least on Cartesian printers (It's much more complicated to implement on CoreXY).
