Duet3 1LC 1.0 vs 1.1
I recently purchased a 1LC board from my local dealer (digitmakers in Toronto).
The board I was provided was the 1.0 board.
I've heard that the 1.1 board is needed to utilize an accelerometer. If true, Should I be asking for them to replace it with the 1.1 board?
@ryanp, I would .... ver 1.1 has been shipping for a while now. Ver 1.0 does not have an accelerometer on it.
@ryanp v1.1 has the accelerometer built-in. If you have a v1.0 you can still get a separate accelerometer chip and hook it up
@engikeneer said in Duet3 1LC 1.0 vs 1.1:
Which is the more versatile option IMHO. Even dc42 mentioned, it would make sense to measure hotend versa bed ringing.
How would you do that with 1.1? -
@o_lampe said in Duet3 1LC 1.0 vs 1.1:
That's on a bed slinger style of printer.
@dc42 how do you best use that information, though? IF I am not mistaken, you still need to select a single frequency for suppression, not separate ones per axis?
Do you pick the highest amplitude, the average of the peaks, or something else?
Or is this meant for upcoming features?
@aniron said in Duet3 1LC 1.0 vs 1.1:
In the immediate future, you will either pick the frequency with the worst ringing, or a shaper that provides reasonable suppression at both frequencies.
We will probably offer the ability to configure different frequencies on X and Y axes in future, at least on Cartesian printers (It's much more complicated to implement on CoreXY).
