    Smart Effector issue
    Smart effector for delta printers
    10
    87
    4.2k
    • tecnoundefined
      tecno @Phaedrux
      @phaedrux
      Still as in latest picture = no duct.
      Total weight is 84grams with 3 fans, printed in PETG.
        jay_s_uk @Phaedrux
        @phaedrux that duct design (which is mine) works fine for me on my smart effector v3 so i doubt thats the issue. I still think its a mechanical issue with effector tilt
        tecnoundefined 1 Reply Last reply Reply Quote 0
        • tecnoundefined
          tecno @jay_s_uk
          Have found my main issue = the printed effector adapter is way too small = too short rods.
          Back to the drawing board!
          • tecnoundefined
            tecno @tecno
            A bit larger adapter 😉
            tecnoundefined 1 Reply Last reply Reply Quote 1
            • tecnoundefined
              tecno @tecno
              One violent move and this is the result.
              • tecnoundefined
                tecno @tecno
                So some days has gone and I am now trying to get the Smart Effector to work = no go!
                New non 3D printed effector adapter (original in alu with slight modifications)
                Area of bed 9 to 3 down to 6 can be probed G30 and 0,0 towards back about 50mm works
                Out of that area the smart effector is not sensitive enough as the effector needs to tilt a lot before it triggers.
                I find this a bit odd as the trigger LED on head moves. All set to default values.
                bed.g
                config.g
                  Your dive speed seems to be half the recommended value. M558 F600 vs M558 F1200
                  https://docs.duet3d.com/en/Duet3D_hardware/Accessories/Smart_Effector#configuring-firmware
                  M558 P8 R0.8 C"probe+servo0" H10 F600 T2000
                  M558 P8 R0.4 F1200
                  So perhaps it's not striking with enough force to reliably trigger.
                  • tecnoundefined
                    tecno @Phaedrux
                    @phaedrux
                    And looks like that, had to go all way up to 2500 to get reliable trig.
                    Where do I set hotend offset and where to set effector offset?
                    Looking from front X0/Y0 effector is to left and the hotend is a bit left too.
                    Phaedruxundefined tecnoundefined 2 Replies Last reply Reply Quote 0
                      Phaedrux Moderator @tecno
                      @tecno said in Smart Effector issue:
                      I'm not sure what you mean.
                      dc42undefined tecnoundefined 2 Replies Last reply Reply Quote 0
                        dc42 administrators @Phaedrux
                        FWIW we've identified a modification to the Smart Effector version 3 that improves the signal-to-noise ratio, which in turn allows you to use a higher sensitivity unless fan noise etc. prevents that. The modification is to remove capacitor C8. This can be done using a soldering iron with a bit large enough to cover both pads. Alternatively, you could use a small twist drill bit to remove a thin sliver of copper around the adjacent via that connects one end of the capacitor to the ground plane.
                        This image is as viewed from the top of the PCB, so you need to invert it when looking at the bottom.
                        • tecnoundefined
                          tecno @Phaedrux
                          @phaedrux said in Smart Effector issue:
                          G10 P0 X-4 Y0 Z0 ; set tool 0 axis offsets
                          G10 P0 R0 S0
                          Fixed offset issue
                          • tecnoundefined
                            tecno @dc42
                            @dc42 said in Smart Effector issue:
                            So far during my tests no fans are used, good to know when adding fans.
                            • tecnoundefined
                              tecno @tecno
                              Still some issues with false trig = does not go down but LED lights up = trig.
                              How to solve this?
                                When and where was it purchased?
                                • tecnoundefined
                                  tecno @Phaedrux
                                  Warning: Skipping grid point X=40.0, Y=60.0 because Z probe cannot reach it
                                  37 points probed, min error -0.260, max error 0.240, mean -0.026, deviation 0.113
                                  Height map saved to file 0:/sys/heightmap.csv
                                  From where does this X=40.0, Y=60.0 coordinate originate?
                                  • tecnoundefined
                                    tecno @Phaedrux
                                    A few weeks ago via James
                                    • tecnoundefined
                                      tecno @tecno
                                      @phaedrux
                                      Now on 3500 and the false trigs seems to be away, but need more testing to be sure.
                                      Also Dive height affects this now on 5mm
                                        dc42 administrators @tecno
                                        @tecno have you tried the following to eliminate the false triggering:
                                        • increase the R parameter in the M558 command, in case it is the previous XY move causing the spurious triggering;
                                        • reduce the probing acceleration, because it may be the Z acceleration at the start of the probing move that causes the spurious triggering.
                                        • tecnoundefined
                                          tecno @dc42
                                          Tried R0.8 still the issue +++ Will not go down to bed on all points !!!
                                            Assuming you're doing a G29 there, the grid spacing is determined by M557 in your config.g
                                            https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_mesh_bed
