    Opinions on "FYSETC" ... politely, please.
    56
    4.6k
    • o_lampeundefined
      o_lampe @Phaedrux
      @phaedrux said in Opinions on "FYSETC" ... politely, please.:
      Well at least they include the silk screen message
      Right, they even copied the "Esher3D" typo from the original ๐Ÿ˜ฌ
      • elmoretundefined
        elmoret @zBeeble
        @zbeeble If you want to email me (Filastruder), I can see what I can do to get you whatever you need at reasonable shipping. Anything to support Duet3D!
        zBeebleundefined 1 Reply Last reply Reply Quote 2
        • zBeebleundefined
          zBeeble @elmoret
          @elmoret Are you a wholesaler in Canada? I tried looking to see if I could PM you, but you have DnD set. If you gimme your URL, I'll be happy to look there for my next purchase.
          elmoretundefined 1 Reply Last reply Reply Quote 0
          • elmoretundefined
            elmoret @zBeeble
            @zbeeble In the US, Google Filastruder. Canโ€™t turn on DMs everywhere, canโ€™t track them all.
              T3P3Tony administrators @zBeeble
              @zbeeble both our Canadian Genuine resellers appear to have the PanelDue 7i in stock
              https://duet3d.com/page/genuine-resellers
              • achrnundefined
                achrn @breed
                @breed said in Opinions on "FYSETC" ... politely, please.:
                I find this interesting. What's the general opinions on the other Chinese manufactures making clones/alternatives? Makerbase, btt, mellow fly. I've never used a direct clone but have used a few mellow boards where I wanted to use stepsticks.
                I think clones and alternatives are very different things.
                It's a personal ethics choice, but personally I don't buy clones (chinese or otherwise), but I don't see any problem with alternatives. I have a Mellow board running a sand table, but it's completely different to any Duet3D board, though it runs RRF and I've discussed it here.
                I note that it is sometimes difficult to work out who 'started it' - I've seen people mounting a spirited attack on cheap 'ebay special' logic analysers claiming them to be clone / rip-off of saleae devices, but my undertsanding is that the cheapies and the (more basic) saleae devices are both copies of published specimen designs from the chip manufacturer. (I do use a cheapie logic analyser, I don't use saleae software with it.)
                I don't think Duet3D claims exclusive ownership of RRF firmware, people other than Duet3D employees have contributed to RRF (I assume - I haven't checked the origin of every line of current code), and indeed there are forums here for RRF on other hardware.
                See also https://forum.duet3d.com/topic/22800/what-s-the-stance-on-rrf-on-none-duet-boards
                  jay_s_uk @achrn
                  In terms of RRF on other boards, @gloomyandy is the dev who has ported RRF to STM32F4 and STM32H7 boards and I support with documentation etc. The Duet3D team are very supporting of the work we have done and we regularly contribute by finding and fixing bugs and supporting users on this forum.
                  We also work with Mellow in the development of their boards to ensure they work well with RRF, for example they are the only boards that come with ESP32 wifi adapters on board and the only ones that support monitoring of the PSU voltage
                  breedundefined 1 Reply Last reply Reply Quote 0
                  • breedundefined
                    breed @jay_s_uk
                    @jay_s_uk Ive had very good luck so far with the few mellow boards I have, with the exception of some issues connecting to USB here and there. I wish sometimes that duet made a board with stepsticks even if it had limited driver support, as I'd rather support duet than a Chinese company.
                    chrishammundefined CthulhuLabsundefined 2 Replies Last reply Reply Quote 1
                    • chrishammundefined
                      chrishamm administrators @breed
                      @breed Something for external stepper drivers like the new MB6XD?
                      Duet software engineer
                      • CthulhuLabsundefined
                        CthulhuLabs @breed
                        I am curious why you need this functionality. When I first got into 3D printing I was using a RAMPS 1.4 board and then went to a RADDS board. I burned out 8x DRV8825 over the course of a year and a half of use. I thought that having built in drivers was a bad idea because everyone seemed to blow them. After a ton of research though I learned that most of the time the blow because of excessive heat or mistakes that can be avoided with improved circuit design. I eventually moved to a Duet 2 Wifi board. Since then I have not burned a single stepper driver even doing the same dumb mistakes as I did in the past. I did have one stepper driver die on my Duet 2 Wifi, but that was on a brand new board and Filastruder immediately RMAed the board once it was confirmed to be a bad board. The Duet boards properly sink the heat away from the stepper driver chips and have all of the necessary protection circuits on them to prevent dumb mistakes. Sure there are still ways to burn one out, but it takes serious effort.
                        breedundefined 1 Reply Last reply Reply Quote 3
                        • breedundefined
                          breed @CthulhuLabs
                          @cthulhulabs the couple printers I use stepsticks on are running makerbase servo42c closed loop steppers. They are large deltas and I have found they help with the occasional layer shift issue. I could have wired them to a duet2wifi or whatever but it's just simpler to use the stepstick adapters. Plus I do as much playing with my printers as I do printing, boards and other various hardware move around a lot.
                          CthulhuLabsundefined 1 Reply Last reply Reply Quote 0
                            CthulhuLabs @breed
                            @breed
                            In other words you need support for external stepper drivers and not necessarily stepsticks. That is exactly what the MB6XD @chrishamm mentioned is designed for. Stepsticks are frankly a horrible design that became standard in 3D printers because they were cheap not because they were good.
                            o_lampeundefined breedundefined 2 Replies Last reply Reply Quote 1
                            • o_lampeundefined
                              o_lampe @CthulhuLabs
                              @cthulhulabs
                              IMHO the main reason , why people grilled their stepstick drivers was the motor current setting via potmeter. Especially A4988 came in different versions regarding current shunt resistors, making it hard to follow the guides.
                              The extended stepstick adaption on Mellow boards allow UART and SPI control to setup the driver, which is more convenient than the external 'black box' drivers I know.
                              Sadly the new MB6XD doesn't seem to support this setup feature?!
                              • Nightowlundefined
                                Nightowl
                                Being very new to the market and after a great deal of research into the alternatives, I chose the Duet (MB6HC) board for my CNC machine.
                                It took (and will take more!) time for me to become better aquainted with it, but there's one thing that stands out for me - the Duet warranty. I don't know if other (Chinese or otherwise) manufacturers would offer such a quick turnaround replacing a defective board, but Duet did (via the reseller), and any doubts I may have had at that point were dispelled.
                                Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
                                I'm still on my learning curve, so take everything I say with caution!
                                RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
                                zBeebleundefined 1 Reply Last reply Reply Quote 1
                                • zBeebleundefined
                                  zBeeble @Nightowl
                                  @nightowl Wow. Machine of spinny death controlled by duet. Props. To your sig, I know enough about woodworking to have great respect (and a little fear) of routers... pretty much the second scariest powertool in the woodshop. The first being the thickness planer. Tailing on a thickness planer put me through the first year of university (and engendered a deep dislike of oak).
                                  I have to say... there's a lot of difference between a machine whose malfunction creates an abstract silly-string sculpture and one that can maim.
                                  Nightowlundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
                                  • Nightowlundefined
                                    Nightowl @zBeeble
                                    @zbeeble said in Opinions on "FYSETC" ... politely, please.:
                                    Oh yeah, and it works brilliantly!
                                    There are a lot more 3D printer people on here than CNC people (and some that do both!) but they've been very helpful when I've been trying to get my head around stuff!
                                    zBeebleundefined 1 Reply Last reply Reply Quote 0
                                    • breedundefined
                                      breed @CthulhuLabs
                                      @cthulhulabs agreed. I wasn't aware the mb6xd was out. But actually using external and stepsticks.
                                      • zBeebleundefined
                                        zBeeble @Nightowl
                                        @nightowl actually... I was considering that my take on e3d's tool changer might have one of the tools being a dremel like device --- for cutting and buffing... but right now it's just a thought.
                                        • zaptaundefined
                                          zapta @SputnikOC3d
                                          @sputnikoc3d said in Opinions on "FYSETC" ... politely, please.:
                                          ABS Mafia in the voron community
                                          'ABS Mafia'. I like it. ๐Ÿ˜‰
                                          • o_lampeundefined
                                            o_lampe @zBeeble
                                            [OT]
                                            Although I agree about the dangers inherited in spinning tools, I'm sure people will use common sense and do some dry-testing before they put a tool in the spindle.
                                            I'm more afraid of laser-modules run by hobbyists, because they can fire up during commissioning/testing. We only have two eyes, but ten fingers ๐Ÿ˜‰
